[petsc-users] Strange Partition in PETSc 3.11 version on some computers
Danyang Su
danyang.su at gmail.com
Sun Sep 15 16:17:49 CDT 2019
Dear All,
I have a question regarding strange partition problem in PETSc 3.11
version. The problem does not exist on my local workstation. However, on
a cluster with different PETSc versions, the partition seems quite
different, as you can find in the figure below, which is tested with 160
processors. The color means the processor owns that subdomain. In this
layered prism mesh, there are 40 layers from bottom to top and each
layer has around 20k nodes. The natural order of nodes is also layered
from bottom to top.
The left partition (PETSc 3.10 and earlier) looks good with minimum
number of ghost nodes while the right one (PETSc 3.11) looks weired with
huge number of ghost nodes. Looks like the right one uses partition
layer by layer. This problem exists on a a cluster but not on my local
workstation for the same PETSc version (with different compiler and
MPI). Other than the difference in partition and efficiency, the
simulation results are the same.
partition difference
Below is PETSc configuration on three machine:
Local workstation (works fine): ./configure --with-cc=gcc
--with-cxx=g++ --with-fc=gfortran --download-mpich --download-scalapack
--download-parmetis --download-metis --download-ptscotch
--download-fblaslapack --download-hypre --download-superlu_dist
--download-hdf5=yes --download-ctetgen --with-debugging=0 COPTFLAGS=-O3
CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 --with-cxx-dialect=C++11
Cluster with PETSc 3.9.3 (works fine):
--prefix=/scinet/niagara/software/2018a/opt/intel-2018.2-intelmpi-2018.2/petsc/3.9.3
CC=mpicc CXX=mpicxx F77=mpif77 F90=mpif90 FC=mpifc
COPTFLAGS="-march=native -O2" CXXOPTFLAGS="-march=native -O2"
FOPTFLAGS="-march=native -O2" --download-chaco=1 --download-hypre=1
--download-metis=1 --download-ml=1 --download-mumps=1
--download-parmetis=1 --download-plapack=1 --download-prometheus=1
--download-ptscotch=1 --download-scotch=1 --download-sprng=1
--download-superlu=1 --download-superlu_dist=1 --download-triangle=1
--with-avx512-kernels=1
--with-blaslapack-dir=/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl
--with-debugging=0 --with-hdf5=1
--with-mkl_pardiso-dir=/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl
--with-scalapack=1
--with-scalapack-lib="[/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/niagara/intel/2018.2/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]"
--with-x=0
Cluster with PETSc 3.11.3 (looks weired):
--prefix=/scinet/niagara/software/2019b/opt/intel-2019u4-intelmpi-2019u4/petsc/3.11.3
FOPTFLAGS="-march=native -O2" --download-chaco=1 --download-hdf5=1
--download-hypre=1 --download-metis=1 --download-ml=1 --download-mumps=1
--with-blaslapack-dir=/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl
--with-cxx-dialect=C++11 --with-debugging=0
--with-mkl_pardiso-dir=/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl
--with-scalapack=1
--with-scalapack-lib="[/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/intel/2019u4/compilers_and_libraries_2019.4.243/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]"
--with-x=0
And the partition is used by default dmplex distribution.
!c distribute mesh over processes
call DMPlexDistribute(dmda_flow%da,stencil_width, &
PETSC_NULL_SF, &
PETSC_NULL_OBJECT, &
distributedMesh,ierr)
CHKERRQ(ierr)
Any idea on this strange problem?
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190915/05528892/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190915/05528892/attachment-0001.png>
