[petsc-users] Strange Partition in PETSc 3.11 version on some computers
Danyang Su
danyang.su at gmail.com
Mon Sep 16 23:41:45 CDT 2019
On 2019-09-16 12:02 p.m., Matthew Knepley wrote:
> On Mon, Sep 16, 2019 at 1:46 PM Smith, Barry F. <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
> Very different stuff going on in the two cases, different
> objects being created, different number of different types of
> operations. Clearly a major refactorization of the code was done.
> Presumably a regression was introduced that changed the behavior
> dramatically, possible by mistake.
> You can attempt to use git bisect to determine what changed
> caused the dramatic change in behavior. Then it can be decided if
> the changed that triggered the change in the results was a bug or
> a planned feature.
> Danyang,
> Can you send me the smallest mesh you care about, and I will look at
> the partitioning? We can at least get quality metrics
> between these two releases.
> Thanks,
> Matt
Hi Matt,
This is the smallest mesh for the regional scale simulation that has
strange partition problem. It can be download via the link below.
https://www.dropbox.com/s/tu34jgqqhkz8pwj/basin-3d.vtk?dl=0
I am trying to reproduce the similar problem using smaller 2D mesh,
however, there is no such problem in 2D, even though the partitions
using PETSc 3.9.3 and 3.11.3 are a bit different, they both look
reasonable. As shown below, both rectangular mesh and triangular mesh
use DMPlex.
2D rectangular and triangle mesh
I will keep on testing using PETSc3.11.3 but with different compiler and
MPI to check if I can reproduce the problem.
Danyang
> Barry
> > On Sep 16, 2019, at 11:50 AM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> > Hi Barry and Matt,
> > Attached is the output of both runs with -dm_view -log_view
> included.
> > I am now coordinating with staff to install PETSc 3.9.3 version
> using intel2019u4 to narrow down the problem. Will get back to you
> later after the test.
> > Thanks,
> > Danyang
> > On 2019-09-15 4:43 p.m., Smith, Barry F. wrote:
> >> Send the configure.log and make.log for the two system
> configurations that produce very different results as well as the
> output running with -dm_view -info for both runs. The cause is
> likely not subtle, one is likely using metis and the other is
> likely just not using any partitioner.
> >>> On Sep 15, 2019, at 6:07 PM, Matthew Knepley via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >>> On Sun, Sep 15, 2019 at 6:59 PM Danyang Su
> <danyang.su at gmail.com <mailto:danyang.su at gmail.com>> wrote:
> >>> Hi Matt,
> >>> Thanks for the quick reply. I have no change in the adjacency.
> The source code and the simulation input files are all the same. I
> also tried to use GNU compiler and mpich with petsc 3.11.3 and it
> works fine.
> >>> It looks like the problem is caused by the difference in
> configuration. However, the configuration is pretty the same as
> petsc 3.9.3 except the compiler and mpi used. I will contact
> scinet staff to check if they have any idea on this.
> >>> Very very strange since the partition is handled completely by
> Metis, and does not use MPI.
> >>> Thanks,
> >>> Matt
> >>> Thanks,
> >>> Danyang
> >>> On September 15, 2019 3:20:18 p.m. PDT, Matthew Knepley
> <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> >>> On Sun, Sep 15, 2019 at 5:19 PM Danyang Su via petsc-users
> >>> Dear All,
> >>> I have a question regarding strange partition problem in PETSc
> 3.11 version. The problem does not exist on my local workstation.
> However, on a cluster with different PETSc versions, the partition
> seems quite different, as you can find in the figure below, which
> is tested with 160 processors. The color means the processor owns
> that subdomain. In this layered prism mesh, there are 40 layers
> from bottom to top and each layer has around 20k nodes. The
> natural order of nodes is also layered from bottom to top.
> >>> The left partition (PETSc 3.10 and earlier) looks good with
> minimum number of ghost nodes while the right one (PETSc 3.11)
> looks weired with huge number of ghost nodes. Looks like the right
> one uses partition layer by layer. This problem exists on a a
> cluster but not on my local workstation for the same PETSc version
> (with different compiler and MPI). Other than the difference in
> partition and efficiency, the simulation results are the same.
> >>> Below is PETSc configuration on three machine:
> >>> Local workstation (works fine): ./configure --with-cc=gcc
> --with-cxx=g++ --with-fc=gfortran --download-mpich
> --download-scalapack --download-parmetis --download-metis
> --download-ptscotch --download-fblaslapack --download-hypre
> --download-superlu_dist --download-hdf5=yes --download-ctetgen
> --with-debugging=0 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
> --with-cxx-dialect=C++11
> >>> Cluster with PETSc 3.9.3 (works fine):
> --prefix=/scinet/niagara/software/2018a/opt/intel-2018.2-intelmpi-2018.2/petsc/3.9.3
> CC=mpicc CXX=mpicxx F77=mpif77 F90=mpif90 FC=mpifc
> COPTFLAGS="-march=native -O2" CXXOPTFLAGS="-march=native -O2"
> FOPTFLAGS="-march=native -O2" --download-chaco=1
> --download-hypre=1 --download-metis=1 --download-ml=1
> --download-mumps=1 --download-parmetis=1 --download-plapack=1
> --download-prometheus=1 --download-ptscotch=1 --download-scotch=1
> --download-sprng=1 --download-superlu=1 --download-superlu_dist=1
> --download-triangle=1 --with-avx512-kernels=1
> --with-blaslapack-dir=/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl
> --with-debugging=0 --with-hdf5=1
> --with-mkl_pardiso-dir=/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl
> --with-scalapack=1
> --with-scalapack-lib="[/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]"
> --with-x=0
> >>> Cluster with PETSc 3.11.3 (looks weired):
> --prefix=/scinet/niagara/software/2019b/opt/intel-2019u4-intelmpi-2019u4/petsc/3.11.3
> FOPTFLAGS="-march=native -O2" --download-chaco=1 --download-hdf5=1
> --with-blaslapack-dir=/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl
> --with-cxx-dialect=C++11 --with-debugging=0
> --with-mkl_pardiso-dir=/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl
> --with-scalapack=1
> --with-scalapack-lib="[/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]"
> --with-x=0
> >>> And the partition is used by default dmplex distribution.
> >>> !c distribute mesh over processes
> >>> call DMPlexDistribute(dmda_flow%da,stencil_width, &
> >>> PETSC_NULL_SF,
> >>> PETSC_NULL_OBJECT,
> >>> distributedMesh,ierr)
> >>> CHKERRQ(ierr)
> >>> Any idea on this strange problem?
> >>> I just looked at the code. Your mesh should be partitioned by
> k-way partitioning using Metis since its on 1 proc for
> partitioning. This code
> >>> is the same for 3.9 and 3.11, and you get the same result on
> your machine. I cannot understand what might be happening on your
> cluster
> >>> (MPI plays no role). Is it possible that you changed the
> adjacency specification in that version?
> >>> Thanks,
> >>> Matt
> >>> Thanks,
> >>> Danyang
> >>> What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any results
> to which their experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/
> >>> Sent from my Android device with K-9 Mail. Please excuse my
> brevity.
> >>> -- Norbert Wiener
> > <basin-petsc-3.9.3.log><basin-petsc-3.11.3.log>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190916/e24ba29c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190916/e24ba29c/attachment-0001.png>
