[petsc-users] Using petsc with an existing domain decomposition.
Mark Adams mfadams at lbl.gov
Sun Oct 13 08:56:58 CDT 2019
On Sun, Oct 13, 2019 at 5:25 AM Pierre Gubernatis via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello all,
> It souds that the best way to introduce petsc in a code is not to
> introduce it, but develop the code over the petsc structure.
All things being equal, yes, but few users start with PETSc from scratch.
You situation is normal and Matt's suggestion of mirroring your mesh in
PETSc mesh object (DM) is a common approach.
> It is probably true but my problem is that my existing code already is
> equipped with a domain decomposition based on MPI (a typical themal
> hydraulic with cartesian staggered mesh)
> The user can slice the domain in sub-domains and construct a linear
> problem by block: each sub-domain assembles its part of the operator and
> its part of the RHS.
> I am wondering what is the best way now to introduce petsc (considering
> that I don’t want to assemble a global operator on a given proc). Is there
> an example that would show how to introduce petsc in this situation ?
> Thank you, Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191013/f9219b2b/attachment.html>
