[petsc-users] DMPlex memory problem in scaling test
Danyang Su danyang.su at gmail.com
Thu Oct 10 15:26:12 CDT 2019
Hi All,
Your guess is right. The memory problem occurs after
DMPlexCreateFromCellList and DMPlexDistribute. The mesh related memory
in the master processor is not released after that.
The pseudo code I use is
if (rank == 0) then         !only the master processor read the mesh
file and create cell list
         call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells, &
num_nodes,num_nodes_per_cell,    &
Petsc_False,dmplex_cells,ndim,   &  !use Petsc_True to create
intermediate mesh entities (faces, edges),
dmplex_verts,dmda_flow%da,ierr)     !not work for prism for the current
3.8 version.
         CHKERRQ(ierr)
else                                 !slave processors pass zero cells
         call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,0,       &
3.8 version.
         CHKERRQ(ierr)
end if
call DMPlexDistribute
call DMDestroy(dmda_flow%da,ierr)
CHKERRQ(ierr)
!c set the global mesh as distributed mesh
dmda_flow%da = distributedMesh
After calling the above functions, the memory usage for the test case
(no. points 953,433, nprocs 160) is shown below:
rank 0 PETSc memory current MB    1610.39 PETSc memory maximum MB    1690.42
rank 151 PETSc memory current MB     105.00 PETSc memory maximum MB
104.94
rank 98 PETSc memory current MB     106.02 PETSc memory maximum MB
105.95
rank 18 PETSc memory current MB     106.17 PETSc memory maximum MB
106.17
Is there any function available in the master version that can release
this memory?
Danyang
On 2019-10-10 11:09 a.m., Mark Adams via petsc-users wrote:
> Now that I think about it, the partitioning and distribution can be
> done with existing API, I would assume, like is done with matrices.
> I'm still wondering what the H5 format is. I assume that it is not
> built for a hardwired number of processes to read in parallel and that
> the parallel read is somewhat scalable.
> On Thu, Oct 10, 2019 at 12:13 PM Mark Adams <mfadams at lbl.gov
> <mailto:mfadams at lbl.gov>> wrote:
>     A related question, what is the state of having something like a
>     distributed  DMPlexCreateFromCellList method, but maybe your H5
>     efforts would work. My bone modeling code is old and a pain, but
>     the apps specialized serial mesh generator could write an H5 file
>     instead of the current FEAP file. Then you reader, SNES and a
>     large deformation plasticity element in PetscFE could replace my
>     code, in the future.
>     How does your H5 thing work? Is it basically a flat file (not
>     partitioned) that is read in in parallel by slicing the cell
>     lists, etc, using file seek or something equivalent, then
>     reconstructing a local graph on each processor to give to say
>     Parmetis, then completes the distribution with this
>     reasonable partitioning? (this is what our current code does)
>     Thanks,
>     Mark
>     On Thu, Oct 10, 2019 at 9:30 AM Dave May via petsc-users
>     <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>         On Thu 10. Oct 2019 at 15:15, Matthew Knepley
>         <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>             On Thu, Oct 10, 2019 at 9:10 AM Dave May
>             <dave.mayhem23 at gmail.com <mailto:dave.mayhem23 at gmail.com>>
>             wrote:
>                 On Thu 10. Oct 2019 at 15:04, Matthew Knepley
>                     On Thu, Oct 10, 2019 at 8:41 AM Dave May
>                     <mailto:dave.mayhem23 at gmail.com>> wrote:
>                         On Thu 10. Oct 2019 at 14:34, Matthew Knepley
>                         wrote:
>                             On Thu, Oct 10, 2019 at 8:31 AM Dave May
>                                 On Thu, 10 Oct 2019 at 13:21, Matthew
>                                 Knepley via petsc-users
>                                     On Wed, Oct 9, 2019 at 5:10 PM
>                                     Danyang Su via petsc-users
>                                     wrote:
>                                         Dear All,
>                                         I have a question regarding
>                                         the maximum memory usage for
>                                         the scaling test. My code is
>                                         written in Fortran with
>                                         support for both structured
>                                         grid (DM) and unstructured
>                                         grid (DMPlex). It looks like
>                                         memory consumption is much
>                                         larger when DMPlex is used and
>                                         finally causew out_of_memory
>                                         problem.
>                                         Below are some test using both
>                                         structured grid and
>                                         unstructured grid. The memory
>                                         consumption by the code is
>                                         estimated based on all
>                                         allocated arrays and PETSc
>                                         estimated based on
>                                         PetscMemoryGetMaximumUsage.
>                                         I just wonder why the PETSc
>                                         memory consumption does not
>                                         decrease when number of
>                                         processors increases. For
>                                         structured grid (scenario
>                                         7-9), the memory consumption
>                                         decreases as number of
>                                         processors increases. However,
>                                         for unstructured grid case
>                                         (scenario 14-16), the memory
>                                         for PETSc part remains
>                                         unchanged. When I run a larger
>                                         case, the code crashes because
>                                         memory is ran out. The same
>                                         case works on another cluster
>                                         with 480GB memory per node.
>                                         Does this make sense?
>                                     We would need a finer breakdown of
>                                     where memory is being used. I did
>                                     this for a paper:
>                                     https://agupubs.onlinelibrary.wiley.com/doi/full/10.1002/jgrb.50217
>                                     If the subdomains, the halo sizes
>                                     can overwhelm the basic storage.
>                                     It looks like the subdomains are
>                                     big here,
>                                     but things are not totally clear
>                                     to me. It would be helpful to send
>                                     the output of -log_view for each
>                                     case since
>                                     PETSc tries to keep track of
>                                     allocated memory.
>                                 Matt - I'd guess that there is a
>                                 sequential (non-partitioned) mesh
>                                 hanging around in memory.
>                                 Is it possible that he's created the
>                                 PLEX object which is loaded
>                                 sequentially (stored and retained in
>                                 memory and never released), and then
>                                 afterwards distributed?
>                                 This can never happen with the DMDA
>                                 and the table verifies this.
>                                 If his code using the DMDA and DMPLEX
>                                 are as identical as possible (albeit
>                                 the DM used), then a sequential mesh
>                                 held in memory seems the likely cause.
>                             Dang it, Dave is always right.
>                             How to prevent this?
>                         I thought you/Lawrence/Vaclav/others... had
>                         developed and provided support  for a parallel
>                         DMPLEX load via a suitably defined plex
>                         specific H5 mesh file.
>                     We have, but these tests looked like generated meshes.
>                 Great.
>                 So would a solution to the problem be to have the user
>                 modify their code in the follow way:
>                 * they move the mesh gen stage into a seperate exec
>                 which they call offline (on a fat node with lots of
>                 memory), and dump the appropriate file
>                 * they change their existing application to simply
>                 load that file in parallel.
>             Yes.
>                 If there were examples illustrating how to create the
>                 file which can be loaded in parallel I think it would
>                 be very helpful for the user (and many others)
>             I think Vaclav is going to add his examples as soon as we
>             fix this parallel interpolation bug. I am praying for time
>             in the latter
>             part of October to do this.
>         Excellent news - thanks for the update and info.
>         Cheers
>         Dave
>               Thanks,
>                 Matt
>                 Cheers
>                 Dave
>                       Thanks,
>                         Matt
>                             Since it looks like you are okay with
>                             fairly regular meshes, I would construct the
>                             coarsest mesh you can, and then use
>                               -dm_refine <k>
>                             which is activated by DMSetFromOptions().
>                             Make sure to call it after
>                             DMPlexDistribute(). It will regularly
>                             refine in parallel and should show good
>                             memory scaling as Dave says.
>                               Thanks,
>                                  Matt
>                                       Thanks,
>                                          Matt
>                                         scenario 	no. points 	cell
>                                         type 	DMPLex 	nprocs 	no.
>                                         nodes 	mem per node GB 	solver
>                                         	Rank 0 memory MB 	Rank 0
>                                         petsc memory MB 	Runtime (sec)
>                                         1 	2121 	rectangle 	no 	40 	1
>                                         200 	GMRES,Hypre
>                                         preconditioner 	0.21 	41.6
>                                         2 	8241 	rectangle 	no 	40 	1
>                                         200 	GMRES,Hypre
>                                         preconditioner 	0.59 	51.84
>                                         3 	32481 	rectangle 	no 	40 	1
>                                         	200 	GMRES,Hypre
>                                         preconditioner 	1.95 	59.1
>                                         4 	128961 	rectangle 	no 	40
>                                         1 	200 	GMRES,Hypre
>                                         preconditioner 	7.05 	89.71
>                                         5 	513921 	rectangle 	no 	40
>                                         1 	200 	GMRES,Hypre
>                                         preconditioner 	26.76 	110.58
>                                         6 	2051841 	rectangle 	no 	40
>                                         1 	200 	GMRES,Hypre
>                                         preconditioner 	104.21 	232.05
>                                         *7* 	*8199681* 	*rectangle*
>                                         *no* 	*40* 	*1* 	*200*
>                                         *GMRES,Hypre preconditioner*
>                                         *411.26* 	*703.27* 	*140.29*
>                                         *8* 	*8199681* 	*rectangle*
>                                         *no* 	*80* 	*2* 	*200*
>                                         *206.6* 	*387.25* 	*62.04*
>                                         *9* 	*8199681* 	*rectangle*
>                                         *no* 	*160* 	*4* 	*200*
>                                         *104.28* 	*245.3* 	*32.76*
>                                         10 	2121 	triangle 	yes 	40 	1
>                                         	200 	GMRES,Hypre
>                                         preconditioner 	0.49 	61.78
>                                         11 	15090 	triangle 	yes 	40
>                                         1 	200 	GMRES,Hypre
>                                         preconditioner 	2.32 	96.61
>                                         12 	59847 	triangle 	yes 	40
>                                         1 	200 	GMRES,Hypre
>                                         preconditioner 	8.28 	176.14
>                                         13 	238568 	triangle 	yes 	40
>                                         1 	200 	GMRES,Hypre
>                                         preconditioner 	31.89 	573.73
>                                         *14* 	*953433* 	*triangle*
>                                         *yes* 	*40* 	*1* 	*200*
>                                         *119.23* 	*2102.54* 	*44.11*
>                                         *15* 	*953433* 	*triangle*
>                                         *yes* 	*80* 	*2* 	*200*
>                                         *72.99* 	*2123.8* 	*24.36*
>                                         *16* 	*953433* 	*triangle*
>                                         *yes* 	*160* 	*4* 	*200*
>                                         *48.65* 	*2076.25* 	*14.87*
>                                         17 	55770 	prism 	yes 	40 	1
>                                         200 	GMRES,Hypre
>                                         preconditioner 	18.46 	219.39
>                                         18 	749814 	prism 	yes 	40 	1
>                                         200 	GMRES,Hypre
>                                         preconditioner 	149.86 	2412.39
>                                         19 	7000050 	prism 	yes 	40 to
>                                         640 	1 to 16 	200 	GMRES,Hypre
>                                         preconditioner
>                                         	out_of_memory
>                                         *20* 	*7000050* 	*prism*
>                                         *yes* 	*64* 	*2* 	*480*
>                                         *890.92* 	*17214.41*
>                                         The error information of
>                                         scenario 19 is shown below:
>                                         kernel messages produced
>                                         during job executions:
>                                         [Oct 9 10:41] mpiexec.hydra
>                                         invoked oom-killer:
>                                         gfp_mask=0x200da, order=0,
>                                         oom_score_adj=0
>                                         [  +0.010274] mpiexec.hydra
>                                         cpuset=/ mems_allowed=0-1
>                                         [  +0.006680] CPU: 2 PID:
>                                         144904 Comm: mpiexec.hydra
>                                         Tainted: G OE ------------
>                                         3.10.0-862.14.4.el7.x86_64 #1
>                                         [  +0.013365] Hardware name:
>                                         Lenovo ThinkSystem SD530
>                                         -[7X21CTO1WW]-/-[7X21CTO1WW]-,
>                                         BIOS -[TEE124N-1.40]- 06/12/2018
>                                         [  +0.012866] Call Trace:
>                                         [  +0.003945]
>                                         [<ffffffffb3313754>]
>                                         dump_stack+0x19/0x1b
>                                         [  +0.006995]
>                                         [<ffffffffb330e91f>]
>                                         dump_header+0x90/0x229
>                                         [  +0.007121]
>                                         [<ffffffffb2cfa982>] ?
>                                         ktime_get_ts64+0x52/0xf0
>                                         [  +0.007451]
>                                         [<ffffffffb2d5141f>] ?
>                                         delayacct_end+0x8f/0xb0
>                                         [  +0.007393]
>                                         [<ffffffffb2d9ac94>]
>                                         oom_kill_process+0x254/0x3d0
>                                         [  +0.007592]
>                                         [<ffffffffb2d9a73d>] ?
>                                         oom_unkillable_task+0xcd/0x120
>                                         [  +0.007978]
>                                         [<ffffffffb2d9a7e6>] ?
>                                         find_lock_task_mm+0x56/0xc0
>                                         [  +0.007729]
>                                         [<ffffffffb2d9b4d6>]
>                                         *out_of_memory+0x4b6/0x4f0*
>                                         [  +0.007358]
>                                         [<ffffffffb330f423>]
>                                         __alloc_pages_slowpath+0x5d6/0x724
>                                         [  +0.008190]
>                                         [<ffffffffb2da18b5>]
>                                         __alloc_pages_nodemask+0x405/0x420
>                                         Thanks,
>                                         Danyang
>                                     What most experimenters take for
>                                     granted before they begin their
>                                     experiments is infinitely more
>                                     interesting than any results to
>                                     which their experiments lead.
>                                     -- Norbert Wiener
>                                     https://www.cse.buffalo.edu/~knepley/
>                                     <http://www.cse.buffalo.edu/~knepley/>
>                             What most experimenters take for granted
>                             before they begin their experiments is
>                             infinitely more interesting than any
>                             results to which their experiments lead.
>                             -- Norbert Wiener
>                     What most experimenters take for granted before
>                     they begin their experiments is infinitely more
>                     interesting than any results to which their
>                     experiments lead.
>                     -- Norbert Wiener
>             What most experimenters take for granted before they begin
>             their experiments is infinitely more interesting than any
>             -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/6e4d602e/attachment-0001.html>
