[petsc-users] DMDAGetElements and global/local element number
Dave May
dave.mayhem23 at gmail.com
Thu Sep 12 15:21:33 CDT 2019
On Thu, 12 Sep 2019 at 20:21, Emmanuel Ayala via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi everyone, it would be great if someone can give me a hint for this
> issue, i have been trying to figure out how to solve it, but i did not
> succeed
> I'm using DMDA to generate a 3D mesh (DMDA_ELEMENT_Q1). I'm trying to fill
> a MPI matrix with some values wich are related to the dofs of each element
> node, moreover i need to set this values based on the element number.
> Something like:
> mpi_A(total_elements X total_dofs)
> total_dofs
> row_0 (element_0) a_0 a_1 a_2 ... a_23
> row_1 (element_1) a_0 a_1 a_2 ... a_23
> row_2 (element_2)
> row_n (element_n) a_0 a_1 a_2 ... a_23
> The element number is related to the row index. And the matrix values are
> set depending of the DOFs related to the element.
> With DMDAGetElements i can read the LOCAL nodes connected to the element
> and then the DOFs associated to the element. I can handle the local and
> global relations with DMGetLocalToGlobalMapping, MatSetLocalToGlobalMapping
> and MatSetValuesLocal. BUT i CAN NOT understand how to know the element
> number in LOCAL or GLOBAL contex. DMDAGetElements gives the NUMBER OF
> ELEMENTS owned in the local process, but there is not any information about
> the local or global ELEMENT NUMBER.
> How to know the local or global element number related to the data
> provided by DMDAGetElements?
The DMDA defines cells of the same type (quads (2D) or hex (3D), hence
every cell defines the same number of vertices.
DMDAGetElements(DM dm,PetscInt *nel,PetscInt *nen,const PetscInt *e[])
nel - number of local elements
nen - number of element nodes
e - the local indices of the elements' vertices
e[] defines the ordering of the elements. e[] is an array containing all of
the element-vertex maps. Since each element in the DMDA has the same number
of vertices, the first nen values in e[] correspond to the vertices (local
index) associated with the first element. The next nen values in e[]
correspond to the vertices of the second element. The vertices for any
(local) element with the index "cid" can be sought via e[nen*cid + i] where
i would range from 0 to nen-1.
Why would you ever want, or need, the global element number? What is the
use case?
Dave
> Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190912/82a31d99/attachment.html>
