[petsc-users] Segfault in DMPlexDistributeFieldIS with -log_view
Adrian Croucher
a.croucher at auckland.ac.nz
Thu Sep 12 21:59:06 CDT 2019
It's OK, I found the problem.
I was accidentally passing in a DM which hadn't been created yet. This
didn't matter when not using -log_view, because it looks like the DM
isn't actually used for anything else inside DMPlexDistributeFieldIS().
But when you run with -log_view it tries to get its communicator.
- Adrian
On 13/09/19 2:31 PM, Adrian Croucher wrote:
> hi
> My code is using DMPlexDistributeFieldIS() to distribute an index set,
> and it seems to work ok, except if I run with -log_view.
> In that case I get the error below.
> The code (Fortran) looks like this:
> call PetscSectionCreate(PETSC_COMM_WORLD, dist_section, ierr)
> CHKERRQ(ierr)
> call ISCreate(PETSC_COMM_WORLD, dist_index_set, ierr)
> CHKERRQ(ierr)
> call DMPlexDistributeFieldIS(self%dm, sf, section, &
> index_set, dist_section, &
> dist_index_set, ierr); CHKERRQ(ierr)
> call PetscSectionDestroy(dist_section, ierr); CHKERRQ(ierr)
> call ISDestroy(index_set, ierr); CHKERRQ(ierr)
> index_set = dist_index_set
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
