[petsc-users] Optimized mode
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Mon Sep 16 23:40:49 CDT 2019
  What do you mean by 2.0e-4 units ?   If you mean the last 4 digits may differ in the two solutions, yes that is completely normal. How many digits you lose depends on the order of the operations  and the condition number of the matrix and and for elasticity that will very easily be  greater than 10^4
  Barry
From: https://pdfs.semanticscholar.org/dccf/d6daa35fc9d585de1f927c58cc29c4cd0bab.pdf
We conclude this section by noting the need for care in interpreting the forward error. Experiments in [24] show that simply changing the order of evaluation of an inner product in the substitution algorithm for solution of a triangular system can change the forward error in the computed solution by orders of magnitude. This means, for example, that it is dangerous to compare different codes or algorithms solely in terms of observed forward errors.
> On Sep 16, 2019, at 11:13 PM, Emmanuel Ayala via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi everyone,
> I have a code for elastic linear analysis which involves DMDA, SuperLu and matrix operations. I have a MPI vector which contains the nodal displacements, when I run the code in debug mode i get the same value for the norm (2 or Inf), for different number of process. But when I use the optimized mode, I have small variations for the same norm depending on the number of process.
> -Debug mode: the same norm value for any number of processes.
> -Optimized mode: the norm value changes with the number of processes. The variations are around 2.0e-4 units.
>  This is normal?
> For my optimized mode I used the next configuration
> ./configure --with-debugging=0 COPTFLAGS='-O3 -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3 -march=native -mtune=native' --download-mpich --download-superlu_dist --download-metis --download-parmetis --download-cmake --download-fblaslapack=1 --with-cxx-dialect=C++11
> Best regards.
