[petsc-users] negative grid complexity in GAMG
Mark Adams mfadams at lbl.gov
Wed Oct 16 16:12:57 CDT 2019
Thanks Barry,
Sorry I missed this.
Mark: this problem is going crazy. The (default) coarsening parameters are
terrible for you. Can run with -info, grep for GAMG and send that? And
please send me the gamg parameters that you are using.
On Wed, Oct 16, 2019 at 9:01 AM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> barry/2019-10-15/bug-gamg-complexity/maint
> https://gitlab.com/petsc/petsc/merge_requests/2179
> > On Oct 16, 2019, at 5:29 AM, Mark Lohry <mlohry at gmail.com> wrote:
> > Well that was a quick late night bug fix. Thanks Barry, I'll try it out.
> > Just to confirm: You are running with with default double precision
> numbers and have used the configure option --with-64-bit-indices ?
> > Double precision floats, but 32 bit indices. I realize I'm playing with
> fire here, but I'm bumping very close to available memory limits at this
> scale and 64 bit indices tips me over. I figure integer index overflows
> would probably show a catastrophic failure, but all output looks sane.
> > I see you are using MATMFFD as the operator and MPIAIJ as the matrix
> from which to build the preconditioner? This is not suppose to cause any
> difficulties since the complexity computation code uses the second matrix,
> that is the MPAIJ matrix to get the complexity information.
> > Right, I'm using MATMFFD for the operator, and using a snes_lag_jacobian
> with SNESComputeJacobianDefaultColor for the matrix used to build to
> preconditioner. The actual behavior is exactly what I'd expect from smaller
> runs and the results look good, so it sounds like what you describe.
> > On Wed, Oct 16, 2019 at 12:17 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >    I think I now see the bug: the code uses PetscInt       lev, nnz0 =
> -1; which will overflow. It should be using PetscLogDouble for nnz0
> >   You can try changing that one place in the code and see that it now
> prints a reasonable value for complexity.
> >   I will prepare a MR for maint to fix the bug permanently.
> >   Barry
> > static PetscErrorCode PCMGGetGridComplexity(PC pc, PetscReal *gc)
> >   PetscErrorCode ierr;
> >   PC_MG          *mg      = (PC_MG*)pc->data;
> >   PC_MG_Levels   **mglevels = mg->levels;
> >   PetscInt       lev, nnz0 = -1;
> >   MatInfo        info;
> >   PetscFunctionBegin;
> >   if (!mg->nlevels) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_PLIB,"MG has no
> levels");
> >   for (lev=0, *gc=0; lev<mg->nlevels; lev++) {
> >     Mat dB;
> >     ierr =
> KSPGetOperators(mglevels[lev]->smoothd,NULL,&dB);CHKERRQ(ierr);
> >     ierr = MatGetInfo(dB,MAT_GLOBAL_SUM,&info);CHKERRQ(ierr); /* global
> reduction */
> >     *gc += (PetscReal)info.nz_used;
> >     if (lev==mg->nlevels-1) nnz0 = info.nz_used;
> >   if (nnz0) *gc /= (PetscReal)nnz0;
> >   else *gc = 0;
> >   PetscFunctionReturn(0);
> > > On Oct 15, 2019, at 11:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > >   Mark,
> > >   It may be caused by some overflow in the calculations somewhere due
> to your very large sizes and nonzeros but I could not see anything based on
> a quick inspection of the code. We seem to use double to store the counts
> which normally would be more than sufficient to hold the results without
> overflow. Unless somewhere there is a mistaken use of int that causes a
> problem.
> > >   There is definitely a bug but I am hard pressed to suggest how to
> find it since it seems only to be expressed in your giant runs.
> > >  Barry
> > >> On Oct 15, 2019, at 9:16 PM, Mark Lohry via petsc-users <
> > >> I'm running some larger unsteady problems and trying to eek out some
> better GAMG performance. As is, at very small time steps, ASM
> preconditioner with ILU(0) is maybe 20% more efficient than my naive GAMG
> setup, which gives me hope that some tuning of GAMG can give some
> advantage. Convergence overall seems quite good, and light years better
> than ASM/ILU at larger time steps.
> > >> So looking through the manual and see a note that "grid complexity
> should be well under 2.0 and preferably around 1.3 or lower". I check
> ksp_view and see:
> > >> Complexity:    grid = -40.5483
> > >> Is something funny happening here?
> > >> Pasting whole -ksp_view below:
> > >> KSP Object: 1920 MPI processes
> > >>  type: fgmres
> > >>    restart=100, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> > >>    happy breakdown tolerance 1e-30
> > >>  maximum iterations=30, initial guess is zero
> > >>  tolerances:  relative=0.0001, absolute=1e-06, divergence=10.
> > >>  right preconditioning
> > >>  using UNPRECONDITIONED norm type for convergence test
> > >> PC Object: 1920 MPI processes
> > >>  type: gamg
> > >>    type is MULTIPLICATIVE, levels=20 cycles=v
> > >>      Cycles per PCApply=1
> > >>      Using externally compute Galerkin coarse grid matrices
> > >>      GAMG specific options
> > >>        Threshold for dropping small values in graph on each level =
>  0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.
>  0.   0.   0.
> > >>        Threshold scaling factor for each level not specified = 1.
> > >>        AGG specific options
> > >>          Symmetric graph false
> > >>          Number of levels to square graph 1
> > >>          Number smoothing steps 0
> > >>  Coarse grid solver -- level -------------------------------
> > >>    KSP Object: (mg_coarse_) 1920 MPI processes
> > >>      type: preonly
> > >>      maximum iterations=10000, initial guess is zero
> > >>      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> > >>      left preconditioning
> > >>      using NONE norm type for convergence test
> > >>    PC Object: (mg_coarse_) 1920 MPI processes
> > >>      type: bjacobi
> > >>        number of blocks = 1920
> > >>        Local solve is same for all blocks, in the following KSP and
> PC objects:
> > >>      KSP Object: (mg_coarse_sub_) 1 MPI processes
> > >>        type: preonly
> > >>        maximum iterations=1, initial guess is zero
> > >>      PC Object: (mg_coarse_sub_) 1 MPI processes
> > >>        type: lu
> > >>          out-of-place factorization
> > >>          tolerance for zero pivot 2.22045e-14
> > >>          using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
> > >>          matrix ordering: nd
> > >>          factor fill ratio given 5., needed 1.
> > >>            Factored matrix follows:
> > >>              Mat Object: 1 MPI processes
> > >>                type: seqaij
> > >>                rows=15, cols=15, bs=5
> > >>                package used to perform factorization: petsc
> > >>                total: nonzeros=175, allocated nonzeros=175
> > >>                total number of mallocs used during MatSetValues calls
> =0
> > >>                  using I-node routines: found 3 nodes, limit used is 5
> > >>        linear system matrix = precond matrix:
> > >>          type: seqaij
> > >>          total number of mallocs used during MatSetValues calls =0
> > >>      Mat Object: 1920 MPI processes
> > >>        type: mpiaij
> > >>          using I-node (on process 0) routines: found 3 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 1 -------------------------------
> > >>    KSP Object: (mg_levels_1_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>      maximum iterations=1, nonzero initial guess
> > >>    PC Object: (mg_levels_1_) 1920 MPI processes
> > >>      type: asm
> > >>        total subdomain blocks = 1920, amount of overlap = 0
> > >>        restriction/interpolation type - RESTRICT
> PC objects:
> > >>      KSP Object: (mg_levels_1_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_1_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          in-place factorization
> > >>          0 levels of fill
> > >>          matrix ordering: natural
> > >>          factor fill ratio given 0., needed 0.
> > >>                type: seqaij
> > >>                rows=4240, cols=4240
> > >>                total: nonzeros=64800, allocated nonzeros=64800
> =0
> > >>                  using I-node routines: found 848 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 848 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=4240, cols=4240, bs=5
> > >>          using nonscalable MatPtAP() implementation
> > >>          using I-node (on process 0) routines: found 848 nodes, limit
> used is 5
> > >>  Up solver (post-smoother) same as down solver (pre-smoother)
> > >>  Down solver (pre-smoother) on level 2 -------------------------------
> > >>    KSP Object: (mg_levels_2_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_2_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_2_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_2_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=4260, cols=4260
> > >>                total: nonzeros=65200, allocated nonzeros=65200
> =0
> > >>                  using I-node routines: found 852 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 852 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=4260, cols=4260, bs=5
> > >>          using I-node (on process 0) routines: found 852 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 3 -------------------------------
> > >>    KSP Object: (mg_levels_3_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_3_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_3_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_3_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=5440, cols=5440
> > >>                total: nonzeros=90950, allocated nonzeros=90950
> =0
> > >>                  using I-node routines: found 1088 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1088 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=5440, cols=5440, bs=5
> > >>          using I-node (on process 0) routines: found 1088 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 4 -------------------------------
> > >>    KSP Object: (mg_levels_4_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_4_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_4_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_4_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=5485, cols=5485
> > >>                total: nonzeros=93075, allocated nonzeros=93075
> =0
> > >>                  using I-node routines: found 1097 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1097 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=5485, cols=5485, bs=5
> > >>          using I-node (on process 0) routines: found 1097 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 5 -------------------------------
> > >>    KSP Object: (mg_levels_5_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_5_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_5_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_5_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=5685, cols=5685
> > >>                total: nonzeros=98925, allocated nonzeros=98925
> =0
> > >>                  using I-node routines: found 1137 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1137 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=5685, cols=5685, bs=5
> > >>          using I-node (on process 0) routines: found 1137 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 6 -------------------------------
> > >>    KSP Object: (mg_levels_6_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_6_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_6_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_6_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=5825, cols=5825
> > >>                total: nonzeros=102325, allocated nonzeros=102325
> =0
> > >>                  using I-node routines: found 1165 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1165 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=5825, cols=5825, bs=5
> > >>          using I-node (on process 0) routines: found 1165 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 7 -------------------------------
> > >>    KSP Object: (mg_levels_7_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_7_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_7_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_7_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=5925, cols=5925
> > >>                total: nonzeros=104925, allocated nonzeros=104925
> =0
> > >>                  using I-node routines: found 1185 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1185 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=5925, cols=5925, bs=5
> > >>          using I-node (on process 0) routines: found 1185 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 8 -------------------------------
> > >>    KSP Object: (mg_levels_8_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_8_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_8_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_8_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=6050, cols=6050
> > >>                total: nonzeros=110200, allocated nonzeros=110200
> =0
> > >>                  using I-node routines: found 1210 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1210 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=6050, cols=6050, bs=5
> > >>          using I-node (on process 0) routines: found 1210 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 9 -------------------------------
> > >>    KSP Object: (mg_levels_9_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_9_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_9_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_9_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=6890, cols=6890
> > >>                total: nonzeros=153200, allocated nonzeros=153200
> =0
> > >>                  using I-node routines: found 1378 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1378 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=6890, cols=6890, bs=5
> > >>          using I-node (on process 0) routines: found 1378 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 10
> > >>    KSP Object: (mg_levels_10_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_10_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_10_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_10_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=7395, cols=7395
> > >>                total: nonzeros=180025, allocated nonzeros=180025
> =0
> > >>                  using I-node routines: found 1479 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1479 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=7395, cols=7395, bs=5
> > >>          using I-node (on process 0) routines: found 1479 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 11
> > >>    KSP Object: (mg_levels_11_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_11_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_11_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_11_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=8960, cols=8960
> > >>                total: nonzeros=259800, allocated nonzeros=259800
> =0
> > >>                  using I-node routines: found 1792 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 1792 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=8960, cols=8960, bs=5
> > >>          using I-node (on process 0) routines: found 1792 nodes,
> limit used is 5
> > >>  Down solver (pre-smoother) on level 12
> > >>    KSP Object: (mg_levels_12_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_12_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_12_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_12_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=1795, cols=1795
> > >>                total: nonzeros=33275, allocated nonzeros=33275
> =0
> > >>                  using I-node routines: found 359 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 359 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=11825, cols=11825, bs=5
> > >>        total: nonzeros=403125, allocated nonzeros=403125
> > >>          using I-node (on process 0) routines: found 359 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 13
> > >>    KSP Object: (mg_levels_13_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_13_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_13_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_13_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=340, cols=340
> > >>                total: nonzeros=3500, allocated nonzeros=3500
> =0
> > >>                  using I-node routines: found 68 nodes, limit used is
> 5
> > >>          type: seqaij
> > >>          rows=340, cols=340
> > >>            using I-node routines: found 68 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=17210, cols=17210, bs=5
> > >>        total: nonzeros=696850, allocated nonzeros=696850
> > >>          using I-node (on process 0) routines: found 68 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 14
> > >>    KSP Object: (mg_levels_14_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_14_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_14_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_14_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=125, cols=125
> > >>                total: nonzeros=625, allocated nonzeros=625
> =0
> > >>                  using I-node routines: found 25 nodes, limit used is
> 5
> > >>          type: seqaij
> > >>          rows=125, cols=125
> > >>            using I-node routines: found 25 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=29055, cols=29055, bs=5
> > >>        total: nonzeros=1475675, allocated nonzeros=1475675
> > >>          using I-node (on process 0) routines: found 25 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 15
> > >>    KSP Object: (mg_levels_15_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_15_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_15_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_15_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=45, cols=45
> > >>                total: nonzeros=225, allocated nonzeros=225
> =0
> > >>                  using I-node routines: found 9 nodes, limit used is 5
> > >>          type: seqaij
> > >>          rows=45, cols=45
> > >>        type: mpiaij
> > >>        rows=62935, cols=62935, bs=5
> > >>        total: nonzeros=3939025, allocated nonzeros=3939025
> > >>          using I-node (on process 0) routines: found 9 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 16
> > >>    KSP Object: (mg_levels_16_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_16_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_16_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_16_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=55, cols=55
> > >>                total: nonzeros=725, allocated nonzeros=725
> =0
> > >>                  using I-node routines: found 11 nodes, limit used is
> 5
> > >>          type: seqaij
> > >>          rows=55, cols=55
> > >>            using I-node routines: found 11 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=205010, cols=205010, bs=5
> > >>        total: nonzeros=14780300, allocated nonzeros=14780300
> > >>          using scalable MatPtAP() implementation
> > >>          using I-node (on process 0) routines: found 11 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 17
> > >>    KSP Object: (mg_levels_17_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_17_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_17_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_17_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=360, cols=360
> > >>                total: nonzeros=14350, allocated nonzeros=14350
> =0
> > >>                  using I-node routines: found 72 nodes, limit used is
> 5
> > >>          type: seqaij
> > >>          rows=360, cols=360
> > >>            using I-node routines: found 72 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=921310, cols=921310, bs=5
> > >>        total: nonzeros=63203300, allocated nonzeros=63203300
> > >>          using I-node (on process 0) routines: found 72 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 18
> > >>    KSP Object: (mg_levels_18_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_18_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_18_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_18_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=2130, cols=2130
> > >>                total: nonzeros=87950, allocated nonzeros=87950
> =0
> > >>                  using I-node routines: found 426 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 426 nodes, limit used is 5
> > >>        type: mpiaij
> > >>        rows=4473930, cols=4473930, bs=5
> > >>        total: nonzeros=232427300, allocated nonzeros=232427300
> > >>          using I-node (on process 0) routines: found 426 nodes, limit
> used is 5
> > >>  Down solver (pre-smoother) on level 19
> > >>    KSP Object: (mg_levels_19_) 1920 MPI processes
> > >>      type: richardson
> > >>        damping factor=1.
> > >>    PC Object: (mg_levels_19_) 1920 MPI processes
> > >>      type: asm
> PC objects:
> > >>      KSP Object: (mg_levels_19_sub_) 1 MPI processes
> > >>        type: preonly
> > >>      PC Object: (mg_levels_19_sub_) 1 MPI processes
> > >>        type: ilu
> > >>          0 levels of fill
> > >>                type: seqaij
> > >>                rows=179050, cols=179050
> > >>                total: nonzeros=42562500, allocated nonzeros=42562500
> =0
> > >>                  using I-node routines: found 35810 nodes, limit used
> is 5
> > >>          type: seqaij
> > >>            using I-node routines: found 35810 nodes, limit used is 5
> > >>      linear system matrix followed by preconditioner matrix:
> > >>        type: mffd
> > >>        rows=347149550, cols=347149550
> > >>          Matrix-free approximation:
> > >>            err=1.49012e-08 (relative error in function evaluation)
> > >>            Using wp compute h routine
> > >>                Does not compute normU
> > >>        type: mpiaij
> > >>        rows=347149550, cols=347149550, bs=5
> > >>        total: nonzeros=86758607500, allocated nonzeros=86758607500
> > >>          using I-node (on process 0) routines: found 35810 nodes,
> limit used is 5
> > >>    type: mffd
> > >>    type: mpiaij
> > >>      using I-node (on process 0) routines: found 35810 nodes, limit
> used is 5
> > >>        Line search: Using full step: fnorm 2.025875581923e+03 gnorm
> 2.801672254495e+00
> > >>    1 SNES Function norm 2.801672254495e+00
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191016/e9aced35/attachment-0001.html>
