[petsc-users] negative grid complexity in GAMG
Thu Oct 17 05:48:00 CDT 2019
On Thu, Oct 17, 2019 at 6:22 AM Mark Lohry via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi Mark,
> I assume these are advection problems and smoothed aggregation does not
>> work well.
> Correct, it stagnates immediately with smoothed aggregation.
> I think '-pc_gamg_square_graph 20' should reduce the number of levels and
>> work better for you.
> On the big problem it's producing 20 levels without -pc_gamg_square_graph
> 20; with that on it produces 6 levels. It certainly has less of the
> near-identical-size coarse levels, but overall convergence time is roughly
> the same. Any suggestion of where to go from here?
So with many fewer levels, are you saying
  a) It takes more iterates?
  b) It takes the same wall clock time?
I think you might want to switch to beefier smoothers on those lower levels
if you see
more iterates. Mark?
    Matt
> Original setup without pc_gamg_square_graph 20:
> [0] PCSetUp_GAMG(): level 0) N=347149550, n data rows=5, n data cols=5,
> nnz/row (ave)=250, np=1920
> [0] PCGAMGFilterGraph(): 100.% nnz after filtering, with threshold 0., 50.
> nnz ave. (N=69429910)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
> [0] PCGAMGProlongator_AGG(): New grid 894786 nodes
> [0] PCSetUp_GAMG(): 1) N=4473930, n data cols=5, nnz/row (ave)=51, 1920
> active pes
> 10.1761 nnz ave. (N=894786)
> [0] PCGAMGProlongator_AGG(): New grid 184262 nodes
> [0] PCSetUp_GAMG(): 2) N=921310, n data cols=5, nnz/row (ave)=68, 1920
> active pes
> 13.0556 nnz ave. (N=184262)
> [0] PCGAMGProlongator_AGG(): New grid 41002 nodes
> [0] PCSetUp_GAMG(): 3) N=205010, n data cols=5, nnz/row (ave)=72, 1920
> active pes
> 10.0909 nnz ave. (N=41002)
> [0] PCGAMGProlongator_AGG(): New grid 12587 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 20 with simple
> aggregation
> [0] PCSetUp_GAMG(): 4) N=62935, n data cols=5, nnz/row (ave)=62, 960
> active pes
> 5.33333 nnz ave. (N=12587)
> [0] PCGAMGProlongator_AGG(): New grid 5811 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 40 with simple
> aggregation
> [0] PCSetUp_GAMG(): 5) N=29055, n data cols=5, nnz/row (ave)=50, 640
> active pes
> [0] PCGAMGFilterGraph(): 100.% nnz after filtering, with threshold 0., 3.8
> nnz ave. (N=5811)
> [0] PCGAMGProlongator_AGG(): New grid 3442 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 110 with simple
> aggregation
> [0] PCSetUp_GAMG(): 6) N=17210, n data cols=5, nnz/row (ave)=40, 320
> active pes
> 4.66176 nnz ave. (N=3442)
> [0] PCGAMGProlongator_AGG(): New grid 2365 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 275 with simple
> aggregation
> [0] PCSetUp_GAMG(): 7) N=11825, n data cols=5, nnz/row (ave)=34, 240
> active pes
> 4.961 nnz ave. (N=2365)
> [0] PCGAMGProlongator_AGG(): New grid 1792 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 1125 with simple
> aggregation
> [0] PCSetUp_GAMG(): 8) N=8960, n data cols=5, nnz/row (ave)=28, 192 active
> pes
> 5.79911 nnz ave. (N=1792)
> [0] PCGAMGProlongator_AGG(): New grid 1479 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 7395 with simple
> aggregation
> [0] PCSetUp_GAMG(): 9) N=7395, n data cols=5, nnz/row (ave)=24, 160 active
> pes
> 4.86883 nnz ave. (N=1479)
> [0] PCGAMGProlongator_AGG(): New grid 1378 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 6890 with simple
> aggregation
> [0] PCSetUp_GAMG(): 10) N=6890, n data cols=5, nnz/row (ave)=22, 128
> active pes
> 4.44702 nnz ave. (N=1378)
> [0] PCGAMGProlongator_AGG(): New grid 1210 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 6050 with simple
> aggregation
> [0] PCSetUp_GAMG(): 11) N=6050, n data cols=5, nnz/row (ave)=18, 120
> active pes
> 3.64298 nnz ave. (N=1210)
> [0] PCGAMGProlongator_AGG(): New grid 1185 nodes
> [0] PCGAMGCreateLevel_GAMG(): Aggregate processors noop: new_size=120,
> neq(loc)=5925
> [0] PCSetUp_GAMG(): 12) N=5925, n data cols=5, nnz/row (ave)=17, 120
> active pes
> 3.54177 nnz ave. (N=1185)
> [0] PCGAMGProlongator_AGG(): New grid 1165 nodes
> neq(loc)=5825
> [0] PCSetUp_GAMG(): 13) N=5825, n data cols=5, nnz/row (ave)=17, 120
> active pes
> 3.5133 nnz ave. (N=1165)
> [0] PCGAMGProlongator_AGG(): New grid 1137 nodes
> neq(loc)=5685
> [0] PCSetUp_GAMG(): 14) N=5685, n data cols=5, nnz/row (ave)=17, 120
> active pes
> 3.48021 nnz ave. (N=1137)
> [0] PCGAMGProlongator_AGG(): New grid 1097 nodes
> neq(loc)=5485
> [0] PCSetUp_GAMG(): 15) N=5485, n data cols=5, nnz/row (ave)=16, 120
> active pes
> 3.3938 nnz ave. (N=1097)
> [0] PCGAMGProlongator_AGG(): New grid 1088 nodes
> neq(loc)=5440
> [0] PCSetUp_GAMG(): 16) N=5440, n data cols=5, nnz/row (ave)=16, 120
> active pes
> 3.34375 nnz ave. (N=1088)
> [0] PCGAMGProlongator_AGG(): New grid 852 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 4260 with simple
> aggregation
> [0] PCSetUp_GAMG(): 17) N=4260, n data cols=5, nnz/row (ave)=15, 80 active
> pes
> 3.06103 nnz ave. (N=852)
> [0] PCGAMGProlongator_AGG(): New grid 848 nodes
> [0] PCSetUp_GAMG(): 18) N=4240, n data cols=5, nnz/row (ave)=15, 80 active
> pes
> 3.0566 nnz ave. (N=848)
> [0] PCGAMGProlongator_AGG(): New grid 3 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 15 with simple
> aggregation
> [0] PCSetUp_GAMG(): 19) N=15, n data cols=5, nnz/row (ave)=11, 1 active pes
> [0] PCSetUp_GAMG(): 20 levels, grid complexity = 1.00367
> With pc_gamg_square_graph 20:
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 20 to square
> active pes
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 2 of 20 to square
> [0] PCGAMGProlongator_AGG(): New grid 49106 nodes
> [0] PCSetUp_GAMG(): 2) N=245530, n data cols=5, nnz/row (ave)=80, 1920
> active pes
> 14.8 nnz ave. (N=49106)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 3 of 20 to square
> [0] PCGAMGProlongator_AGG(): New grid 1646 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 0 with simple
> aggregation
> [0] PCSetUp_GAMG(): 3) N=8230, n data cols=5, nnz/row (ave)=86, 160 active
> pes
> 11.5 nnz ave. (N=1646)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 4 of 20 to square
> [0] PCGAMGProlongator_AGG(): New grid 56 nodes
> aggregation
> [0] PCSetUp_GAMG(): 4) N=280, n data cols=5, nnz/row (ave)=62, 6 active pes
> 12.5714 nnz ave. (N=56)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 5 of 20 to square
> [0] PCGAMGProlongator_AGG(): New grid 4 nodes
> aggregation
> [0] PCSetUp_GAMG(): 5) N=20, n data cols=5, nnz/row (ave)=17, 1 active pes
> [0] PCSetUp_GAMG(): 6 levels, grid complexity = 1.00291
> On Wed, Oct 16, 2019 at 9:46 PM Mark Adams <mfadams at lbl.gov> wrote:
>> The block size refers to the number of dofs/vertex, so you want 5. (I
>> have no idea what is going on with block size set to 20).
>> This is better but also smaller. 10 levels is a lot a levels.
>> This is unsmoothed aggregation. I assume these are advection problems and
>> smoothed aggregation does not work well. This is not in my wheelhouse. I
>> Thanks,
>> Mark
>> On Wed, Oct 16, 2019 at 8:59 PM Mark Lohry <mlohry at gmail.com> wrote:
>>> Hi Mark, are you referring to how on the coarser levels the coarsening
>>> rate seems to nearly flatline? i.e. level 2 has 4,260 rows while level 1
>>> has 4,240 rows? I was curious about that too...
>>> Not sure if this is the cause, but I have gone back and forth on what
>>> blocksize I set; I'm doing high order elements with 5 coupled equations, so
>>> the true block size in that case is 50x50. For that I had played with
>>> setting block size to either 5 (number of equations) or 50 (actual block
>>> size) and seemed to have seen a meager 20% improvement with the block size
>>> at 5, so I kind of left it there.
>>> Running a much smaller variant of the same problem at lower order (block
>>> size 20 instead of 50), the -info grep you asked for is below. I'll get
>>> -info for the much larger case but it'll take a couple days.
>>> For options I'm running
>>> -snes_lag_jacobian 10000 -ksp_gmres_restart 100 -pc_gamg_agg_nsmooths 0
>>> -mg_levels_ksp_type richardson -mg_levels_pc_type asm -mg_levels_ksp_max_it
>>> 1
>>> -pc_mg_cycle_type v -snes_linesearch_type bt -snes_linesearch_order 3
>>> -snes_linesearch_monitor -mg_levels_sub_pc_factor_in_place true -info
>>> block size 5 :
>>> [0] PCSetUp_GAMG(): level 0) N=2006480, n data rows=5, n data cols=5,
>>> nnz/row (ave)=100, np=16
>>> 20. nnz ave. (N=401296)
>>> [0] PCGAMGProlongator_AGG(): New grid 12947 nodes
>>> [0] PCSetUp_GAMG(): 1) N=64735, n data cols=5, nnz/row (ave)=51, 16
>>> active pes
>>> 10.3351 nnz ave. (N=12947)
>>> [0] PCGAMGProlongator_AGG(): New grid 2671 nodes
>>> [0] PCSetUp_GAMG(): 2) N=13355, n data cols=5, nnz/row (ave)=66, 16
>>> active pes
>>> 12.5524 nnz ave. (N=2671)
>>> [0] PCGAMGProlongator_AGG(): New grid 598 nodes
>>> [0] PCSetUp_GAMG(): 3) N=2990, n data cols=5, nnz/row (ave)=65, 16
>>> active pes
>>> 12.7727 nnz ave. (N=598)
>>> [0] PCGAMGProlongator_AGG(): New grid 178 nodes
>>> [0] PCSetUp_GAMG(): 4) N=890, n data cols=5, nnz/row (ave)=52, 16 active
>>> pes
>>> 8.28571 nnz ave. (N=178)
>>> [0] PCGAMGProlongator_AGG(): New grid 80 nodes
>>> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 30 with simple
>>> aggregation
>>> [0] PCSetUp_GAMG(): 5) N=400, n data cols=5, nnz/row (ave)=34, 8 active
>>> pes
>>> 5.77778 nnz ave. (N=80)
>>> [0] PCGAMGProlongator_AGG(): New grid 50 nodes
>>> aggregation
>>> [0] PCSetUp_GAMG(): 6) N=250, n data cols=5, nnz/row (ave)=25, 4 active
>>> pes
>>> 4.76923 nnz ave. (N=50)
>>> [0] PCGAMGProlongator_AGG(): New grid 36 nodes
>>> [0] PCSetUp_GAMG(): 7) N=180, n data cols=5, nnz/row (ave)=18, 4 active
>>> pes
>>> 3.75 nnz ave. (N=36)
>>> [0] PCGAMGProlongator_AGG(): New grid 33 nodes
>>> [0] PCGAMGCreateLevel_GAMG(): Aggregate processors noop: new_size=4,
>>> neq(loc)=90
>>> [0] PCSetUp_GAMG(): 8) N=165, n data cols=5, nnz/row (ave)=18, 4 active
>>> pes
>>> 3.72222 nnz ave. (N=33)
>>> [0] PCGAMGProlongator_AGG(): New grid 8 nodes
>>> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 35 with simple
>>> aggregation
>>> [0] PCSetUp_GAMG(): 9) N=40, n data cols=5, nnz/row (ave)=15, 1 active
>>> pes
>>> [0] PCSetUp_GAMG(): 10 levels, grid complexity = 1.02237
>>> block size 20:
>>> [0] PCSetUp_GAMG(): level 0) N=2006480, n data rows=20, n data cols=20,
>>> 5. nnz ave. (N=100324)
>>> [0] PCGAMGProlongator_AGG(): New grid 12948 nodes
>>> [0] PCSetUp_GAMG(): 1) N=258960, n data cols=20, nnz/row (ave)=205, 16
>>> active pes
>>> 10.2857 nnz ave. (N=12948)
>>> [0] PCSetUp_GAMG(): 2) N=53420, n data cols=20, nnz/row (ave)=266, 16
>>> active pes
>>> 12.5548 nnz ave. (N=2671)
>>> [0] PCGAMGProlongator_AGG(): New grid 593 nodes
>>> [0] PCSetUp_GAMG(): 3) N=11860, n data cols=20, nnz/row (ave)=264, 16
>>> active pes
>>> 10.8519 nnz ave. (N=593)
>>> [0] PCGAMGProlongator_AGG(): New grid 181 nodes
>>> [0] PCSetUp_GAMG(): 4) N=3620, n data cols=20, nnz/row (ave)=214, 16
>>> active pes
>>> 8.375 nnz ave. (N=181)
>>> [0] PCGAMGProlongator_AGG(): New grid 79 nodes
>>> [0] PCSetUp_GAMG(): 5) N=1580, n data cols=20, nnz/row (ave)=164, 16
>>> active pes
>>> 8. nnz ave. (N=79)
>>> [0] PCGAMGProlongator_AGG(): New grid 43 nodes
>>> [0] PCSetUp_GAMG(): 6) N=860, n data cols=20, nnz/row (ave)=100, 16
>>> active pes
>>> 5. nnz ave. (N=43)
>>> [0] PCGAMGProlongator_AGG(): New grid 15 nodes
>>> aggregation
>>> [0] PCSetUp_GAMG(): 7) N=300, n data cols=20, nnz/row (ave)=81, 8 active
>>> pes
>>> 2.66667 nnz ave. (N=15)
>>> [0] PCGAMGProlongator_AGG(): New grid 1 nodes
>>> aggregation
>>> [0] PCSetUp_GAMG(): 8) N=20, n data cols=20, nnz/row (ave)=20, 1 active
>>> pes
>>> [0] PCSetUp_GAMG(): HARD stop of coarsening on level 7.  Grid too small:
>>> 1 block nodes
>>> [0] PCSetUp_GAMG(): 9 levels, grid complexity = 1.35745
>>> On Wed, Oct 16, 2019 at 5:12 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Thanks Barry,
>>>> Sorry I missed this.
>>>> Mark: this problem is going crazy. The (default) coarsening parameters
>>>> are terrible for you. Can run with -info, grep for GAMG and send that? And
>>>> please send me the gamg parameters that you are using.
>>>> Thanks,
>>>> Mark
>>>> On Wed, Oct 16, 2019 at 9:01 AM Smith, Barry F. via petsc-users <
>>>>> barry/2019-10-15/bug-gamg-complexity/maint
>>>>> https://gitlab.com/petsc/petsc/merge_requests/2179
>>>>> > On Oct 16, 2019, at 5:29 AM, Mark Lohry <mlohry at gmail.com> wrote:
>>>>> > Well that was a quick late night bug fix. Thanks Barry, I'll try it
>>>>> out.
>>>>> > Just to confirm: You are running with with default double precision
>>>>> numbers and have used the configure option --with-64-bit-indices ?
>>>>> > Double precision floats, but 32 bit indices. I realize I'm playing
>>>>> with fire here, but I'm bumping very close to available memory limits at
>>>>> this scale and 64 bit indices tips me over. I figure integer index
>>>>> overflows would probably show a catastrophic failure, but all output looks
>>>>> sane.
>>>>> > I see you are using MATMFFD as the operator and MPIAIJ as the matrix
>>>>> from which to build the preconditioner? This is not suppose to cause any
>>>>> difficulties since the complexity computation code uses the second matrix,
>>>>> that is the MPAIJ matrix to get the complexity information.
>>>>> > Right, I'm using MATMFFD for the operator, and using a
>>>>> snes_lag_jacobian with SNESComputeJacobianDefaultColor for the matrix used
>>>>> to build to preconditioner. The actual behavior is exactly what I'd expect
>>>>> from smaller runs and the results look good, so it sounds like what you
>>>>> describe.
>>>>> > On Wed, Oct 16, 2019 at 12:17 AM Smith, Barry F. <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> >    I think I now see the bug: the code uses PetscInt       lev, nnz0
>>>>> = -1; which will overflow. It should be using PetscLogDouble for nnz0
>>>>> >   You can try changing that one place in the code and see that it
>>>>> now prints a reasonable value for complexity.
>>>>> >   I will prepare a MR for maint to fix the bug permanently.
>>>>> >   Barry
>>>>> > static PetscErrorCode PCMGGetGridComplexity(PC pc, PetscReal *gc)
>>>>> >   PetscErrorCode ierr;
>>>>> >   PC_MG          *mg      = (PC_MG*)pc->data;
>>>>> >   PC_MG_Levels   **mglevels = mg->levels;
>>>>> >   PetscInt       lev, nnz0 = -1;
>>>>> >   MatInfo        info;
>>>>> >   PetscFunctionBegin;
>>>>> >   if (!mg->nlevels) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_PLIB,"MG has
>>>>> no levels");
>>>>> >   for (lev=0, *gc=0; lev<mg->nlevels; lev++) {
>>>>> >     Mat dB;
>>>>> >     ierr =
>>>>> KSPGetOperators(mglevels[lev]->smoothd,NULL,&dB);CHKERRQ(ierr);
>>>>> >     ierr = MatGetInfo(dB,MAT_GLOBAL_SUM,&info);CHKERRQ(ierr); /*
>>>>> global reduction */
>>>>> >     *gc += (PetscReal)info.nz_used;
>>>>> >     if (lev==mg->nlevels-1) nnz0 = info.nz_used;
>>>>> >   if (nnz0) *gc /= (PetscReal)nnz0;
>>>>> >   else *gc = 0;
>>>>> >   PetscFunctionReturn(0);
>>>>> > > On Oct 15, 2019, at 11:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> > >   Mark,
>>>>> > >   It may be caused by some overflow in the calculations somewhere
>>>>> due to your very large sizes and nonzeros but I could not see anything
>>>>> based on a quick inspection of the code. We seem to use double to store the
>>>>> counts which normally would be more than sufficient to hold the results
>>>>> without overflow. Unless somewhere there is a mistaken use of int that
>>>>> causes a problem.
>>>>> precision numbers and have used the configure option --with-64-bit-indices
>>>>> matrix from which to build the preconditioner? This is not suppose to cause
>>>>> any difficulties since the complexity computation code uses the second
>>>>> matrix, that is the MPAIJ matrix to get the complexity information.
>>>>> > >   There is definitely a bug but I am hard pressed to suggest how
>>>>> to find it since it seems only to be expressed in your giant runs.
>>>>> > >  Barry
>>>>> > >> On Oct 15, 2019, at 9:16 PM, Mark Lohry via petsc-users <
>>>>> > >> I'm running some larger unsteady problems and trying to eek out
>>>>> some better GAMG performance. As is, at very small time steps, ASM
>>>>> preconditioner with ILU(0) is maybe 20% more efficient than my naive GAMG
>>>>> setup, which gives me hope that some tuning of GAMG can give some
>>>>> advantage. Convergence overall seems quite good, and light years better
>>>>> than ASM/ILU at larger time steps.
>>>>> > >> So looking through the manual and see a note that "grid
>>>>> complexity should be well under 2.0 and preferably around 1.3 or lower". I
>>>>> check ksp_view and see:
>>>>> > >> Complexity:    grid = -40.5483
>>>>> > >> Is something funny happening here?
>>>>> > >> Pasting whole -ksp_view below:
>>>>> > >> KSP Object: 1920 MPI processes
>>>>> > >>  type: fgmres
>>>>> > >>    restart=100, using Classical (unmodified) Gram-Schmidt
>>>>> Orthogonalization with no iterative refinement
>>>>> > >>    happy breakdown tolerance 1e-30
>>>>> > >>  maximum iterations=30, initial guess is zero
>>>>> > >>  tolerances:  relative=0.0001, absolute=1e-06, divergence=10.
>>>>> > >>  right preconditioning
>>>>> > >>  using UNPRECONDITIONED norm type for convergence test
>>>>> > >> PC Object: 1920 MPI processes
>>>>> > >>  type: gamg
>>>>> > >>    type is MULTIPLICATIVE, levels=20 cycles=v
>>>>> > >>      Cycles per PCApply=1
>>>>> > >>      Using externally compute Galerkin coarse grid matrices
>>>>> > >>      GAMG specific options
>>>>> > >>        Threshold for dropping small values in graph on each level
>>>>> =   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.
>>>>>  0.   0.   0.   0.
>>>>> > >>        Threshold scaling factor for each level not specified = 1.
>>>>> > >>        AGG specific options
>>>>> > >>          Symmetric graph false
>>>>> > >>          Number of levels to square graph 1
>>>>> > >>          Number smoothing steps 0
>>>>> > >>  Coarse grid solver -- level -------------------------------
>>>>> > >>    KSP Object: (mg_coarse_) 1920 MPI processes
>>>>> > >>      type: preonly
>>>>> > >>      maximum iterations=10000, initial guess is zero
>>>>> > >>      tolerances:  relative=1e-05, absolute=1e-50,
>>>>> divergence=10000.
>>>>> > >>      left preconditioning
>>>>> > >>      using NONE norm type for convergence test
>>>>> > >>    PC Object: (mg_coarse_) 1920 MPI processes
>>>>> > >>      type: bjacobi
>>>>> > >>        number of blocks = 1920
>>>>> > >>        Local solve is same for all blocks, in the following KSP
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_coarse_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> > >>        maximum iterations=1, initial guess is zero
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_coarse_sub_) 1 MPI processes
>>>>> > >>        type: lu
>>>>> > >>          out-of-place factorization
>>>>> > >>          tolerance for zero pivot 2.22045e-14
>>>>> > >>          using diagonal shift on blocks to prevent zero pivot
>>>>> [INBLOCKS]
>>>>> > >>          matrix ordering: nd
>>>>> > >>          factor fill ratio given 5., needed 1.
>>>>> > >>            Factored matrix follows:
>>>>> > >>              Mat Object: 1 MPI processes
>>>>> > >>                type: seqaij
>>>>> > >>                rows=15, cols=15, bs=5
>>>>> > >>                package used to perform factorization: petsc
>>>>> > >>                total: nonzeros=175, allocated nonzeros=175
>>>>> > >>                total number of mallocs used during MatSetValues
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 3 nodes, limit used
>>>>> is 5
>>>>> > >>        linear system matrix = precond matrix:
>>>>> > >>          type: seqaij
>>>>> > >>          total number of mallocs used during MatSetValues calls =0
>>>>> > >>            using I-node routines: found 3 nodes, limit used is 5
>>>>> > >>      Mat Object: 1920 MPI processes
>>>>> > >>        type: mpiaij
>>>>> > >>          using I-node (on process 0) routines: found 3 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 1
>>>>> > >>    KSP Object: (mg_levels_1_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> > >>      maximum iterations=1, nonzero initial guess
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_1_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> > >>        total subdomain blocks = 1920, amount of overlap = 0
>>>>> > >>        restriction/interpolation type - RESTRICT
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_1_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_1_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          in-place factorization
>>>>> > >>          0 levels of fill
>>>>> > >>          matrix ordering: natural
>>>>> > >>          factor fill ratio given 0., needed 0.
>>>>> > >>                type: seqaij
>>>>> > >>                rows=4240, cols=4240
>>>>> > >>                total: nonzeros=64800, allocated nonzeros=64800
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 848 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 848 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=4240, cols=4240, bs=5
>>>>> > >>          using nonscalable MatPtAP() implementation
>>>>> > >>          using I-node (on process 0) routines: found 848 nodes,
>>>>> limit used is 5
>>>>> > >>  Up solver (post-smoother) same as down solver (pre-smoother)
>>>>> > >>  Down solver (pre-smoother) on level 2
>>>>> > >>    KSP Object: (mg_levels_2_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_2_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_2_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_2_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=4260, cols=4260
>>>>> > >>                total: nonzeros=65200, allocated nonzeros=65200
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 852 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 852 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=4260, cols=4260, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 852 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 3
>>>>> > >>    KSP Object: (mg_levels_3_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_3_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_3_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_3_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=5440, cols=5440
>>>>> > >>                total: nonzeros=90950, allocated nonzeros=90950
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1088 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1088 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=5440, cols=5440, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1088 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 4
>>>>> > >>    KSP Object: (mg_levels_4_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_4_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_4_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_4_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=5485, cols=5485
>>>>> > >>                total: nonzeros=93075, allocated nonzeros=93075
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1097 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1097 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=5485, cols=5485, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1097 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 5
>>>>> > >>    KSP Object: (mg_levels_5_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_5_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_5_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_5_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=5685, cols=5685
>>>>> > >>                total: nonzeros=98925, allocated nonzeros=98925
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1137 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1137 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=5685, cols=5685, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1137 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 6
>>>>> > >>    KSP Object: (mg_levels_6_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_6_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_6_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_6_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=5825, cols=5825
>>>>> > >>                total: nonzeros=102325, allocated nonzeros=102325
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1165 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1165 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=5825, cols=5825, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1165 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 7
>>>>> > >>    KSP Object: (mg_levels_7_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_7_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_7_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_7_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=5925, cols=5925
>>>>> > >>                total: nonzeros=104925, allocated nonzeros=104925
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1185 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1185 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=5925, cols=5925, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1185 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 8
>>>>> > >>    KSP Object: (mg_levels_8_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_8_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_8_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_8_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=6050, cols=6050
>>>>> > >>                total: nonzeros=110200, allocated nonzeros=110200
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1210 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1210 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=6050, cols=6050, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1210 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 9
>>>>> > >>    KSP Object: (mg_levels_9_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_9_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_9_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_9_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=6890, cols=6890
>>>>> > >>                total: nonzeros=153200, allocated nonzeros=153200
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1378 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1378 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=6890, cols=6890, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1378 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 10
>>>>> > >>    KSP Object: (mg_levels_10_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_10_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_10_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_10_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=7395, cols=7395
>>>>> > >>                total: nonzeros=180025, allocated nonzeros=180025
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1479 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1479 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=7395, cols=7395, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1479 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 11
>>>>> > >>    KSP Object: (mg_levels_11_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_11_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_11_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_11_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=8960, cols=8960
>>>>> > >>                total: nonzeros=259800, allocated nonzeros=259800
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 1792 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 1792 nodes, limit used is
>>>>> 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=8960, cols=8960, bs=5
>>>>> > >>          using I-node (on process 0) routines: found 1792 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 12
>>>>> > >>    KSP Object: (mg_levels_12_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_12_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_12_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_12_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=1795, cols=1795
>>>>> > >>                total: nonzeros=33275, allocated nonzeros=33275
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 359 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 359 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=11825, cols=11825, bs=5
>>>>> > >>        total: nonzeros=403125, allocated nonzeros=403125
>>>>> > >>          using I-node (on process 0) routines: found 359 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 13
>>>>> > >>    KSP Object: (mg_levels_13_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_13_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_13_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_13_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=340, cols=340
>>>>> > >>                total: nonzeros=3500, allocated nonzeros=3500
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 68 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>          rows=340, cols=340
>>>>> > >>            using I-node routines: found 68 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=17210, cols=17210, bs=5
>>>>> > >>        total: nonzeros=696850, allocated nonzeros=696850
>>>>> > >>          using I-node (on process 0) routines: found 68 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 14
>>>>> > >>    KSP Object: (mg_levels_14_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_14_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_14_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_14_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=125, cols=125
>>>>> > >>                total: nonzeros=625, allocated nonzeros=625
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 25 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>          rows=125, cols=125
>>>>> > >>            using I-node routines: found 25 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=29055, cols=29055, bs=5
>>>>> > >>        total: nonzeros=1475675, allocated nonzeros=1475675
>>>>> > >>          using I-node (on process 0) routines: found 25 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 15
>>>>> > >>    KSP Object: (mg_levels_15_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_15_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_15_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_15_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=45, cols=45
>>>>> > >>                total: nonzeros=225, allocated nonzeros=225
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 9 nodes, limit used
>>>>> is 5
>>>>> > >>          type: seqaij
>>>>> > >>          rows=45, cols=45
>>>>> > >>            using I-node routines: found 9 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=62935, cols=62935, bs=5
>>>>> > >>        total: nonzeros=3939025, allocated nonzeros=3939025
>>>>> > >>          using I-node (on process 0) routines: found 9 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 16
>>>>> > >>    KSP Object: (mg_levels_16_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_16_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_16_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_16_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=55, cols=55
>>>>> > >>                total: nonzeros=725, allocated nonzeros=725
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 11 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>          rows=55, cols=55
>>>>> > >>            using I-node routines: found 11 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=205010, cols=205010, bs=5
>>>>> > >>        total: nonzeros=14780300, allocated nonzeros=14780300
>>>>> > >>          using scalable MatPtAP() implementation
>>>>> > >>          using I-node (on process 0) routines: found 11 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 17
>>>>> > >>    KSP Object: (mg_levels_17_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_17_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_17_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_17_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=360, cols=360
>>>>> > >>                total: nonzeros=14350, allocated nonzeros=14350
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 72 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>          rows=360, cols=360
>>>>> > >>            using I-node routines: found 72 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=921310, cols=921310, bs=5
>>>>> > >>        total: nonzeros=63203300, allocated nonzeros=63203300
>>>>> > >>          using I-node (on process 0) routines: found 72 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 18
>>>>> > >>    KSP Object: (mg_levels_18_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_18_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_18_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_18_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=2130, cols=2130
>>>>> > >>                total: nonzeros=87950, allocated nonzeros=87950
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 426 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>            using I-node routines: found 426 nodes, limit used is 5
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=4473930, cols=4473930, bs=5
>>>>> > >>        total: nonzeros=232427300, allocated nonzeros=232427300
>>>>> > >>          using I-node (on process 0) routines: found 426 nodes,
>>>>> limit used is 5
>>>>> > >>  Down solver (pre-smoother) on level 19
>>>>> > >>    KSP Object: (mg_levels_19_) 1920 MPI processes
>>>>> > >>      type: richardson
>>>>> > >>        damping factor=1.
>>>>> divergence=10000.
>>>>> > >>    PC Object: (mg_levels_19_) 1920 MPI processes
>>>>> > >>      type: asm
>>>>> and PC objects:
>>>>> > >>      KSP Object: (mg_levels_19_sub_) 1 MPI processes
>>>>> > >>        type: preonly
>>>>> divergence=10000.
>>>>> > >>      PC Object: (mg_levels_19_sub_) 1 MPI processes
>>>>> > >>        type: ilu
>>>>> > >>          0 levels of fill
>>>>> > >>                type: seqaij
>>>>> > >>                rows=179050, cols=179050
>>>>> > >>                total: nonzeros=42562500, allocated
>>>>> nonzeros=42562500
>>>>> calls =0
>>>>> > >>                  using I-node routines: found 35810 nodes, limit
>>>>> used is 5
>>>>> > >>          type: seqaij
>>>>> > >>          total: nonzeros=42562500, allocated nonzeros=42562500
>>>>> > >>            using I-node routines: found 35810 nodes, limit used
>>>>> is 5
>>>>> > >>      linear system matrix followed by preconditioner matrix:
>>>>> > >>        type: mffd
>>>>> > >>        rows=347149550, cols=347149550
>>>>> > >>          Matrix-free approximation:
>>>>> > >>            err=1.49012e-08 (relative error in function evaluation)
>>>>> > >>            Using wp compute h routine
>>>>> > >>                Does not compute normU
>>>>> > >>        type: mpiaij
>>>>> > >>        rows=347149550, cols=347149550, bs=5
>>>>> > >>        total: nonzeros=86758607500, allocated nonzeros=86758607500
>>>>> > >>          using I-node (on process 0) routines: found 35810 nodes,
>>>>> limit used is 5
>>>>> > >>    type: mffd
>>>>> > >>    type: mpiaij
>>>>> limit used is 5
>>>>> > >>        Line search: Using full step: fnorm 2.025875581923e+03
>>>>> gnorm 2.801672254495e+00
>>>>> > >>    1 SNES Function norm 2.801672254495e+00
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191017/f714aad4/attachment-0001.html>
