[petsc-users] error at run time
Sat Sep 7 01:40:48 CDT 2019
On Fri, Sep 6, 2019 at 5:22 PM Konstantinos Kontzialis via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi all,
> I run my code as follows:
> mpiexec -np 2 ./hoac test1.cgns
> and I get the following error:
> ./hoac: error while loading shared libraries: libpetsc.so.3.11: cannot
> open shared object file: No such file or directory
I assume this is Linux. You can fix this at least two ways:
  1) You can fix your link by using -rpath to point to the PETSc library
  2) You can put the PETSc library location in your LD_LIBRARY_PATH env
variable
     Matt
> but the libpetsc.so.3.11 exists.
> I ls my local petsc installation at:
> ls -l $PETSC_DIR/$PETSC_ARCH/lib
> and I get
> -rw-r--r--. 1 ** **   8955614 Sep  4 23:15 libcmumps.a
> -rw-r--r--. 1 ** **   8900950 Sep  4 23:15 libdmumps.a
> -rw-r--r--. 1 ** **   1655112 Sep  4 23:03 libfblas.a
> -rw-r--r--. 1 ** **  29819054 Sep  4 23:03 libflapack.a
> -rw-r--r--. 1 ** ** 110570758 Sep  4 23:16 libHYPRE.a
> -rwxr-xr-x. 1 ** **   1996784 Sep  4 23:05 libmetis.so
> -rw-r--r--. 1 ** **   3268440 Sep  4 23:15 libmumps_common.a
> -rwxr-xr-x. 1 ** **   1358144 Sep  4 23:05 libparmetis.so
> lrwxrwxrwx. 1 ** **        18 Sep  4 23:20 libpetsc.so ->
> libpetsc.so.3.11.3
> lrwxrwxrwx. 1 ** **        18 Sep  4 23:20 libpetsc.so.3.11 ->
> libpetsc.so.3.11.3
> -rwxrwxr-x. 1 ** ** 111015280 Sep  4 23:20 libpetsc.so.3.11.3
> -rw-r--r--. 1 ** **   2026784 Sep  4 23:15 libpord.a
> -rw-r--r--. 1 ** **  80737926 Sep  4 23:12 libscalapack.a
> -rw-r--r--. 1 ** **   8902046 Sep  4 23:15 libsmumps.a
> -rw-r--r--. 1 ** **   8973822 Sep  4 23:15 libzmumps.a
> drwxr-xr-x. 3 ** **      4096 Sep  4 22:55 petsc
> drwxr-xr-x. 2 ** **      4096 Sep  4 23:03 pkgconfig
> and I see that the libepetsc.so.3.11 exists as a link.
> Why do I get this error then?
> Regards,
> Kostas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190907/93f7cf90/attachment.html>
