[petsc-users] question about CISS
Povolotskyi, Mykhailo
mpovolot at purdue.edu
Fri Sep 6 15:11:57 CDT 2019
Hello,
I have been experimenting with CISS by computing part of the spectrum of
a complex matrix of rather small size (774).
I have compared two spectral regions: the circle and the ring.
The results were compared against LAPACK.
The attached figure shows that the accuracy with the ring is low,
comparatively to a circle.
It looks like if the ring is used, the eigenvalues are found, but not
accurately.
The circle area works quite okay.
This is what I'm doing:
EPS eps;
EPSType type;
RG rg;
EPSCreate(MPI_COMM_SELF,&eps);
EPSSetOperators( eps,matrix_petsc,NULL);
EPSSetType(eps,EPSCISS);
EPSSetProblemType(eps, EPS_NHEP);
EPSSetFromOptions(eps);
EPSGetRG(eps,&rg);
RGSetType(rg,RGRING);
double vscale(1.0);
double start_ang(0);
double end_ang(1.0);
RGRingSetParameters(rg,center,radius,vscale,start_ang,end_ang,width);
EPSSolve(eps);
Could you, please, advise me on this problem?
Thank you,
Michael.
Type: image/png
Desc: circle_vs_ring2.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190906/5fa18186/attachment-0001.png>
