[petsc-users] petsc-users Digest, Vol 130, Issue 75
Valeria Barra valeria.barra at colorado.edu
Mon Oct 21 11:07:15 CDT 2019
Hi Matt,
I'm not sure if this is something related to the issue I filed
https://gitlab.com/petsc/petsc/issues/423 where an unbalanced partitioning
was observed even on a very tiny mesh, created in
petsc/src/dm/impls/plex/examples/tutorials/ex7.c
Valeria
On Fri, Oct 18, 2019 at 6:21 PM <petsc-users-request at mcs.anl.gov> wrote:
> Send petsc-users mailing list submissions to
>         petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
>    1. Re:  Strange Partition in PETSc 3.11 version on some
>       computers (Matthew Knepley)
> Message: 1
> Date: Fri, 18 Oct 2019 20:20:13 -0400
> From: Matthew Knepley <knepley at gmail.com>
> To: Danyang Su <danyang.su at gmail.com>
> Cc: "Smith, Barry F." <bsmith at mcs.anl.gov>, Mark Lohry
>         <mlohry at gmail.com>,     PETSc <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Strange Partition in PETSc 3.11 version on
>         some computers
> Message-ID:
>         <CAMYG4Gk00hHAxspwm9CXPR8Nw+Tjh3QJN3rkwESRyc_dMkjG=
> A at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> On Fri, Oct 18, 2019 at 5:53 PM Danyang Su <danyang.su at gmail.com> wrote:
> > Hi All,
> > I am now able to reproduce the partition problem using a relatively small
> > mesh (attached). The mesh consists of 9087 nodes, 15656 prism cells.
> There
> > are 39 layers with 233 nodes for each layer. I have tested the partition
> > using PETSc as well as Gmsh 3.0.1.
> Great job finding a good test case. Can you send me that mesh?
>   Thanks,
>      Matt
> > Taking 4 partitions as an example, the partition from PETSc 3.9 and 3.10
> > are reasonable though not perfect, with total number of ghost nodes /
> total
> > number of nodes ratio 2754 / 9087.
> > The partition from PETSc 3.11, PETSc 3.12 and PETSc-dev look weird, with
> > total number of ghost nodes / total number of nodes: 12413 / 9087. The
> > nodes are not well connected for the same processor.
> > Note: the z axis is scaled by 25 for better visualization in paraview.
> > The partition from Gmsh-Metis is a bit different but still quite similar
> > to PETSc 3.9 and 3.10.
> > Finally, the partition using Gmsh-Chaco Multilevel-KL algorithm is the
> > best one, with total number of ghost nodes / total number of nodes: 741 /
> > 9087 . For most of my simulation cases with much larger meshes, PETSc 3.9
> > and 3.10 generate partition similar to the one below, which work pretty
> > well and the code can get very good speedup.
> > Thanks,
> > Danyang
> > On 2019-09-18 11:44 a.m., Danyang Su wrote:
> > On 2019-09-18 10:56 a.m., Smith, Barry F. via petsc-users wrote:
> > On Sep 18, 2019, at 12:25 PM, Mark Lohry via petsc-users
> > <petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov> wrote:
> > Mark,
> >      Mark,
> >        Good point. This has been a big headache forever
> >        Note that this has been "fixed" in the master version of PETSc and
> > will be in its next release. If you use --download-parmetis in the future
> > it will use the same random numbers on all machines and thus should
> produce
> > the same partitions on all machines.
> >         I think that metis has aways used the same random numbers and all
> > machines and thus always produced the same results.
> >      Barry
> > Good to know this. I will the same configuration that causes strange
> > partition problem to test the next version.
> > Thanks,
> > Danyang
> > The machine, compiler and MPI version should not matter.
> > I might have missed something earlier in the thread, but parmetis has a
> > dependency on the machine's glibc srand, and it can (and does) create
> > different partitions with different srand versions. The same mesh on the
> > same code on the same process count can and will give different
> partitions
> > (possibly bad ones) on different machines.
> > On Tue, Sep 17, 2019 at 1:05 PM Mark Adams via petsc-users
> > On Tue, Sep 17, 2019 at 12:53 PM Danyang Su <danyang.su at gmail.com>
> > Hi Mark,
> > Thanks for your follow-up.
> > The unstructured grid code has been verified and there is no problem in
> > the results. The convergence rate is also good. The 3D mesh is not good,
> it
> > is based on the original stratum which I haven't refined, but good for
> > initial test as it is relative small and the results obtained from this
> > mesh still makes sense.
> > The 2D meshes are just for testing purpose as I want to reproduce the
> > partition problem on a cluster using PETSc3.11.3 and Intel2019.
> > Unfortunately, I didn't find problem using this example.
> > The code has no problem in using different PETSc versions (PETSc V3.4 to
> > V3.11)
> > OK, it is the same code. I thought I saw something about your code
> > changing.
> > Just to be clear, v3.11 never gives you good partitions. It is not just a
> > problem on this Intel cluster.
> >   and MPI distribution (MPICH, OpenMPI, IntelMPI), except for one
> > simulation case (the mesh I attached) on a cluster with PETSc3.11.3 and
> > Intel2019u4 due to the very different partition compared to PETSc3.9.3.
> Yet
> > the simulation results are the same except for the efficiency problem
> > because the strange partition results into much more communication (ghost
> > nodes).
> > I am still trying different compiler and mpi with PETSc3.11.3 on that
> > cluster to trace the problem. Will get back to you guys when there is
> > update.
> > This is very strange. You might want to use 'git bisect'. You set a good
> > and a bad SHA1 (we can give you this for 3.9 and 3.11 and the exact
> > commands). The git will go to a version in the middle. You then
> > reconfigure, remake, rebuild your code, run your test. Git will ask you,
> as
> > I recall, if the version is good or bad. Once you get this workflow going
> > it is not too bad, depending on how hard this loop is of course.
> >   Thanks,
> > danyang
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191018/a51cd5a4/attachment.html
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191018/a51cd5a4/attachment.png
> Type: image/png
> Desc: not available
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191018/a51cd5a4/attachment-0001.png
> Type: image/png
> Desc: not available
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191018/a51cd5a4/attachment-0002.png
> Subject: Digest Footer
> End of petsc-users Digest, Vol 130, Issue 75
*Valeria Barra,*
*Postdoctoral Research Associate,*
*Department of Computer Science,*
*University of Colorado at Boulder*
https://csel-web.cs.colorado.edu/~vaba3353
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191021/fa03f2bb/attachment.html>
