[petsc-users] DMPlex memory problem in scaling test
Fri Oct 11 07:02:59 CDT 2019
On Fri, Oct 11, 2019 at 12:37 AM Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matt,
> My previous test is terminated after calling subroutine A as shown below.
> >> In Subroutine A
>       call DMPlexDistribute(dmda_flow%da,stencil_width,                &
>                             PETSC_NULL_SF,distributedMesh,ierr)
>       CHKERRQ(ierr)
>       if (distributedMesh /= PETSC_NULL_DM) then
>         call DMDestroy(dmda_flow%da,ierr)
>         CHKERRQ(ierr)
>         !c set the global mesh as distributed mesh
>         dmda_flow%da = distributedMesh
>         call DMDestroy(distributedMesh,ierr)
>        !If DMDestroy(distributedMesh,ierr) called, then everything is
> destroyed and there is nothing output with -malloc_test. However, I got
> error in the next subroutine [0]PETSC ERROR: DMGetCoordinatesLocal() line
> 5545 in /home/dsu/Soft/PETSc/petsc-dev/src/dm/interface/dm.c Object already
> free: Parameter # 1
>         CHKERRQ(ierr)
>      end if
> >> In Subroutine B
>       !c get local mesh DM and set coordinates
>       call DMGetCoordinatesLocal(dmda_flow%da,gc,ierr)
>       CHKERRQ(ierr)
>       call DMGetCoordinateDM(dmda_flow%da,cda,ierr)
>       CHKERRQ(ierr)
Okay, after Distribute() call DMDestroy() on the parallel mesh as well.
     Matt
> Thanks,
> Danyang
> On 2019-10-10 6:15 p.m., Matthew Knepley wrote:
> On Thu, Oct 10, 2019 at 9:00 PM Danyang Su <danyang.su at gmail.com> wrote:
>> Labels should be destroyed with the DM. Just make a small code that does
>> nothing but distribute the mesh and end. If you
>> run with -malloc_test you should see if everythign is destroyed properly.
>>   Thanks,
>>     Matt
>> Attached is the output run with -malloc_test using 2 processor. It's a
>> big file. How can I quick check if something is not properly destroyed?
> Everything output has not been destroyed. It looks like you did not
> destroy the distributed DM.
>   Thanks,
>     Matt
>> Thanks,
>> Danyang
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/520323d8/attachment.html>
