[petsc-users] Changing nonzero structure and Jacobian coloring
Matthew Knepley
knepley at gmail.com
Wed Oct 16 09:06:41 CDT 2019
On Wed, Oct 16, 2019 at 9:32 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> What Ellen wants to do seems exactly the same use case as required by
> dynamic AMR.
> Some thoughts:
> * If the target problem is nonlinear, then you will need to evaluate the
> Jacobian more than once (with the same nonzero pattern) per time step. You
> would also have to solve a linear problem at each Newton iterate.
> Collectively I think both tasks will consume much more time than that
> required to create a new matrix and determine / set the nonzero pattern
> (which is only required once per time step).
> * If you are using an incompressible SPH method (e.g. you use a kernel
> with a constant compact support) then you will have code which allows you
> to efficiently determine which particles interact, e.g. via a background
> cell structure, thus you have a means to infer the the nonzero structure.
> However computing the off-diagonal counts can be a pain...
> * Going further, provided you have a unique id assigned to each particle,
> you can use MatPreallocator (
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatPreallocatorPreallocate.html)
> to easily define the exact nonzero pattern.
> Given all the above, I don’t see why you shouldn’t try your idea of
> creating a new matrix at each step and assembling the Jacobian.
> Why not just try using MatPreallocator and profile the time required to
> define the nonzero structure?
> I like Barry’s idea of defining the preconditioner for the Jacobian using
> an operator defined via kernels with smaller compact support. I’d be
> interested to know how effective that is as a preconditioner.
> There is potentially a larger issue to consider (if your application runs
> in parallel). Whilst the number of particles is constant in time, the
> number of particles per MPI rank will likely change as particles advect
> (I'm assuming you decomposed the problem using the background search cell
> grid and do not load balance the particles which is a commonly done with
> incompressible SPH implementations). As a result, the local size of the Vec
> object which stores the solution will change between time steps. Vec cannot
> be re-sized, hence you will not only need to change the nonzero structure
> of the Jacobian but you will also need to destroy/create all Vec's objects
> and all objects associated with the nonlinear solve. Given this, I'm not
> even sure you can use TS for your use case (hopefully a TS expert will
> comment on this).
> My experience has been that creating new objects (Vec, Mat, KSP, SNES) in
> PETSc is fast (compared to a linear solve). You might have to give up on
> using TS, and instead roll your own time integrator. By doing this you will
> have control of only a SNES object (plus Mat's for J Vec's for the residual
> and solution) which you can create and destroy within each time step. To
> use FD coloring you would need to provide this function
> SNESComputeJacobianDefaultColor to SNESComputeJacobian(), along with a
> preallocated matrix (which you define using MatPreallocator).
If rolling your own TS would work, then TSStep() will definitely work, and
saves a lot of coding for multistep methods.
Matt
> Thanks
> Dave
> Dave
> On Wed 16. Oct 2019 at 13:25, Matthew Knepley via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> On Tue, Oct 15, 2019 at 4:56 PM Smith, Barry F. via petsc-users <
>>> Because of the difficulty of maintaining a nonzero matrix for such
>>> problems aren't these problems often done "matrix-free"?
>>> So you provide a routine that computes the action of the operator but
>>> doesn't form the operator explicitly (and you hope that you don't need a
>>> preconditioner). There are simple ways (but less optimal) to do this as
>>> well as more sophisticated (such as multipole methods).
>>> If the convergence of the linear solver is too slow (due to lack of
>>> preconditioner) you might consider continuing with matrix free but at each
>>> new Newton solve (or several Newton solves) construct a very sparse matrix
>>> that captures just the very local coupling in the problem. Once particles
>>> have moved around a bit you would throw away the old matrix and construct a
>>> new one. For example the matrix might just captures interactions between
>>> particles that are less than some radius away from themselves. You could
>>> use a direct solver or iterative solver to solve this very sparse system.
>> I tried to do this with Dan Negrut many years ago and had the same
>> problems. That is part of why incompressible SPH never works,
>> since you need global modes.
>> Thanks,
>> Matt
>>> Barry
>>> This is why KSPSetOperators and SNESSetJacobian and TSSetRHS/IJacobain
>>> take two Jacobian matrices, the first holds the matrix free Jacobian and
>>> the second holds the approximation used inside the preconditioner.
>>> > On Oct 15, 2019, at 3:29 PM, Ellen M. Price <
>>> ellen.price at cfa.harvard.edu> wrote:
>>> > Thanks for the reply, Barry! Unfortunately, this is a particle code
>>> > (SPH, specifically), so the particle neighbors, which influence the
>>> > properties, change over time; the degrees of freedom is a constant, as
>>> > is the particle number. Any thoughts, given the new info? Or should I
>>> > stick with explicit integration? I've seen explicit used most commonly,
>>> > but, as I mentioned before, the optimal timestep that gives the error
>>> > bounds I need is just too small for my application, and the only other
>>> > thing I can think to try is to throw a lot more cores at the problem
>>> and
>>> > wait.
>>> > Ellen
>>> > On 10/15/19 4:14 PM, Smith, Barry F. wrote:
>>> >> So you have a fixed "mesh" and fixed number of degrees of freedom
>>> for the entire time but the dependency on the function value at each
>>> particular point on the neighbor points changes over time?
>>> >> For example, if you are doing upwinding and the direction changes
>>> when you used to use values from the right you now use values from the left?
>>> >> Independent of the coloring, just changing the locations in the
>>> matrix where the entries are nonzero is expensive and painful. So what I
>>> would do is build the initial Jacobian nonzero structure to contain all
>>> possible connections, color that and then use that for the entire
>>> computation. At each time step you will be working with some zero entries
>>> in the Jacobian but that is ok, it is simpler and ultimately probably
>>> faster than trying to keep changing the nonzero structure to "optimize" and
>>> only treat truly nonzero values.
>>> >> For "stencil" type discretizations (finite difference, finite
>>> value) what I describe should be fine. But if you problem is completely
>>> different (I can't imagine how) and the Jacobian changes truly dramatically
>>> in structure then what I suggest may not be appropriate but you'll need to
>>> tell us your problem in that case so we can make suggestions.
>>> >> Barry
>>> >>> On Oct 15, 2019, at 2:56 PM, Ellen M. Price via petsc-users <
>>> >>> Hi PETSc users!
>>> >>> I have a problem that I am integrating with TS, and I think an
>>> implicit
>>> >>> method would let me take larger timesteps. The Jacobian is difficult
>>> to
>>> >>> compute, but, more importantly, the nonzero structure is changing
>>> with
>>> >>> time, so even if I use coloring and finite differences to compute the
>>> >>> actual values, I will have to update the coloring every time the
>>> >>> Jacobian recomputes.
>>> >>> Has anyone done this before, and/or is there a correct way to tell
>>> TS to
>>> >>> re-compute the coloring of the matrix before SNES actually computes
>>> the
>>> >>> entries? Is this even a good idea, or is the coloring so expensive
>>> that
>>> >>> this is foolish (in general -- I know the answer depends on the
>>> problem,
>>> >>> but there may be a rule of thumb)?
>>> >>> Thanks,
>>> >>> Ellen Price
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191016/ba5ba43e/attachment-0001.html>
