[petsc-users] DMPlex memory problem in scaling test
Mark Adams
mfadams at lbl.gov
Thu Oct 10 11:13:11 CDT 2019
A related question, what is the state of having something like a
distributed DMPlexCreateFromCellList method, but maybe your H5 efforts
would work. My bone modeling code is old and a pain, but the apps
specialized serial mesh generator could write an H5 file instead of the
current FEAP file. Then you reader, SNES and a large deformation plasticity
element in PetscFE could replace my code, in the future.
How does your H5 thing work? Is it basically a flat file (not partitioned)
that is read in in parallel by slicing the cell lists, etc, using file seek
or something equivalent, then reconstructing a local graph on each
processor to give to say Parmetis, then completes the distribution with
this reasonable partitioning? (this is what our current code does)
On Thu, Oct 10, 2019 at 9:30 AM Dave May via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> On Thu 10. Oct 2019 at 15:15, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Oct 10, 2019 at 9:10 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>>> On Thu 10. Oct 2019 at 15:04, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Oct 10, 2019 at 8:41 AM Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>>> On Thu 10. Oct 2019 at 14:34, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Oct 10, 2019 at 8:31 AM Dave May <dave.mayhem23 at gmail.com>
>>>>>> wrote:
>>>>>>> On Thu, 10 Oct 2019 at 13:21, Matthew Knepley via petsc-users <
>>>>>>>> On Wed, Oct 9, 2019 at 5:10 PM Danyang Su via petsc-users <
>>>>>>>>> Dear All,
>>>>>>>>> I have a question regarding the maximum memory usage for the
>>>>>>>>> scaling test. My code is written in Fortran with support for both
>>>>>>>>> structured grid (DM) and unstructured grid (DMPlex). It looks like memory
>>>>>>>>> consumption is much larger when DMPlex is used and finally causew
>>>>>>>>> out_of_memory problem.
>>>>>>>>> Below are some test using both structured grid and unstructured
>>>>>>>>> grid. The memory consumption by the code is estimated based on all
>>>>>>>>> allocated arrays and PETSc memory consumption is estimated based on
>>>>>>>>> PetscMemoryGetMaximumUsage.
>>>>>>>>> I just wonder why the PETSc memory consumption does not decrease
>>>>>>>>> when number of processors increases. For structured grid (scenario 7-9),
>>>>>>>>> the memory consumption decreases as number of processors increases.
>>>>>>>>> However, for unstructured grid case (scenario 14-16), the memory for PETSc
>>>>>>>>> part remains unchanged. When I run a larger case, the code crashes because
>>>>>>>>> memory is ran out. The same case works on another cluster with 480GB memory
>>>>>>>>> per node. Does this make sense?
>>>>>>>> We would need a finer breakdown of where memory is being used. I
>>>>>>>> did this for a paper:
>>>>>>>> https://agupubs.onlinelibrary.wiley.com/doi/full/10.1002/jgrb.50217
>>>>>>>> If the subdomains, the halo sizes can overwhelm the basic storage.
>>>>>>>> It looks like the subdomains are big here,
>>>>>>>> but things are not totally clear to me. It would be helpful to send
>>>>>>>> the output of -log_view for each case since
>>>>>>>> PETSc tries to keep track of allocated memory.
>>>>>>> Matt - I'd guess that there is a sequential (non-partitioned) mesh
>>>>>>> hanging around in memory.
>>>>>>> Is it possible that he's created the PLEX object which is loaded
>>>>>>> sequentially (stored and retained in memory and never released), and then
>>>>>>> afterwards distributed?
>>>>>>> This can never happen with the DMDA and the table verifies this.
>>>>>>> If his code using the DMDA and DMPLEX are as identical as possible
>>>>>>> (albeit the DM used), then a sequential mesh held in memory seems the
>>>>>>> likely cause.
>>>>>> Dang it, Dave is always right.
>>>>>> How to prevent this?
>>>>> I thought you/Lawrence/Vaclav/others... had developed and provided
>>>>> support for a parallel DMPLEX load via a suitably defined plex specific H5
>>>>> mesh file.
>>>> We have, but these tests looked like generated meshes.
>>> Great.
>>> So would a solution to the problem be to have the user modify their code
>>> in the follow way:
>>> * they move the mesh gen stage into a seperate exec which they call
>>> offline (on a fat node with lots of memory), and dump the appropriate file
>>> * they change their existing application to simply load that file in
>>> parallel.
>> Yes.
>>> If there were examples illustrating how to create the file which can be
>>> loaded in parallel I think it would be very helpful for the user (and many
>>> others)
>> I think Vaclav is going to add his examples as soon as we fix this
>> parallel interpolation bug. I am praying for time in the latter
>> part of October to do this.
> Excellent news - thanks for the update and info.
> Cheers
> Dave
>> Thanks,
>> Matt
>>> Cheers
>>> Dave
>>>> Thanks,
>>>> Matt
>>>>> Since it looks like you are okay with fairly regular meshes, I would
>>>>>> construct the
>>>>>> coarsest mesh you can, and then use
>>>>>> -dm_refine <k>
>>>>>> which is activated by DMSetFromOptions(). Make sure to call it after
>>>>>> DMPlexDistribute(). It will regularly
>>>>>> refine in parallel and should show good memory scaling as Dave says.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> scenario no. points cell type DMPLex nprocs no. nodes mem per
>>>>>>>>> node GB solver Rank 0 memory MB Rank 0 petsc memory MB Runtime
>>>>>>>>> (sec)
>>>>>>>>> 1 2121 rectangle no 40 1 200 GMRES,Hypre preconditioner 0.21 41.6
>>>>>>>>> 2 8241 rectangle no 40 1 200 GMRES,Hypre preconditioner 0.59 51.84
>>>>>>>>> 3 32481 rectangle no 40 1 200 GMRES,Hypre preconditioner 1.95 59.1
>>>>>>>>> 4 128961 rectangle no 40 1 200 GMRES,Hypre preconditioner 7.05
>>>>>>>>> 89.71
>>>>>>>>> 5 513921 rectangle no 40 1 200 GMRES,Hypre preconditioner 26.76
>>>>>>>>> 110.58
>>>>>>>>> 6 2051841 rectangle no 40 1 200 GMRES,Hypre preconditioner 104.21
>>>>>>>>> 232.05
>>>>>>>>> *7* *8199681* *rectangle* *no* *40* *1* *200* *GMRES,Hypre
>>>>>>>>> preconditioner* *411.26* *703.27* *140.29*
>>>>>>>>> *8* *8199681* *rectangle* *no* *80* *2* *200* *GMRES,Hypre
>>>>>>>>> preconditioner* *206.6* *387.25* *62.04*
>>>>>>>>> *9* *8199681* *rectangle* *no* *160* *4* *200* *GMRES,Hypre
>>>>>>>>> preconditioner* *104.28* *245.3* *32.76*
>>>>>>>>> 10 2121 triangle yes 40 1 200 GMRES,Hypre preconditioner 0.49
>>>>>>>>> 61.78
>>>>>>>>> 11 15090 triangle yes 40 1 200 GMRES,Hypre preconditioner 2.32
>>>>>>>>> 96.61
>>>>>>>>> 12 59847 triangle yes 40 1 200 GMRES,Hypre preconditioner 8.28
>>>>>>>>> 176.14
>>>>>>>>> 13 238568 triangle yes 40 1 200 GMRES,Hypre preconditioner 31.89
>>>>>>>>> 573.73
>>>>>>>>> *14* *953433* *triangle* *yes* *40* *1* *200* *GMRES,Hypre
>>>>>>>>> preconditioner* *119.23* *2102.54* *44.11*
>>>>>>>>> *15* *953433* *triangle* *yes* *80* *2* *200* *GMRES,Hypre
>>>>>>>>> preconditioner* *72.99* *2123.8* *24.36*
>>>>>>>>> *16* *953433* *triangle* *yes* *160* *4* *200* *GMRES,Hypre
>>>>>>>>> preconditioner* *48.65* *2076.25* *14.87*
>>>>>>>>> 17 55770 prism yes 40 1 200 GMRES,Hypre preconditioner 18.46
>>>>>>>>> 219.39
>>>>>>>>> 18 749814 prism yes 40 1 200 GMRES,Hypre preconditioner 149.86
>>>>>>>>> 2412.39
>>>>>>>>> 19 7000050 prism yes 40 to 640 1 to 16 200 GMRES,Hypre
>>>>>>>>> preconditioner
>>>>>>>>> out_of_memory
>>>>>>>>> *20* *7000050* *prism* *yes* *64* *2* *480* *GMRES,Hypre
>>>>>>>>> preconditioner* *890.92* *17214.41*
>>>>>>>>> The error information of scenario 19 is shown below:
>>>>>>>>> kernel messages produced during job executions:
>>>>>>>>> [Oct 9 10:41] mpiexec.hydra invoked oom-killer: gfp_mask=0x200da,
>>>>>>>>> order=0, oom_score_adj=0
>>>>>>>>> [ +0.010274] mpiexec.hydra cpuset=/ mems_allowed=0-1
>>>>>>>>> [ +0.006680] CPU: 2 PID: 144904 Comm: mpiexec.hydra Tainted:
>>>>>>>>> G OE ------------ 3.10.0-862.14.4.el7.x86_64 #1
>>>>>>>>> [ +0.013365] Hardware name: Lenovo ThinkSystem SD530
>>>>>>>>> -[7X21CTO1WW]-/-[7X21CTO1WW]-, BIOS -[TEE124N-1.40]- 06/12/2018
>>>>>>>>> [ +0.012866] Call Trace:
>>>>>>>>> [ +0.003945] [<ffffffffb3313754>] dump_stack+0x19/0x1b
>>>>>>>>> [ +0.006995] [<ffffffffb330e91f>] dump_header+0x90/0x229
>>>>>>>>> [ +0.007121] [<ffffffffb2cfa982>] ? ktime_get_ts64+0x52/0xf0
>>>>>>>>> [ +0.007451] [<ffffffffb2d5141f>] ? delayacct_end+0x8f/0xb0
>>>>>>>>> [ +0.007393] [<ffffffffb2d9ac94>] oom_kill_process+0x254/0x3d0
>>>>>>>>> [ +0.007592] [<ffffffffb2d9a73d>] ?
>>>>>>>>> oom_unkillable_task+0xcd/0x120
>>>>>>>>> [ +0.007978] [<ffffffffb2d9a7e6>] ? find_lock_task_mm+0x56/0xc0
>>>>>>>>> [ +0.007729] [<ffffffffb2d9b4d6>] *out_of_memory+0x4b6/0x4f0*
>>>>>>>>> [ +0.007358] [<ffffffffb330f423>]
>>>>>>>>> __alloc_pages_slowpath+0x5d6/0x724
>>>>>>>>> [ +0.008190] [<ffffffffb2da18b5>]
>>>>>>>>> __alloc_pages_nodemask+0x405/0x420
>>>>>>>>> Thanks,
>>>>>>>>> Danyang
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/1d58d9f1/attachment-0001.html>
