[petsc-users] Error running configure on SOWING
Danyang Su danyang.su at gmail.com
Tue Sep 10 12:43:56 CDT 2019
Dear All,
I am trying to install petsc-dev on a cluster with intel compiler.
However, the configuration get stuck on SOWING.
Error running configure on SOWING: Could not execute "['./configure
--prefix=/home/m/min3p/danyangs/soft/petsc/petsc-dev/linux-intel-opt']":
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking for ar... ar
checking for gcc... no
checking for cc... no
checking for cl.exe... noconfigure: error: in
`/gpfs/fs1/home/m/min3p/danyangs/soft/petsc/petsc-dev/linux-intel-opt/externalpackages/git.sowing':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
Actually the C compiler is there.
If I use GNU compiler, there is no problem. I also tried to use
different sowing configuration as discussed on
https://lists.mcs.anl.gov/pipermail/petsc-dev/2018-June/023070.html, but
without success.
The configuration is
./configure COPTFLAGS="-march=native -O2" CXXOPTFLAGS="-march=native
-O2" FOPTFLAGS="-march=native -O2" --with-scalapack=1
--with-scalapack-lib="[/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64/libmkl_scalapack_lp64.so,/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so]"
--download-parmetis=1 --download-metis=1 --download-ptscotch=1
--download-fblaslapack=1 --download-hypre=1 --download-superlu_dist=1
--with-hdf5=1
--with-hdf5-dir=/scinet/niagara/software/2019a/opt/intel-2019.1-intelmpi-2019.1/hdf5-mpi/1.10.4
--download-zlib=1 --download-szlib=1 --download-ctetgen=1
--with-debugging=0 --with-cxx-dialect=C++11
--with-mpi-dir=/scinet/niagara/intel/2019.1/compilers_and_libraries_2019.1.144/linux/mpi/intel64
-download-sowing
Any suggestion on this?
Thanks and regards,
danyang
