[petsc-users] VecView output to HDF5 in 3.12.0 broken ?
Smith, Barry F. bsmith at mcs.anl.gov
Tue Oct 15 16:28:06 CDT 2019
   Thanks for figuring this out. We should have done this debugging and figured it out.
   I hunted through the HDF5 docs and includes and though they document the maximum chunk size they do not seem to have any way of getting it using the preprocessor or compiler (that it is not defined by a macro or function).
   This means we need to defined PETSC_HDF5_MAX_CHUNKSIZE 2147483647 inside our hdf5 include file and use this macro whenever we check for chunk size instead of using PETSC_HDF5_INT_MAX
   Are you able to make a MR with this feature for maint or should we?
   Thanks again, and sorry for the side effect that someone unintentionally introduced when they "fixed" the code.
   Barry
> On Oct 15, 2019, at 3:59 PM, Sajid Ali via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi PETSc-developers,
> I think I’ve found the commit that broke this. In MR-1706, the definition of PETSC_HDF5_INT_MAX was changed from being set to 2147483647 to (~(hsize_t)0).
> This new definition sets PETSC_HDF5_INT_MAX to 18446744073709551615 thereby changing the thresholds in the chunking logic at src/vec/vec/impls/mpi/pdvec.c (which causes the error I’m observing).
> I’m not sure where the number 2147483647 comes from but I tried looking at the older commits only to realize that include/petscviewerhdf5.h has always had this number (ever since this definition was moved over from include/petscviewer.h).
> Snippet to check value of (~(hsize_t)0) :
> (ipy3) [sajid at xrmlite misc]$ cat ex.c
> #include "hdf5.h"
> int main() {
>         printf("ref=%llu \n",(~(hsize_t)0));
>         size_t size = sizeof(hsize_t);
>         printf("size = %zu\n", size);
> (ipy3) [sajid at xrmlite misc]$ h5cc ex.c
> (ipy3) [sajid at xrmlite misc]$ ./a.out
> ref=18446744073709551615
> size = 8
> Thank You,
> Sajid Ali
> Applied Physics
> Northwestern University
> s-sajid-ali.github.io
