[petsc-users] Changing nonzero structure and Jacobian coloring
Wed Oct 16 07:23:41 CDT 2019
On Tue, Oct 15, 2019 at 4:56 PM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>   Because of the difficulty of maintaining a nonzero matrix for such
> problems aren't these problems often done "matrix-free"?
>   So you provide a routine that computes the action of the operator but
> doesn't form the operator explicitly (and you hope that you don't need a
> preconditioner). There are simple ways (but less optimal) to do this as
> well as more sophisticated (such as multipole methods).
>   If the convergence of the linear solver is too slow (due to lack of
> preconditioner) you might consider continuing with matrix free but at each
> new Newton solve (or several Newton solves) construct a very sparse matrix
> that captures just the very local coupling in the problem. Once particles
> have moved around a bit you would throw away the old matrix and construct a
> new one. For example the matrix might just captures interactions between
> particles that are less than some radius away from themselves. You could
> use a direct solver or iterative solver to solve this very sparse system.
I tried to do this with Dan Negrut many years ago and had the same
problems. That is part of why incompressible SPH never works,
since you need global modes.
     Matt
>   Barry
> This is why KSPSetOperators and SNESSetJacobian and TSSetRHS/IJacobain
> take two Jacobian matrices, the first holds the matrix free Jacobian and
> the second holds the approximation used inside the preconditioner.
> > On Oct 15, 2019, at 3:29 PM, Ellen M. Price <ellen.price at cfa.harvard.edu>
> wrote:
> > Thanks for the reply, Barry! Unfortunately, this is a particle code
> > (SPH, specifically), so the particle neighbors, which influence the
> > properties, change over time; the degrees of freedom is a constant, as
> > is the particle number. Any thoughts, given the new info? Or should I
> > stick with explicit integration? I've seen explicit used most commonly,
> > but, as I mentioned before, the optimal timestep that gives the error
> > bounds I need is just too small for my application, and the only other
> > thing I can think to try is to throw a lot more cores at the problem and
> > wait.
> > Ellen
> > On 10/15/19 4:14 PM, Smith, Barry F. wrote:
> >>  So you have a fixed "mesh" and fixed number of degrees of freedom for
> the entire time but the dependency on the function value at each particular
> point on the neighbor points changes over time?
> >>  For example, if you are doing upwinding and the direction changes when
> you used to use values from the right you now use values from the left?
> >>   Independent of the coloring, just changing the locations in the
> matrix where the entries are nonzero is expensive and painful. So what I
> would do is build the initial Jacobian nonzero structure to contain all
> possible connections, color that and then use that for the entire
> computation. At each time step you will be working with some zero entries
> in the Jacobian but that is ok, it is simpler and ultimately probably
> faster than trying to keep changing the nonzero structure to "optimize" and
> only treat truly nonzero values.
> >>   For "stencil" type discretizations (finite difference, finite value)
> what I describe should be fine. But if you problem is completely different
> (I can't imagine how) and the Jacobian changes truly dramatically in
> structure then what I suggest may not be appropriate but you'll need to
> tell us your problem in that case so we can make suggestions.
> >>   Barry
> >>> On Oct 15, 2019, at 2:56 PM, Ellen M. Price via petsc-users <
> >>> Hi PETSc users!
> >>> I have a problem that I am integrating with TS, and I think an implicit
> >>> method would let me take larger timesteps. The Jacobian is difficult to
> >>> compute, but, more importantly, the nonzero structure is changing with
> >>> time, so even if I use coloring and finite differences to compute the
> >>> actual values, I will have to update the coloring every time the
> >>> Jacobian recomputes.
> >>> Has anyone done this before, and/or is there a correct way to tell TS
> to
> >>> re-compute the coloring of the matrix before SNES actually computes the
> >>> entries? Is this even a good idea, or is the coloring so expensive that
> >>> this is foolish (in general -- I know the answer depends on the
> problem,
> >>> but there may be a rule of thumb)?
> >>> Thanks,
> >>> Ellen Price
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191016/7b9f4f04/attachment.html>
