[petsc-users] Block preconditioning for 3d problem
Dave Lee davelee2804 at gmail.com
Sun Oct 13 06:20:24 CDT 2019
Hi Barry,
I've answered your questions as follows:
 So each slab lives on all the processes?
Yes, that's correct.
How many processes and how many slabs are you running with?
For my test problem there are 6 processors and 8 slabs
There will be num_slabs blocks per processor times the number of
processors. Depending on the layout of the unknowns each block will consist
of a entire local slap or each block will consist of pieces from each slap.
The internal slab DOF is the minor index. Each processor is responsible for
144 DOFs per slab, so each processor is responsible for 8x144 DOFs. When I
run with -ksp_view there are 8 blocks on each processor (48 total), each
with 144 DOF's, so I'm assuming everything is ok there.
 Please run the linear solver with
    -ksp_monitor_true_residual -sub_ksp_monitor_true_residual
-ksp_converged_reason -sub_ksp_converged_reason
  Do you get huge iteration counts somewhere?
Not that I can see, file is attached (log.gmres)
Next run the same thing but add -ksp_type fgmres does that change anything?
I don't think so. The convergence is still the same, file is attached
(log.fgmres).
One thing I've noticed - I've been dumping the index of the slab with the
maximum normalised error: norm_L2(delta_x) / norm_L2(x). If I solve for
each slab separately, then the maximum normalised errors are typically in
slab 3 (of 0-7). This makes sense as this is probably the most dynamically
active layer of the atmosphere. However if I solve for all the slabs in a
single solve (as is the cases for these tests), then the greatest error is
always in slab 7, the top of the atmosphere. Obviously the pressure is
lowest in this level, so I'm wondering if the GMRES iterations are just
weighting for the lower layers of the atmosphere too much.
Cheers, Dave.
On Sun, Oct 13, 2019 at 3:42 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Oct 10, 2019, at 2:58 AM, Dave Lee via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hi PETSc,
> > I have a nonlinear 3D problem for a set of uncoupled 2D slabs. (Which I
> ultimately want to couple once this problem is solved).
> > When I solve the inner linear problem for each of these 2D slabs
> individually (using KSPGMRES) the convergence of the outer nonlinear
> problem is good. However when I solve the inner linear problem as a single
> 3D problem (with no coupling between the 2D slabs, so the matrix is
> effectively a set of uncoupled blocks, one for each 2D slab) the outer
> nonlinear convergence degrades dramatically.
> > Note that I am not using SNES, just my own quasi-Newton approach for the
> outer nonlinear problem.
> > I suspect that the way to recover the convergence for the 3D coupled
> problem is to use some sort of PCBJACOBI or PCFIELDSPLIT preconditioner,
> but I'm not entirely sure. I've tried following this example:
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex7.c.html
> > but without any improvement in the convergence.
> > On each processor the slab index is the major index and the internal
> slab DOF index is the minor index. The parallel decomposition is within the
> 2D slab dimensions only, not between slabs.
> > I'm configuring the 3D inner linear solver as
> > KSPGetPC(ksp, &pc);
> > PCSetType(pc, PCBJACOBI);
> > PCBJacobiSetLocalBlocks(pc, num_slabs, NULL);
> > KSPSetUp(ksp);
> > PCBJacobiGetSubKSP(pc, &nlocal, &first_local, &subksp);
> > for(int ii = 0; ii < nlocal; ii++) {
> >     KSPGetPC(subksp[ii], &subpc);
> >     PCSetType(subpc, PCJACOBI);
> >     KSPSetType(subksp[ii], KSPGMRES);
> >     KSPSetTolerances(subksp[ii], 1.e-12, PETSC_DEFAULT, PETSC_DEFAULT,
> PETSC_DEFAULT);
> anything?
>   Send all the results in an attached file.
> Barry
> > However this does not seem to change the outer nonlinear convergence.
> When I run with ksp_view the local block sizes look correct - number of
> local 2D slab DOFs for each block on each processor.
> > Any ideas on what sort of KSP/PC configuration I should be using to
> recover the convergence of the uncoupled 2D slab linear solve for this 3D
> linear solve? Should I be rethinking my node indexing to help with this?
> > Cheers, Dave.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191013/3e5377d5/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191013/3e5377d5/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191013/3e5377d5/attachment-0003.obj>
