[petsc-users] matsetvalueslocal for aijcusparse matrix
Xiangdong epscodes at gmail.com
Wed Oct 23 10:35:15 CDT 2019
Thanks, Barry. Your suggestion fixed my problem.
Xiangdong
On Tue, Oct 22, 2019 at 8:26 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   What a crap design PETSc has for GPUs. Sorry about this.
> Move
> > MatSetOptionPrefix(A,"test_")
> > 8 MatSetFromOptions
> to immediately after the MatSetType(A,MATAIJ).
>   What is happening is the original preallocation information you provided
> is lost when the matrix type is changed in MatSetFromOptions(), it comes
> from the ancient decision to have GPU vectors and matrices be entirely new
> subclasses instead of just providing GPU backends to the standard classes.
> Hopefully we can eventually fix this.
>   Barry
> > On Oct 22, 2019, at 3:32 PM, Xiangdong <epscodes at gmail.com> wrote:
> > My Matrix setup workflow is like this:
> > 1 MatCreate
> > 2 MatSetSizes
> > 3 MatSetType(A,MATAIJ)
> > 4 MatMPIAIJSetPreallocation
> > 5 MatSeqAIJSetPreallocation
> > 6 MatSetLocalToGlobalMapping
> > 7 MatSetOptionPrefix(A,"test_")
> > 8 MatSetFromOptions
> > 9 MatSetUp
> > 10 loop all the nonzero entries by calling
> MatSetValuesLocal(A,1,&i,1,&j, &val, ADD_VALUES);
> > 11 MatAssemblyBegin
> > 12 MatAssemblyEnd
> > For the AIJ format, it works fine. -info gives "Number of mallocs during
> MatSetValues() is 0" and "Stash has 0 entries, uses 0 mallocs."
> > If I run the same code with -test_mat_type aijcusparse, it takes forever
> to finish step 10. Does this step really involve moving data from host to
> devices? Do I need to have more changes to use aijcusparse other than just
> changing mat_type from command line?
> > Thank you.
> > Best,
> > Xiangdong
> > On Tue, Oct 22, 2019 at 1:53 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >    The aijcusparse actually uses the same data structures and code for
> setting values as does aij. So it is not related directly to that format.
> >   Barry
> > > On Oct 21, 2019, at 6:26 PM, Xiangdong via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > > Hello everyone,
> > > When I use matsetvalueslocal to form the matrix in aijcusparse format,
> I found that it takes forever to finish the loops of matsetvalueslocal. I
> am setting one entry a time, and there are about about 28 Million nonzeros.
> (It is fast if the matrix is aij, instead of aijcusparse).
> > > However, if I have the matrix ready in binary format and use matload
> to get it into aijcusparse format, it is fast.
> > > Is it the issue of matsetvalueslocal or my wrong way of using
> matsetvalueslocal? any suggestions to speed up the process?
> > > Thank you.
> > > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191023/63ba10dc/attachment-0001.html>
