[petsc-users] configuring on OSX
Jed Brown jed at jedbrown.org
Tue Sep 3 23:09:41 CDT 2019
We always need configure.log, please.
You shouldn't have to set CPP; it's usually preferable to use $(CC) -E anyway.
Brian Van Straalen via petsc-users <petsc-users at mcs.anl.gov> writes:
> pulling from git PETSC and on master branch.
> ./configure CPP=/usr/bin/cpp
>              Configuring PETSc to compile on your system
> TESTING: checkCPreprocessor from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:592)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Cannot find a C preprocessor
> Brian
> my configure script
> configure_options = [
> #   '--with-mpi-dir=/usr/local/opt/open-mpi',
>    '--with-cc=/usr/bin/clang',
>    '--with-cpp=/usr/bin/cpp',
>    '--with-cxx=/usr/bin/clang++',
>    '--with-fc=0',
>     'COPTFLAGS=-g -framework Accelerate',
>     'CXXOPTFLAGS=-g -framework Accelerate',
>     'FOPTFLAGS=-g',
> #  '--with-memalign=64',
>   '--download-hypre=1',
>   '--download-metis=1',
>   '--download-parmetis=1',
>   '--download-c2html=1',
>   '--download-ctetgen',
> #  '--download-viennacl',
> #  '--download-ml=1',
>   '--download-p4est=1',
>   '--download-superlu_dist',
>   '--download-superlu',
>   '--with-cxx-dialect=C++11',
>   '--download-mumps=1',
>   '--download-scalapack=1',
> #  '--download-exodus=1',
> #  '--download-ctetgen=1',
>   '--download-triangle=1',
> #  '--download-pragmatic=1',
> #  '--download-eigen=1',
>   '--download-zlib',
>   '--with-x=1',
>   '--with-sowing=0',
>   '--with-debugging=1',
>   '--with-precision=double',
>   'PETSC_ARCH=arch-macosx-gnu-g',
>   '--download-chaco'
> if __name__ == '__main__':
>   import sys,os
>   sys.path.insert(0,os.path.abspath('config'))
>   import configure
>   configure.petsc_configure(configure_options)
> Brian Van Straalen         Lawrence Berkeley Lab
> BVStraalen at lbl.gov        Computational Research
> (510) 486-4976            Division (crd.lbl.gov)
