[petsc-users] question about MatCreateRedundantMatrix
Jose E. Roman jroman at dsic.upv.es
Fri Sep 20 06:22:30 CDT 2019
I have tried with slepc-master and it works:
$ mpiexec -n 2 ./ex1 -eps_ciss_partitions 2
matrix size 774
(-78.7875,8.8022)
(-73.9569,-42.2401)
(-66.9942,-7.50907)
(-62.262,-2.71603)
(-58.9716,0.601111)
(-57.9883,0.298729)
(-57.8323,1.06041)
(-56.5317,1.10758)
(-56.0234,45.2405)
(-54.4058,2.88373)
(-25.946,26.0317)
(-23.5383,-16.9096)
(-19.0999,0.194467)
(-18.795,1.15113)
(-15.3051,0.915914)
(-14.803,-0.00475538)
(-8.52467,10.6032)
(-4.36051,2.29996)
(-0.525758,0.796658)
(1.41227,0.112858)
(1.53801,0.446984)
(9.43357,0.505277)
slepc-master will become version 3.12 in a few days. I have not tried with 3.11 but I think it should work.
It is always recommended to use the latest version. Version 3.8 is two years old.
Jose
> El 19 sept 2019, a las 20:33, Povolotskyi, Mykhailo <mpovolot at purdue.edu> escribió:
> Hong,
> do you have in mind a reason why the newer version should work or is it a general recommendation?
> Which stable version would you recommend to upgrade to?
> Thank you,
> Michael.
> On 09/19/2019 02:22 PM, Zhang, Hong wrote:
>> Michael,
>> [0]PETSC ERROR: No support for this operation for this object type
>> [0]PETSC ERROR: Mat type seqdense
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.8.4, Mar, 24, 2018
>> This is an old version of  Petsc. Can you update to the latest Petsc release?
>> Hong
>> On 09/19/2019 04:55 AM, Jose E. Roman wrote:
>> > Michael,
>> > In my previous email I should have checked it better. The CISS solver works indeed with dense matrices:
>> > $ mpiexec -n 2 ./ex2 -n 30 -eps_type ciss -terse -rg_type ellipse -rg_ellipse_center 1.175 -rg_ellipse_radius 0.075 -eps_ciss_partitions 2 -mat_type dense
>> > 2-D Laplacian Eigenproblem, N=900 (30x30 grid)
>> >   Solution method: ciss
>> >   Number of requested eigenvalues: 1
>> >   Found 15 eigenvalues, all of them computed up to the required tolerance:
>> >       1.10416, 1.10416, 1.10455, 1.10455, 1.12947, 1.12947, 1.13426, 1.13426,
>> >       1.16015, 1.16015, 1.19338, 1.19338, 1.21093, 1.21093, 1.24413
>> > There might be something different in the way matrices are initialized in your code. Send me a simple example that reproduces the problem and I will track it down.
>> > Sorry for the confusion.
>> > Jose
>> >> El 19 sept 2019, a las 6:20, hong--- via petsc-users <petsc-users at mcs.anl.gov> escribió:
>> >> Michael,
>> >> We have support of MatCreateRedundantMatrix for dense matrices. For example, petsc/src/mat/examples/tests/ex9.c:
>> >> mpiexec -n 4 ./ex9 -mat_type dense -view_mat -nsubcomms 2
>> >> Hong
>> >> On Wed, Sep 18, 2019 at 5:40 PM Povolotskyi, Mykhailo via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> >> Dear Petsc developers,
>> >> I found that MatCreateRedundantMatrix does not support dense matrices.
>> >> This causes the following problem: I cannot use CISS eigensolver from
>> >> SLEPC with dense matrices with parallelization over quadrature points.
>> >> Is it possible for you to add this support?
>> >> Thank you,
>> >> Michael.
>> >> p.s. I apologize if you received this e-mail twice, I sent if first from
>> >> a different address.
