[petsc-users] Block preconditioning for 3d problem
Dave Lee davelee2804 at gmail.com
Fri Oct 11 02:38:38 CDT 2019
Hey Jed,
Right now they are uncoupled purely for testing purposes. I just want to
get the uncoupled problem right before moving on to the coupled problem.
When I add the vertical dynamics back in both the outer nonlinear
convergence and the inner linear convergence are roughly the same as for
when I solve for the 2D slabs only as a 3D system.
I like your scaling idea. I tried using the pressure multiplied by the mass
matrix as a preconditioner for the inner linear problem, but this didn't
help. Perhaps some sort of scaling is the way to go though.
Cheers, Dave.
On Fri, Oct 11, 2019 at 2:45 PM Jed Brown <jed at jedbrown.org> wrote:
> Why are your slabs decoupled at present?  (Have you done a transform in
> the vertical?)  Is the linear convergence significantly different when
> you include the multiple layers?
> Dave Lee <davelee2804 at gmail.com> writes:
> > Hi Jed and Mark,
> > thanks for your helpful comments. Yes the nonlinear outer problem is
> > uncoupled between the slabs, it is only the linear inner problem where
> they
> > are coupled.
> > I've tried to make the slab DOFs close in memory, and also tried using a
> > tight tolerance on the outer KSP (1.0e-20), but without success.
> > You make some really good points about scaling issues Jed and Mark. This
> is
> > a solve for a global atmosphere, and each 2D slab is a horizontal layer
> of
> > the atmosphere, so the pressure (which the linear solve is for) will vary
> > dramatically between slabs. Perhaps I can additionally precondition the
> > linear problem to normalise the pressure in each slab so that they stay
> > close to unity.
> > Cheers, Dave.
> > On Fri, Oct 11, 2019 at 2:52 AM Mark Adams <mfadams at lbl.gov> wrote:
> >> I can think of a few sources of coupling in the solver: 1) line search
> and
> >> 2) Krylov, and 3) the residual test (scaling issues). You could turn
> >> linesearch off and use Richardson (with a fixed number of iterations) or
> >> exact solves as Jed suggested. As far as scaling can you use the same NL
> >> problem on each slab? This should fix all the problems anyway. Or, on
> the
> >> good decouple solves, if the true residual is of the same scale and
> *all*
> >> of the slabs converge well then you should be OK on scaling. If this
> works
> >> then start adding stuff back in and see what breaks it.
> >> On Thu, Oct 10, 2019 at 11:01 AM Jed Brown via petsc-users <
> >> petsc-users at mcs.anl.gov> wrote:
> >>> Dave Lee via petsc-users <petsc-users at mcs.anl.gov> writes:
> >>> > Hi PETSc,
> >>> > I have a nonlinear 3D problem for a set of uncoupled 2D slabs.
> (Which I
> >>> > ultimately want to couple once this problem is solved).
> >>> > When I solve the inner linear problem for each of these 2D slabs
> >>> > individually (using KSPGMRES) the convergence of the outer nonlinear
> >>> > problem is good. However when I solve the inner linear problem as a
> >>> single
> >>> > 3D problem (with no coupling between the 2D slabs, so the matrix is
> >>> > effectively a set of uncoupled blocks, one for each 2D slab) the
> outer
> >>> > nonlinear convergence degrades dramatically.
> >>> Is the nonlinear problem also decoupled between slabs?
> >>> If you solve the linear problem accurately (tight tolerances on the
> >>> outer KSP, or global direct solve), is the outer nonlinear convergence
> >>> good again?  If not, test that your Jacobian is correct (it likely
> isn't
> >>> or you have inconsistent scaling leading to ill conditioning).  SNES
> has
> >>> automatic tests for that, but you aren't using SNES so you'd have to
> >>> write some code.
> >>> What happens if you run the 2D problem (where convergence is currently
> >>> good) with much smaller subdomains (or -pc_type pbjacobi)?
> >>> > Note that I am not using SNES, just my own quasi-Newton approach for
> the
> >>> > outer nonlinear problem.
> >>> > I suspect that the way to recover the convergence for the 3D coupled
> >>> > problem is to use some sort of PCBJACOBI or PCFIELDSPLIT
> preconditioner,
> >>> > but I'm not entirely sure. I've tried following this example:
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex7.c.html
> >>> > but without any improvement in the convergence.
> >>> > On each processor the slab index is the major index and the internal
> >>> slab
> >>> > DOF index is the minor index. The parallel decomposition is within
> the
> >>> 2D
> >>> > slab dimensions only, not between slabs.
> >>> For convergence, you usually want the direction of tight coupling
> >>> (sounds like that is within slabs) to be close in memory.
> >>> In general, use -ksp_monitor_true_residual -ksp_converged_reason.
> >>> > I'm configuring the 3D inner linear solver as
> >>> > KSPGetPC(ksp, &pc);
> >>> > PCSetType(pc, PCBJACOBI);
> >>> > PCBJacobiSetLocalBlocks(pc, num_slabs, NULL);
> >>> > KSPSetUp(ksp);
> >>> > PCBJacobiGetSubKSP(pc, &nlocal, &first_local, &subksp);
> >>> > for(int ii = 0; ii < nlocal; ii++) {
> >>> >     KSPGetPC(subksp[ii], &subpc);
> >>> >     PCSetType(subpc, PCJACOBI);
> >>> >     KSPSetType(subksp[ii], KSPGMRES);
> >>> >     KSPSetTolerances(subksp[ii], 1.e-12, PETSC_DEFAULT,
> PETSC_DEFAULT,
> >>> > PETSC_DEFAULT);
> >>> > However this does not seem to change the outer nonlinear convergence.
> >>> When
> >>> > I run with ksp_view the local block sizes look correct - number of
> >>> local 2D
> >>> > slab DOFs for each block on each processor.
> >>> > Any ideas on what sort of KSP/PC configuration I should be using to
> >>> recover
> >>> > the convergence of the uncoupled 2D slab linear solve for this 3D
> linear
> >>> > solve? Should I be rethinking my node indexing to help with this?
> >>> > Cheers, Dave.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/6bde40c7/attachment-0001.html>
