[petsc-users] BAIJCUSPARSE?
Xiangdong
epscodes at gmail.com
Wed Oct 30 15:45:09 CDT 2019
Thanks for pointing the function MatXAIJSetPreallocation() out. I followed
your suggestions and tried it on my problem:
preallocate the matrix with XAIJ, set its values by
MatSetValuesBlockedLocal, and use this matrix with aijcusparse.
It works!
Thank you.
Xiangdong
On Tue, Oct 29, 2019 at 8:10 PM Mills, Richard Tran <rtmills at anl.gov> wrote:
> We will let you know when this is ready, Xiangdong.
> Let me address a part of your original question that I don't think anyone
> else noticed:
> In my current code, the Jacobian matrix preallocated and assembled as BAIJ
> format. Do I have to rewrite this part of code to preallocate and assemble
> the matrix as AIJ in order to use aijcusparse?
> If you are doing your preallocation via MatXAIJSetPreallocation() and
> setting values via MatSetValuesBlocked() (or its variants), you can change
> the type to AIJ (or AIJCUSPARSE) instead of BAIJ and things should just
> work. (If not, let us know, as this may mean a bug in PETSc.) If you are
> calling MatSetFromOptions(), you should be able to do this on the command
> line (or otherwise through the PETSc options database) -- no code rewrites
> needed.
> Best regards,
> Richard
> On 10/28/19 7:40 AM, Xiangdong wrote:
> Thanks for your information. Glad to hear that BAIJ gpu support is on the
> way. Waiting a few weeks is not a issue at all. Once you finish the BAIJ
> GPU interface, could you please make an announcement here or in the change
> log?
> Thank you.
> Xiangdong
> On Sat, Oct 26, 2019 at 12:11 AM Mills, Richard Tran <rtmills at anl.gov>
> wrote:
>> Xiangdong,
>> cuSPARSE does support block compressed sparse row (BAIJ) format, but we
>> don't currently support that cuSPARSE functionality in PETSc. It should be
>> easy to add, but we are currently refactoring the way we interface with
>> third party GPU libraries such as cuSPARSE, and it would probably make more
>> sense to add this support after that refactor is done. Do you need this
>> right away, or could it wait maybe a few weeks until this is completed?
>> Best regards,
>> Richard
>> On Fri, Oct 25, 2019 at 1:50 PM Smith, Barry F. via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> You would need to investigate if the Nvidia cuSPARSE package supports
>>> such a format. If it does then it would be reasonably straightforward for
>>> you to hook up the required interface from PETSc. If it does not then it is
>>> a massive job to provide such code and you should see if any open source
>>> packages provide such CUDA support and then you could hook PETSc up to use
>>> that.
>>> Barry
>>> > On Oct 25, 2019, at 3:43 PM, Xiangdong via petsc-users <
>>> > Can anyone comment on the PETSc's GPU version of Block CSR, say
>>> BAIJCUSPARSE? Does it make sense to have such format on GPU? Is it under
>>> development?
>>> > Thank you.
>>> > Xiangdong
>>> > On Wed, Oct 23, 2019 at 11:36 AM Xiangdong <epscodes at gmail.com> wrote:
>>> > Hello everyone,
>>> > I am wondering whether there is a format BAIJCUSPARSE for Block CSR on
>>> GPU.
>>> BAIJ format. Do I have to rewrite this part of code to preallocate and
>>> assemble the matrix as AIJ in order to use aijcusparse?
>>> > Thank you.
>>> > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191030/83d95d47/attachment.html>
