[petsc-users] DMPlex memory problem in scaling test
Dave May dave.mayhem23 at gmail.com
Thu Oct 10 07:41:20 CDT 2019
On Thu 10. Oct 2019 at 14:34, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 10, 2019 at 8:31 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Thu, 10 Oct 2019 at 13:21, Matthew Knepley via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> On Wed, Oct 9, 2019 at 5:10 PM Danyang Su via petsc-users <
>>>> Dear All,
>>>> I have a question regarding the maximum memory usage for the scaling
>>>> test. My code is written in Fortran with support for both structured grid
>>>> (DM) and unstructured grid (DMPlex). It looks like memory consumption is
>>>> much larger when DMPlex is used and finally causew out_of_memory problem.
>>>> Below are some test using both structured grid and unstructured grid.
>>>> The memory consumption by the code is estimated based on all allocated
>>>> arrays and PETSc memory consumption is estimated based on
>>>> PetscMemoryGetMaximumUsage.
>>>> I just wonder why the PETSc memory consumption does not decrease when
>>>> number of processors increases. For structured grid (scenario 7-9), the
>>>> memory consumption decreases as number of processors increases. However,
>>>> for unstructured grid case (scenario 14-16), the memory for PETSc part
>>>> remains unchanged. When I run a larger case, the code crashes because
>>>> memory is ran out. The same case works on another cluster with 480GB memory
>>>> per node. Does this make sense?
>>> We would need a finer breakdown of where memory is being used. I did
>>> this for a paper:
>>>   https://agupubs.onlinelibrary.wiley.com/doi/full/10.1002/jgrb.50217
>>> If the subdomains, the halo sizes can overwhelm the basic storage. It
>>> looks like the subdomains are big here,
>>> but things are not totally clear to me. It would be helpful to send the
>>> output of -log_view for each case since
>>> PETSc tries to keep track of allocated memory.
>> Matt - I'd guess that there is a sequential (non-partitioned) mesh
>> hanging around in memory.
>> Is it possible that he's created the PLEX object which is loaded
>> sequentially (stored and retained in memory and never released), and then
>> afterwards distributed?
>> This can never happen with the DMDA and the table verifies this.
>> If his code using the DMDA and DMPLEX are as identical as possible
>> (albeit the DM used), then a sequential mesh held in memory seems the
>> likely cause.
> Dang it, Dave is always right.
> How to prevent this?
I thought you/Lawrence/Vaclav/others... had developed and provided support
 for a parallel DMPLEX load via a suitably defined plex specific H5 mesh
file.
Since it looks like you are okay with fairly regular meshes, I would
> construct the
> coarsest mesh you can, and then use
>   -dm_refine <k>
> which is activated by DMSetFromOptions(). Make sure to call it after
> DMPlexDistribute(). It will regularly
> refine in parallel and should show good memory scaling as Dave says.
>   Thanks,
>      Matt
>>>   Thanks,
>>>      Matt
>>>> scenario no. points cell type DMPLex nprocs no. nodes mem per node GB
>>>> solver Rank 0 memory MB Rank 0 petsc memory MB Runtime (sec)
>>>> 1 2121 rectangle no 40 1 200 GMRES,Hypre preconditioner 0.21 41.6
>>>> 2 8241 rectangle no 40 1 200 GMRES,Hypre preconditioner 0.59 51.84
>>>> 3 32481 rectangle no 40 1 200 GMRES,Hypre preconditioner 1.95 59.1
>>>> 4 128961 rectangle no 40 1 200 GMRES,Hypre preconditioner 7.05 89.71
>>>> 5 513921 rectangle no 40 1 200 GMRES,Hypre preconditioner 26.76 110.58
>>>> 6 2051841 rectangle no 40 1 200 GMRES,Hypre preconditioner 104.21
>>>> 232.05
>>>> *7* *8199681* *rectangle* *no* *40* *1* *200* *GMRES,Hypre
>>>> preconditioner* *411.26* *703.27* *140.29*
>>>> *8* *8199681* *rectangle* *no* *80* *2* *200* *GMRES,Hypre
>>>> preconditioner* *206.6* *387.25* *62.04*
>>>> *9* *8199681* *rectangle* *no* *160* *4* *200* *GMRES,Hypre
>>>> preconditioner* *104.28* *245.3* *32.76*
>>>> 10 2121 triangle yes 40 1 200 GMRES,Hypre preconditioner 0.49 61.78
>>>> 11 15090 triangle yes 40 1 200 GMRES,Hypre preconditioner 2.32 96.61
>>>> 12 59847 triangle yes 40 1 200 GMRES,Hypre preconditioner 8.28 176.14
>>>> 13 238568 triangle yes 40 1 200 GMRES,Hypre preconditioner 31.89 573.73
>>>> *14* *953433* *triangle* *yes* *40* *1* *200* *GMRES,Hypre
>>>> preconditioner* *119.23* *2102.54* *44.11*
>>>> *15* *953433* *triangle* *yes* *80* *2* *200* *GMRES,Hypre
>>>> preconditioner* *72.99* *2123.8* *24.36*
>>>> *16* *953433* *triangle* *yes* *160* *4* *200* *GMRES,Hypre
>>>> preconditioner* *48.65* *2076.25* *14.87*
>>>> 17 55770 prism yes 40 1 200 GMRES,Hypre preconditioner 18.46 219.39
>>>> 18 749814 prism yes 40 1 200 GMRES,Hypre preconditioner 149.86 2412.39
>>>> 19 7000050 prism yes 40 to 640 1 to 16 200 GMRES,Hypre preconditioner
>>>> out_of_memory
>>>> *20* *7000050* *prism* *yes* *64* *2* *480* *GMRES,Hypre
>>>> preconditioner* *890.92* *17214.41*
>>>> The error information of scenario 19 is shown below:
>>>> kernel messages produced during job executions:
>>>> [Oct 9 10:41] mpiexec.hydra invoked oom-killer: gfp_mask=0x200da,
>>>> order=0, oom_score_adj=0
>>>> [  +0.010274] mpiexec.hydra cpuset=/ mems_allowed=0-1
>>>> [  +0.006680] CPU: 2 PID: 144904 Comm: mpiexec.hydra Tainted:
>>>> G           OE  ------------   3.10.0-862.14.4.el7.x86_64 #1
>>>> [  +0.013365] Hardware name: Lenovo ThinkSystem SD530
>>>> -[7X21CTO1WW]-/-[7X21CTO1WW]-, BIOS -[TEE124N-1.40]- 06/12/2018
>>>> [  +0.012866] Call Trace:
>>>> [  +0.003945]  [<ffffffffb3313754>] dump_stack+0x19/0x1b
>>>> [  +0.006995]  [<ffffffffb330e91f>] dump_header+0x90/0x229
>>>> [  +0.007121]  [<ffffffffb2cfa982>] ? ktime_get_ts64+0x52/0xf0
>>>> [  +0.007451]  [<ffffffffb2d5141f>] ? delayacct_end+0x8f/0xb0
>>>> [  +0.007393]  [<ffffffffb2d9ac94>] oom_kill_process+0x254/0x3d0
>>>> [  +0.007592]  [<ffffffffb2d9a73d>] ? oom_unkillable_task+0xcd/0x120
>>>> [  +0.007978]  [<ffffffffb2d9a7e6>] ? find_lock_task_mm+0x56/0xc0
>>>> [  +0.007729]  [<ffffffffb2d9b4d6>] *out_of_memory+0x4b6/0x4f0*
>>>> [  +0.007358]  [<ffffffffb330f423>] __alloc_pages_slowpath+0x5d6/0x724
>>>> [  +0.008190]  [<ffffffffb2da18b5>] __alloc_pages_nodemask+0x405/0x420
>>>> Thanks,
>>>> Danyang
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/4ebe3534/attachment-0001.html>
