[petsc-users] Error running configure on SOWING
Danyang Su danyang.su at gmail.com
Tue Sep 10 13:11:08 CDT 2019
Sorry I forgot to attached the log file.
Attached are the log files using the following configuration:
./configure COPTFLAGS="-march=native -O2" CXXOPTFLAGS="-march=native
-O2" FOPTFLAGS="-march=native -O2" --with-scalapack=1
--with-scalapack-lib="[/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]"
--download-parmetis=1 --download-metis=1 --download-ptscotch=1
--download-fblaslapack=1 --download-hypre=1 --download-superlu_dist=1
--with-hdf5=1
--with-hdf5-dir=/scinet/niagara/software/2019a/opt/intel-2019.1-intelmpi-2019.1/hdf5-mpi/1.10.4
--download-zlib=1 --download-szlib=1 --download-ctetgen=1
--with-debugging=0 --with-cxx-dialect=C++11
--with-mpi-dir=/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mpi/intel64
--download-sowing-cc=/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/bin/intel64/icc
Danyang
On 2019-09-10 11:03 a.m., Smith, Barry F. wrote:
>    Please send the configure.log file when run with --download-sowing-cc=yourCcompiler  and also $PETSC_ARCH/externalpackages/git.sowing/config.log this will tell us why it is rejecting the C compiler.
>     Barry
>> On Sep 10, 2019, at 12:43 PM, Danyang Su via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Dear All,
>> I am trying to install petsc-dev on a cluster with intel compiler. However, the configuration get stuck on SOWING.
>> Error running configure on SOWING: Could not execute "['./configure --prefix=/home/m/min3p/danyangs/soft/petsc/petsc-dev/linux-intel-opt']":
>> checking for ranlib... ranlib
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether install works... yes
>> checking for ar... ar
>> checking for gcc... no
>> checking for cc... no
>> checking for cl.exe... noconfigure: error: in `/gpfs/fs1/home/m/min3p/danyangs/soft/petsc/petsc-dev/linux-intel-opt/externalpackages/git.sowing':
>> configure: error: no acceptable C compiler found in $PATH
>> See `config.log' for more details
>> Actually the C compiler is there.
>> If I use GNU compiler, there is no problem. I also tried to use different sowing configuration as discussed on https://lists.mcs.anl.gov/pipermail/petsc-dev/2018-June/023070.html, but without success.
>> The configuration is
>> ./configure COPTFLAGS="-march=native -O2" CXXOPTFLAGS="-march=native -O2" FOPTFLAGS="-march=native -O2" --with-scalapack=1 --with-scalapack-lib="[/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]" --download-parmetis=1 --download-metis=1 --download-ptscotch=1 --download-fblaslapack=1 --download-hypre=1 --download-superlu_dist=1 --with-hdf5=1 --with-hdf5-dir=/scinet/niagara/software/2019a/opt/intel-2019.1-intelmpi-2019.1/hdf5-mpi/1.10.4 --download-zlib=1 --download-szlib=1 --download-ctetgen=1 --with-debugging=0 --with-cxx-dialect=C++11 --with-mpi-dir=/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mpi/intel64 -download-sowing
>> Any suggestion on this?
>> Thanks and regards,
>> danyang
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190910/8fb9e08a/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190910/8fb9e08a/attachment-0003.bin>
