[petsc-users] negative grid complexity in GAMG
Mark Lohry mlohry at gmail.com
Tue Oct 15 21:16:57 CDT 2019
I'm running some larger unsteady problems and trying to eek out some better
GAMG performance. As is, at very small time steps, ASM preconditioner with
ILU(0) is maybe 20% more efficient than my naive GAMG setup, which gives me
hope that some tuning of GAMG can give some advantage. Convergence overall
seems quite good, and light years better than ASM/ILU at larger time steps.
So looking through the manual and see a note that "grid complexity should
be well under 2.0 and preferably around 1.3 or lower". I check ksp_view and
see:
Complexity:    grid = -40.5483
Is something funny happening here?
Pasting whole -ksp_view below:
KSP Object: 1920 MPI processes
  type: fgmres
    restart=100, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=30, initial guess is zero
  tolerances:  relative=0.0001, absolute=1e-06, divergence=10.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1920 MPI processes
  type: gamg
    type is MULTIPLICATIVE, levels=20 cycles=v
      Cycles per PCApply=1
      Using externally compute Galerkin coarse grid matrices
      GAMG specific options
        Threshold for dropping small values in graph on each level =   0.
0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.   0.
0.   0.
        Threshold scaling factor for each level not specified = 1.
        AGG specific options
          Symmetric graph false
          Number of levels to square graph 1
          Number smoothing steps 0
  Coarse grid solver -- level -------------------------------
    KSP Object: (mg_coarse_) 1920 MPI processes
      type: preonly
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      left preconditioning
      using NONE norm type for convergence test
    PC Object: (mg_coarse_) 1920 MPI processes
      type: bjacobi
        number of blocks = 1920
        Local solve is same for all blocks, in the following KSP and PC
objects:
      KSP Object: (mg_coarse_sub_) 1 MPI processes
        type: preonly
        maximum iterations=1, initial guess is zero
      PC Object: (mg_coarse_sub_) 1 MPI processes
        type: lu
          out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
          matrix ordering: nd
          factor fill ratio given 5., needed 1.
            Factored matrix follows:
              Mat Object: 1 MPI processes
                type: seqaij
                rows=15, cols=15, bs=5
                package used to perform factorization: petsc
                total: nonzeros=175, allocated nonzeros=175
                total number of mallocs used during MatSetValues calls =0
                  using I-node routines: found 3 nodes, limit used is 5
        linear system matrix = precond matrix:
          type: seqaij
      Mat Object: 1920 MPI processes
        type: mpiaij
          using I-node (on process 0) routines: found 3 nodes, limit used
is 5
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object: (mg_levels_1_) 1920 MPI processes
      type: richardson
        damping factor=1.
      maximum iterations=1, nonzero initial guess
    PC Object: (mg_levels_1_) 1920 MPI processes
      type: asm
        total subdomain blocks = 1920, amount of overlap = 0
        restriction/interpolation type - RESTRICT
objects:
      KSP Object: (mg_levels_1_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_1_sub_) 1 MPI processes
        type: ilu
          in-place factorization
          0 levels of fill
          matrix ordering: natural
          factor fill ratio given 0., needed 0.
                type: seqaij
                rows=4240, cols=4240
                total: nonzeros=64800, allocated nonzeros=64800
                  using I-node routines: found 848 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=4240, cols=4240, bs=5
          using nonscalable MatPtAP() implementation
          using I-node (on process 0) routines: found 848 nodes, limit used
is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object: (mg_levels_2_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_2_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_2_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_2_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=4260, cols=4260
                total: nonzeros=65200, allocated nonzeros=65200
                  using I-node routines: found 852 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=4260, cols=4260, bs=5
          using I-node (on process 0) routines: found 852 nodes, limit used
is 5
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object: (mg_levels_3_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_3_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_3_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_3_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=5440, cols=5440
                total: nonzeros=90950, allocated nonzeros=90950
                  using I-node routines: found 1088 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=5440, cols=5440, bs=5
          using I-node (on process 0) routines: found 1088 nodes, limit
used is 5
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object: (mg_levels_4_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_4_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_4_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_4_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=5485, cols=5485
                total: nonzeros=93075, allocated nonzeros=93075
                  using I-node routines: found 1097 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=5485, cols=5485, bs=5
          using I-node (on process 0) routines: found 1097 nodes, limit
used is 5
  Down solver (pre-smoother) on level 5 -------------------------------
    KSP Object: (mg_levels_5_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_5_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_5_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_5_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=5685, cols=5685
                total: nonzeros=98925, allocated nonzeros=98925
                  using I-node routines: found 1137 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=5685, cols=5685, bs=5
          using I-node (on process 0) routines: found 1137 nodes, limit
used is 5
  Down solver (pre-smoother) on level 6 -------------------------------
    KSP Object: (mg_levels_6_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_6_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_6_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_6_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=5825, cols=5825
                total: nonzeros=102325, allocated nonzeros=102325
                  using I-node routines: found 1165 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=5825, cols=5825, bs=5
          using I-node (on process 0) routines: found 1165 nodes, limit
used is 5
  Down solver (pre-smoother) on level 7 -------------------------------
    KSP Object: (mg_levels_7_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_7_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_7_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_7_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=5925, cols=5925
                total: nonzeros=104925, allocated nonzeros=104925
                  using I-node routines: found 1185 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=5925, cols=5925, bs=5
          using I-node (on process 0) routines: found 1185 nodes, limit
used is 5
  Down solver (pre-smoother) on level 8 -------------------------------
    KSP Object: (mg_levels_8_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_8_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_8_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_8_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=6050, cols=6050
                total: nonzeros=110200, allocated nonzeros=110200
                  using I-node routines: found 1210 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=6050, cols=6050, bs=5
          using I-node (on process 0) routines: found 1210 nodes, limit
used is 5
  Down solver (pre-smoother) on level 9 -------------------------------
    KSP Object: (mg_levels_9_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_9_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_9_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_9_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=6890, cols=6890
                total: nonzeros=153200, allocated nonzeros=153200
                  using I-node routines: found 1378 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=6890, cols=6890, bs=5
          using I-node (on process 0) routines: found 1378 nodes, limit
used is 5
  Down solver (pre-smoother) on level 10 -------------------------------
    KSP Object: (mg_levels_10_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_10_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_10_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_10_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=7395, cols=7395
                total: nonzeros=180025, allocated nonzeros=180025
                  using I-node routines: found 1479 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=7395, cols=7395, bs=5
          using I-node (on process 0) routines: found 1479 nodes, limit
used is 5
  Down solver (pre-smoother) on level 11 -------------------------------
    KSP Object: (mg_levels_11_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_11_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_11_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_11_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=8960, cols=8960
                total: nonzeros=259800, allocated nonzeros=259800
                  using I-node routines: found 1792 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=8960, cols=8960, bs=5
          using I-node (on process 0) routines: found 1792 nodes, limit
used is 5
  Down solver (pre-smoother) on level 12 -------------------------------
    KSP Object: (mg_levels_12_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_12_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_12_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_12_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=1795, cols=1795
                total: nonzeros=33275, allocated nonzeros=33275
                  using I-node routines: found 359 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=11825, cols=11825, bs=5
        total: nonzeros=403125, allocated nonzeros=403125
          using I-node (on process 0) routines: found 359 nodes, limit used
is 5
  Down solver (pre-smoother) on level 13 -------------------------------
    KSP Object: (mg_levels_13_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_13_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_13_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_13_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=340, cols=340
                total: nonzeros=3500, allocated nonzeros=3500
                  using I-node routines: found 68 nodes, limit used is 5
          type: seqaij
          rows=340, cols=340
        type: mpiaij
        rows=17210, cols=17210, bs=5
        total: nonzeros=696850, allocated nonzeros=696850
          using I-node (on process 0) routines: found 68 nodes, limit used
is 5
  Down solver (pre-smoother) on level 14 -------------------------------
    KSP Object: (mg_levels_14_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_14_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_14_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_14_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=125, cols=125
                total: nonzeros=625, allocated nonzeros=625
                  using I-node routines: found 25 nodes, limit used is 5
          type: seqaij
          rows=125, cols=125
        type: mpiaij
        rows=29055, cols=29055, bs=5
        total: nonzeros=1475675, allocated nonzeros=1475675
          using I-node (on process 0) routines: found 25 nodes, limit used
is 5
  Down solver (pre-smoother) on level 15 -------------------------------
    KSP Object: (mg_levels_15_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_15_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_15_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_15_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=45, cols=45
                total: nonzeros=225, allocated nonzeros=225
                  using I-node routines: found 9 nodes, limit used is 5
          type: seqaij
          rows=45, cols=45
        type: mpiaij
        rows=62935, cols=62935, bs=5
        total: nonzeros=3939025, allocated nonzeros=3939025
          using I-node (on process 0) routines: found 9 nodes, limit used
is 5
  Down solver (pre-smoother) on level 16 -------------------------------
    KSP Object: (mg_levels_16_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_16_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_16_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_16_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=55, cols=55
                total: nonzeros=725, allocated nonzeros=725
                  using I-node routines: found 11 nodes, limit used is 5
          type: seqaij
          rows=55, cols=55
        type: mpiaij
        rows=205010, cols=205010, bs=5
        total: nonzeros=14780300, allocated nonzeros=14780300
          using scalable MatPtAP() implementation
          using I-node (on process 0) routines: found 11 nodes, limit used
is 5
  Down solver (pre-smoother) on level 17 -------------------------------
    KSP Object: (mg_levels_17_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_17_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_17_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_17_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=360, cols=360
                total: nonzeros=14350, allocated nonzeros=14350
                  using I-node routines: found 72 nodes, limit used is 5
          type: seqaij
          rows=360, cols=360
        type: mpiaij
        rows=921310, cols=921310, bs=5
        total: nonzeros=63203300, allocated nonzeros=63203300
          using I-node (on process 0) routines: found 72 nodes, limit used
is 5
  Down solver (pre-smoother) on level 18 -------------------------------
    KSP Object: (mg_levels_18_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_18_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_18_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_18_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=2130, cols=2130
                total: nonzeros=87950, allocated nonzeros=87950
                  using I-node routines: found 426 nodes, limit used is 5
          type: seqaij
        type: mpiaij
        rows=4473930, cols=4473930, bs=5
        total: nonzeros=232427300, allocated nonzeros=232427300
          using I-node (on process 0) routines: found 426 nodes, limit used
is 5
  Down solver (pre-smoother) on level 19 -------------------------------
    KSP Object: (mg_levels_19_) 1920 MPI processes
      type: richardson
        damping factor=1.
    PC Object: (mg_levels_19_) 1920 MPI processes
      type: asm
objects:
      KSP Object: (mg_levels_19_sub_) 1 MPI processes
        type: preonly
      PC Object: (mg_levels_19_sub_) 1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=179050, cols=179050
                total: nonzeros=42562500, allocated nonzeros=42562500
                  using I-node routines: found 35810 nodes, limit used is 5
          type: seqaij
      linear system matrix followed by preconditioner matrix:
        type: mffd
        rows=347149550, cols=347149550
          Matrix-free approximation:
            err=1.49012e-08 (relative error in function evaluation)
            Using wp compute h routine
                Does not compute normU
        type: mpiaij
        rows=347149550, cols=347149550, bs=5
        total: nonzeros=86758607500, allocated nonzeros=86758607500
          using I-node (on process 0) routines: found 35810 nodes, limit
used is 5
    type: mffd
    type: mpiaij
      using I-node (on process 0) routines: found 35810 nodes, limit used
is 5
        Line search: Using full step: fnorm 2.025875581923e+03 gnorm
2.801672254495e+00
    1 SNES Function norm 2.801672254495e+00
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191015/370e6666/attachment-0001.html>
