[petsc-users] is TS_EQ_DAE_SEMI_EXPLICIT_INDEX functional
Constantinescu, Emil M.
emconsta at anl.gov
Mon Sep 2 19:27:40 CDT 2019
Indeed, various time steppers can take advantage of the differential
form provided and also can serve as a sanity check (e.g., warn users
before they use an explicit solver on an index-2 DAE). To my knowledge,
we do not have solvers that take advantage of semi-explicit DAEs, but
it's good practice to annotate applications for when solvers are
available. In ARKIMEX, we check only if the problem is TS_EQ_IMPLICIT or
not (this includes DAEs and ODEs with mass matrix on the left M\dot{u}).
If you are solving a DAE, you should use TS_EQ_IMPLICIT. G=M^-1 g is
either for nonstiff ODE or partitioned ODE with mass matrix, which can
be used if you have a fast way to compute M^-1 g.
Emil
On 9/2/19 4:44 PM, Jed Brown wrote:
> I believe this is intended to work with most any implicit solver,
> *provided* the initial conditions are compatible. It was added by Emil,
> but I don't see it explicitly tested in PETSc.
> "Huck, Moritz via petsc-users" <petsc-users at mcs.anl.gov> writes:
>> Hi,
>> TS_EQ_DAE_SEMI_EXPLICIT_INDEX(?) are defined in TSEquationType but not mentioned in the manual.
>> Is this feature functional ?
>> If yes how do I have to define the RHSFunction?
>> (I am asking since the ODE variant has it defined as G= M^-1 g, which cannot work for a DAE)
>> Best Regards,
>> Moritz
