[petsc-users] negative grid complexity in GAMG
Mark Adams mfadams at lbl.gov
Wed Oct 16 20:46:56 CDT 2019
The block size refers to the number of dofs/vertex, so you want 5. (I have
no idea what is going on with block size set to 20).
This is better but also smaller. 10 levels is a lot a levels.
This is unsmoothed aggregation. I assume these are advection problems and
smoothed aggregation does not work well. This is not in my wheelhouse. I
think '-pc_gamg_square_graph 20' should reduce the number of levels and
work better for you.
On Wed, Oct 16, 2019 at 8:59 PM Mark Lohry <mlohry at gmail.com> wrote:
> Hi Mark, are you referring to how on the coarser levels the coarsening
> rate seems to nearly flatline? i.e. level 2 has 4,260 rows while level 1
> has 4,240 rows? I was curious about that too...
> Not sure if this is the cause, but I have gone back and forth on what
> blocksize I set; I'm doing high order elements with 5 coupled equations, so
> the true block size in that case is 50x50. For that I had played with
> setting block size to either 5 (number of equations) or 50 (actual block
> size) and seemed to have seen a meager 20% improvement with the block size
> at 5, so I kind of left it there.
> Running a much smaller variant of the same problem at lower order (block
> size 20 instead of 50), the -info grep you asked for is below. I'll get
> -info for the much larger case but it'll take a couple days.
> For options I'm running
> -snes_lag_jacobian 10000 -ksp_gmres_restart 100 -pc_gamg_agg_nsmooths 0
> -mg_levels_ksp_type richardson -mg_levels_pc_type asm -mg_levels_ksp_max_it
> 1
> -pc_mg_cycle_type v -snes_linesearch_type bt -snes_linesearch_order 3
> -snes_linesearch_monitor -mg_levels_sub_pc_factor_in_place true -info
> block size 5 :
> [0] PCSetUp_GAMG(): level 0) N=2006480, n data rows=5, n data cols=5,
> nnz/row (ave)=100, np=16
> [0] PCGAMGFilterGraph(): 100.% nnz after filtering, with threshold 0., 20.
> nnz ave. (N=401296)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
> [0] PCGAMGProlongator_AGG(): New grid 12947 nodes
> [0] PCSetUp_GAMG(): 1) N=64735, n data cols=5, nnz/row (ave)=51, 16 active
> pes
> 10.3351 nnz ave. (N=12947)
> [0] PCGAMGProlongator_AGG(): New grid 2671 nodes
> [0] PCSetUp_GAMG(): 2) N=13355, n data cols=5, nnz/row (ave)=66, 16 active
> pes
> 12.5524 nnz ave. (N=2671)
> [0] PCGAMGProlongator_AGG(): New grid 598 nodes
> [0] PCSetUp_GAMG(): 3) N=2990, n data cols=5, nnz/row (ave)=65, 16 active
> pes
> 12.7727 nnz ave. (N=598)
> [0] PCGAMGProlongator_AGG(): New grid 178 nodes
> [0] PCSetUp_GAMG(): 4) N=890, n data cols=5, nnz/row (ave)=52, 16 active
> pes
> 8.28571 nnz ave. (N=178)
> [0] PCGAMGProlongator_AGG(): New grid 80 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 30 with simple
> aggregation
> [0] PCSetUp_GAMG(): 5) N=400, n data cols=5, nnz/row (ave)=34, 8 active pes
> 5.77778 nnz ave. (N=80)
> [0] PCGAMGProlongator_AGG(): New grid 50 nodes
> aggregation
> [0] PCSetUp_GAMG(): 6) N=250, n data cols=5, nnz/row (ave)=25, 4 active pes
> 4.76923 nnz ave. (N=50)
> [0] PCGAMGProlongator_AGG(): New grid 36 nodes
> [0] PCSetUp_GAMG(): 7) N=180, n data cols=5, nnz/row (ave)=18, 4 active pes
> 3.75 nnz ave. (N=36)
> [0] PCGAMGProlongator_AGG(): New grid 33 nodes
> [0] PCGAMGCreateLevel_GAMG(): Aggregate processors noop: new_size=4,
> neq(loc)=90
> [0] PCSetUp_GAMG(): 8) N=165, n data cols=5, nnz/row (ave)=18, 4 active pes
> 3.72222 nnz ave. (N=33)
> [0] PCGAMGProlongator_AGG(): New grid 8 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 35 with simple
> aggregation
> [0] PCSetUp_GAMG(): 9) N=40, n data cols=5, nnz/row (ave)=15, 1 active pes
> [0] PCSetUp_GAMG(): 10 levels, grid complexity = 1.02237
> block size 20:
> [0] PCSetUp_GAMG(): level 0) N=2006480, n data rows=20, n data cols=20,
> [0] PCGAMGFilterGraph(): 100.% nnz after filtering, with threshold 0., 5.
> nnz ave. (N=100324)
> [0] PCGAMGProlongator_AGG(): New grid 12948 nodes
> [0] PCSetUp_GAMG(): 1) N=258960, n data cols=20, nnz/row (ave)=205, 16
> active pes
> 10.2857 nnz ave. (N=12948)
> [0] PCSetUp_GAMG(): 2) N=53420, n data cols=20, nnz/row (ave)=266, 16
> active pes
> 12.5548 nnz ave. (N=2671)
> [0] PCGAMGProlongator_AGG(): New grid 593 nodes
> [0] PCSetUp_GAMG(): 3) N=11860, n data cols=20, nnz/row (ave)=264, 16
> active pes
> 10.8519 nnz ave. (N=593)
> [0] PCGAMGProlongator_AGG(): New grid 181 nodes
> [0] PCSetUp_GAMG(): 4) N=3620, n data cols=20, nnz/row (ave)=214, 16
> active pes
> 8.375 nnz ave. (N=181)
> [0] PCGAMGProlongator_AGG(): New grid 79 nodes
> [0] PCSetUp_GAMG(): 5) N=1580, n data cols=20, nnz/row (ave)=164, 16
> active pes
> [0] PCGAMGFilterGraph(): 100.% nnz after filtering, with threshold 0., 8.
> nnz ave. (N=79)
> [0] PCGAMGProlongator_AGG(): New grid 43 nodes
> [0] PCSetUp_GAMG(): 6) N=860, n data cols=20, nnz/row (ave)=100, 16 active
> pes
> nnz ave. (N=43)
> [0] PCGAMGProlongator_AGG(): New grid 15 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 20 with simple
> aggregation
> [0] PCSetUp_GAMG(): 7) N=300, n data cols=20, nnz/row (ave)=81, 8 active
> pes
> 2.66667 nnz ave. (N=15)
> [0] PCGAMGProlongator_AGG(): New grid 1 nodes
> [0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 0 with simple
> aggregation
> [0] PCSetUp_GAMG(): 8) N=20, n data cols=20, nnz/row (ave)=20, 1 active pes
> [0] PCSetUp_GAMG(): HARD stop of coarsening on level 7.  Grid too small: 1
> block nodes
> [0] PCSetUp_GAMG(): 9 levels, grid complexity = 1.35745
> On Wed, Oct 16, 2019 at 5:12 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Thanks Barry,
>> Sorry I missed this.
>> Mark: this problem is going crazy. The (default) coarsening parameters
>> are terrible for you. Can run with -info, grep for GAMG and send that? And
>> please send me the gamg parameters that you are using.
>> Thanks,
>> Mark
>> On Wed, Oct 16, 2019 at 9:01 AM Smith, Barry F. via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> barry/2019-10-15/bug-gamg-complexity/maint
>>> https://gitlab.com/petsc/petsc/merge_requests/2179
>>> > On Oct 16, 2019, at 5:29 AM, Mark Lohry <mlohry at gmail.com> wrote:
>>> > Well that was a quick late night bug fix. Thanks Barry, I'll try it
>>> out.
>>> > Just to confirm: You are running with with default double precision
>>> numbers and have used the configure option --with-64-bit-indices ?
>>> > Double precision floats, but 32 bit indices. I realize I'm playing
>>> with fire here, but I'm bumping very close to available memory limits at
>>> this scale and 64 bit indices tips me over. I figure integer index
>>> overflows would probably show a catastrophic failure, but all output looks
>>> sane.
>>> > I see you are using MATMFFD as the operator and MPIAIJ as the matrix
>>> from which to build the preconditioner? This is not suppose to cause any
>>> difficulties since the complexity computation code uses the second matrix,
>>> that is the MPAIJ matrix to get the complexity information.
>>> > Right, I'm using MATMFFD for the operator, and using a
>>> snes_lag_jacobian with SNESComputeJacobianDefaultColor for the matrix used
>>> to build to preconditioner. The actual behavior is exactly what I'd expect
>>> from smaller runs and the results look good, so it sounds like what you
>>> describe.
>>> > On Wed, Oct 16, 2019 at 12:17 AM Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> >    I think I now see the bug: the code uses PetscInt       lev, nnz0 =
>>> -1; which will overflow. It should be using PetscLogDouble for nnz0
>>> >   You can try changing that one place in the code and see that it now
>>> prints a reasonable value for complexity.
>>> >   I will prepare a MR for maint to fix the bug permanently.
>>> >   Barry
>>> > static PetscErrorCode PCMGGetGridComplexity(PC pc, PetscReal *gc)
>>> >   PetscErrorCode ierr;
>>> >   PC_MG          *mg      = (PC_MG*)pc->data;
>>> >   PC_MG_Levels   **mglevels = mg->levels;
>>> >   PetscInt       lev, nnz0 = -1;
>>> >   MatInfo        info;
>>> >   PetscFunctionBegin;
>>> >   if (!mg->nlevels) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_PLIB,"MG has no
>>> levels");
>>> >   for (lev=0, *gc=0; lev<mg->nlevels; lev++) {
>>> >     Mat dB;
>>> >     ierr =
>>> KSPGetOperators(mglevels[lev]->smoothd,NULL,&dB);CHKERRQ(ierr);
>>> >     ierr = MatGetInfo(dB,MAT_GLOBAL_SUM,&info);CHKERRQ(ierr); /*
>>> global reduction */
>>> >     *gc += (PetscReal)info.nz_used;
>>> >     if (lev==mg->nlevels-1) nnz0 = info.nz_used;
>>> >   if (nnz0) *gc /= (PetscReal)nnz0;
>>> >   else *gc = 0;
>>> >   PetscFunctionReturn(0);
>>> > > On Oct 15, 2019, at 11:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> > >   Mark,
>>> > >   It may be caused by some overflow in the calculations somewhere
>>> due to your very large sizes and nonzeros but I could not see anything
>>> based on a quick inspection of the code. We seem to use double to store the
>>> counts which normally would be more than sufficient to hold the results
>>> without overflow. Unless somewhere there is a mistaken use of int that
>>> causes a problem.
>>> precision numbers and have used the configure option --with-64-bit-indices
>>> matrix from which to build the preconditioner? This is not suppose to cause
>>> any difficulties since the complexity computation code uses the second
>>> matrix, that is the MPAIJ matrix to get the complexity information.
>>> > >   There is definitely a bug but I am hard pressed to suggest how to
>>> find it since it seems only to be expressed in your giant runs.
>>> > >  Barry
>>> > >> On Oct 15, 2019, at 9:16 PM, Mark Lohry via petsc-users <
>>> > >> I'm running some larger unsteady problems and trying to eek out
>>> some better GAMG performance. As is, at very small time steps, ASM
>>> preconditioner with ILU(0) is maybe 20% more efficient than my naive GAMG
>>> setup, which gives me hope that some tuning of GAMG can give some
>>> advantage. Convergence overall seems quite good, and light years better
>>> than ASM/ILU at larger time steps.
>>> > >> So looking through the manual and see a note that "grid complexity
>>> should be well under 2.0 and preferably around 1.3 or lower". I check
>>> ksp_view and see:
>>> > >> Complexity:    grid = -40.5483
>>> > >> Is something funny happening here?
>>> > >> Pasting whole -ksp_view below:
>>> > >> KSP Object: 1920 MPI processes
>>> > >>  type: fgmres
>>> > >>    restart=100, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>> > >>    happy breakdown tolerance 1e-30
>>> > >>  maximum iterations=30, initial guess is zero
>>> > >>  tolerances:  relative=0.0001, absolute=1e-06, divergence=10.
>>> > >>  right preconditioning
>>> > >>  using UNPRECONDITIONED norm type for convergence test
>>> > >> PC Object: 1920 MPI processes
>>> > >>  type: gamg
>>> > >>    type is MULTIPLICATIVE, levels=20 cycles=v
>>> > >>      Cycles per PCApply=1
>>> > >>      Using externally compute Galerkin coarse grid matrices
>>> > >>      GAMG specific options
>>> > >>        Threshold for dropping small values in graph on each level
>>> =   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.
>>>  0.   0.   0.   0.
>>> > >>        Threshold scaling factor for each level not specified = 1.
>>> > >>        AGG specific options
>>> > >>          Symmetric graph false
>>> > >>          Number of levels to square graph 1
>>> > >>          Number smoothing steps 0
>>> > >>  Coarse grid solver -- level -------------------------------
>>> > >>    KSP Object: (mg_coarse_) 1920 MPI processes
>>> > >>      type: preonly
>>> > >>      maximum iterations=10000, initial guess is zero
>>> > >>      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>> > >>      left preconditioning
>>> > >>      using NONE norm type for convergence test
>>> > >>    PC Object: (mg_coarse_) 1920 MPI processes
>>> > >>      type: bjacobi
>>> > >>        number of blocks = 1920
>>> > >>        Local solve is same for all blocks, in the following KSP and
>>> PC objects:
>>> > >>      KSP Object: (mg_coarse_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> > >>        maximum iterations=1, initial guess is zero
>>> divergence=10000.
>>> > >>      PC Object: (mg_coarse_sub_) 1 MPI processes
>>> > >>        type: lu
>>> > >>          out-of-place factorization
>>> > >>          tolerance for zero pivot 2.22045e-14
>>> > >>          using diagonal shift on blocks to prevent zero pivot
>>> [INBLOCKS]
>>> > >>          matrix ordering: nd
>>> > >>          factor fill ratio given 5., needed 1.
>>> > >>            Factored matrix follows:
>>> > >>              Mat Object: 1 MPI processes
>>> > >>                type: seqaij
>>> > >>                rows=15, cols=15, bs=5
>>> > >>                package used to perform factorization: petsc
>>> > >>                total: nonzeros=175, allocated nonzeros=175
>>> > >>                total number of mallocs used during MatSetValues
>>> calls =0
>>> > >>                  using I-node routines: found 3 nodes, limit used
>>> is 5
>>> > >>        linear system matrix = precond matrix:
>>> > >>          type: seqaij
>>> > >>          total number of mallocs used during MatSetValues calls =0
>>> > >>            using I-node routines: found 3 nodes, limit used is 5
>>> > >>      Mat Object: 1920 MPI processes
>>> > >>        type: mpiaij
>>> > >>          using I-node (on process 0) routines: found 3 nodes, limit
>>> used is 5
>>> > >>  Down solver (pre-smoother) on level 1
>>> > >>    KSP Object: (mg_levels_1_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>      maximum iterations=1, nonzero initial guess
>>> > >>    PC Object: (mg_levels_1_) 1920 MPI processes
>>> > >>      type: asm
>>> > >>        total subdomain blocks = 1920, amount of overlap = 0
>>> > >>        restriction/interpolation type - RESTRICT
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_1_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_1_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          in-place factorization
>>> > >>          0 levels of fill
>>> > >>          matrix ordering: natural
>>> > >>          factor fill ratio given 0., needed 0.
>>> > >>                type: seqaij
>>> > >>                rows=4240, cols=4240
>>> > >>                total: nonzeros=64800, allocated nonzeros=64800
>>> calls =0
>>> > >>                  using I-node routines: found 848 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 848 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=4240, cols=4240, bs=5
>>> > >>          using nonscalable MatPtAP() implementation
>>> > >>          using I-node (on process 0) routines: found 848 nodes,
>>> limit used is 5
>>> > >>  Up solver (post-smoother) same as down solver (pre-smoother)
>>> > >>  Down solver (pre-smoother) on level 2
>>> > >>    KSP Object: (mg_levels_2_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_2_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_2_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_2_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=4260, cols=4260
>>> > >>                total: nonzeros=65200, allocated nonzeros=65200
>>> calls =0
>>> > >>                  using I-node routines: found 852 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 852 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=4260, cols=4260, bs=5
>>> > >>          using I-node (on process 0) routines: found 852 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 3
>>> > >>    KSP Object: (mg_levels_3_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_3_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_3_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_3_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=5440, cols=5440
>>> > >>                total: nonzeros=90950, allocated nonzeros=90950
>>> calls =0
>>> > >>                  using I-node routines: found 1088 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1088 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=5440, cols=5440, bs=5
>>> > >>          using I-node (on process 0) routines: found 1088 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 4
>>> > >>    KSP Object: (mg_levels_4_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_4_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_4_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_4_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=5485, cols=5485
>>> > >>                total: nonzeros=93075, allocated nonzeros=93075
>>> calls =0
>>> > >>                  using I-node routines: found 1097 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1097 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=5485, cols=5485, bs=5
>>> > >>          using I-node (on process 0) routines: found 1097 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 5
>>> > >>    KSP Object: (mg_levels_5_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_5_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_5_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_5_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=5685, cols=5685
>>> > >>                total: nonzeros=98925, allocated nonzeros=98925
>>> calls =0
>>> > >>                  using I-node routines: found 1137 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1137 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=5685, cols=5685, bs=5
>>> > >>          using I-node (on process 0) routines: found 1137 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 6
>>> > >>    KSP Object: (mg_levels_6_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_6_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_6_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_6_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=5825, cols=5825
>>> > >>                total: nonzeros=102325, allocated nonzeros=102325
>>> calls =0
>>> > >>                  using I-node routines: found 1165 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1165 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=5825, cols=5825, bs=5
>>> > >>          using I-node (on process 0) routines: found 1165 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 7
>>> > >>    KSP Object: (mg_levels_7_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_7_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_7_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_7_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=5925, cols=5925
>>> > >>                total: nonzeros=104925, allocated nonzeros=104925
>>> calls =0
>>> > >>                  using I-node routines: found 1185 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1185 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=5925, cols=5925, bs=5
>>> > >>          using I-node (on process 0) routines: found 1185 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 8
>>> > >>    KSP Object: (mg_levels_8_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_8_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_8_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_8_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=6050, cols=6050
>>> > >>                total: nonzeros=110200, allocated nonzeros=110200
>>> calls =0
>>> > >>                  using I-node routines: found 1210 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1210 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=6050, cols=6050, bs=5
>>> > >>          using I-node (on process 0) routines: found 1210 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 9
>>> > >>    KSP Object: (mg_levels_9_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_9_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_9_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_9_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=6890, cols=6890
>>> > >>                total: nonzeros=153200, allocated nonzeros=153200
>>> calls =0
>>> > >>                  using I-node routines: found 1378 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1378 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=6890, cols=6890, bs=5
>>> > >>          using I-node (on process 0) routines: found 1378 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 10
>>> > >>    KSP Object: (mg_levels_10_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_10_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_10_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_10_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=7395, cols=7395
>>> > >>                total: nonzeros=180025, allocated nonzeros=180025
>>> calls =0
>>> > >>                  using I-node routines: found 1479 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1479 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=7395, cols=7395, bs=5
>>> > >>          using I-node (on process 0) routines: found 1479 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 11
>>> > >>    KSP Object: (mg_levels_11_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_11_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_11_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_11_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=8960, cols=8960
>>> > >>                total: nonzeros=259800, allocated nonzeros=259800
>>> calls =0
>>> > >>                  using I-node routines: found 1792 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 1792 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=8960, cols=8960, bs=5
>>> > >>          using I-node (on process 0) routines: found 1792 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 12
>>> > >>    KSP Object: (mg_levels_12_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_12_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_12_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_12_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=1795, cols=1795
>>> > >>                total: nonzeros=33275, allocated nonzeros=33275
>>> calls =0
>>> > >>                  using I-node routines: found 359 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 359 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=11825, cols=11825, bs=5
>>> > >>        total: nonzeros=403125, allocated nonzeros=403125
>>> > >>          using I-node (on process 0) routines: found 359 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 13
>>> > >>    KSP Object: (mg_levels_13_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_13_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_13_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_13_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=340, cols=340
>>> > >>                total: nonzeros=3500, allocated nonzeros=3500
>>> calls =0
>>> > >>                  using I-node routines: found 68 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>          rows=340, cols=340
>>> > >>            using I-node routines: found 68 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=17210, cols=17210, bs=5
>>> > >>        total: nonzeros=696850, allocated nonzeros=696850
>>> > >>          using I-node (on process 0) routines: found 68 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 14
>>> > >>    KSP Object: (mg_levels_14_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_14_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_14_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_14_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=125, cols=125
>>> > >>                total: nonzeros=625, allocated nonzeros=625
>>> calls =0
>>> > >>                  using I-node routines: found 25 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>          rows=125, cols=125
>>> > >>            using I-node routines: found 25 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=29055, cols=29055, bs=5
>>> > >>        total: nonzeros=1475675, allocated nonzeros=1475675
>>> > >>          using I-node (on process 0) routines: found 25 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 15
>>> > >>    KSP Object: (mg_levels_15_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_15_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_15_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_15_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=45, cols=45
>>> > >>                total: nonzeros=225, allocated nonzeros=225
>>> calls =0
>>> > >>                  using I-node routines: found 9 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>          rows=45, cols=45
>>> > >>            using I-node routines: found 9 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=62935, cols=62935, bs=5
>>> > >>        total: nonzeros=3939025, allocated nonzeros=3939025
>>> > >>          using I-node (on process 0) routines: found 9 nodes, limit
>>> used is 5
>>> > >>  Down solver (pre-smoother) on level 16
>>> > >>    KSP Object: (mg_levels_16_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_16_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_16_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_16_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=55, cols=55
>>> > >>                total: nonzeros=725, allocated nonzeros=725
>>> calls =0
>>> > >>                  using I-node routines: found 11 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>          rows=55, cols=55
>>> > >>            using I-node routines: found 11 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=205010, cols=205010, bs=5
>>> > >>        total: nonzeros=14780300, allocated nonzeros=14780300
>>> > >>          using scalable MatPtAP() implementation
>>> > >>          using I-node (on process 0) routines: found 11 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 17
>>> > >>    KSP Object: (mg_levels_17_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_17_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_17_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_17_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=360, cols=360
>>> > >>                total: nonzeros=14350, allocated nonzeros=14350
>>> calls =0
>>> > >>                  using I-node routines: found 72 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>          rows=360, cols=360
>>> > >>            using I-node routines: found 72 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=921310, cols=921310, bs=5
>>> > >>        total: nonzeros=63203300, allocated nonzeros=63203300
>>> > >>          using I-node (on process 0) routines: found 72 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 18
>>> > >>    KSP Object: (mg_levels_18_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_18_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_18_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_18_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=2130, cols=2130
>>> > >>                total: nonzeros=87950, allocated nonzeros=87950
>>> calls =0
>>> > >>                  using I-node routines: found 426 nodes, limit used
>>> is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 426 nodes, limit used is 5
>>> > >>        type: mpiaij
>>> > >>        rows=4473930, cols=4473930, bs=5
>>> > >>        total: nonzeros=232427300, allocated nonzeros=232427300
>>> > >>          using I-node (on process 0) routines: found 426 nodes,
>>> limit used is 5
>>> > >>  Down solver (pre-smoother) on level 19
>>> > >>    KSP Object: (mg_levels_19_) 1920 MPI processes
>>> > >>      type: richardson
>>> > >>        damping factor=1.
>>> > >>    PC Object: (mg_levels_19_) 1920 MPI processes
>>> > >>      type: asm
>>> PC objects:
>>> > >>      KSP Object: (mg_levels_19_sub_) 1 MPI processes
>>> > >>        type: preonly
>>> divergence=10000.
>>> > >>      PC Object: (mg_levels_19_sub_) 1 MPI processes
>>> > >>        type: ilu
>>> > >>          0 levels of fill
>>> > >>                type: seqaij
>>> > >>                rows=179050, cols=179050
>>> > >>                total: nonzeros=42562500, allocated nonzeros=42562500
>>> calls =0
>>> > >>                  using I-node routines: found 35810 nodes, limit
>>> used is 5
>>> > >>          type: seqaij
>>> > >>            using I-node routines: found 35810 nodes, limit used is 5
>>> > >>      linear system matrix followed by preconditioner matrix:
>>> > >>        type: mffd
>>> > >>        rows=347149550, cols=347149550
>>> > >>          Matrix-free approximation:
>>> > >>            err=1.49012e-08 (relative error in function evaluation)
>>> > >>            Using wp compute h routine
>>> > >>                Does not compute normU
>>> > >>        type: mpiaij
>>> > >>        rows=347149550, cols=347149550, bs=5
>>> > >>        total: nonzeros=86758607500, allocated nonzeros=86758607500
>>> > >>          using I-node (on process 0) routines: found 35810 nodes,
>>> limit used is 5
>>> > >>    type: mffd
>>> > >>    type: mpiaij
>>> > >>      using I-node (on process 0) routines: found 35810 nodes, limit
>>> used is 5
>>> > >>        Line search: Using full step: fnorm 2.025875581923e+03 gnorm
>>> 2.801672254495e+00
>>> > >>    1 SNES Function norm 2.801672254495e+00
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191016/c41e247b/attachment-0001.html>
