[petsc-users] TS_SSP implementation for co-dependent variables
    Manuel Valera
    mvalera-w at sdsu.edu
    Wed Oct  9 17:34:47 CDT 2019
Thanks for the answer, I will read the mentioned example, but to clarify
for Barry I will schematize the process:
At time n, the program need to do all of these at once:
   1. Solve T as a function of u,v,w
   2. Solve S as a function of u,v,w
   3. Solve rho density as a function of T,S
   4. Derivate a correction of the velocity fields from the density
   5. Solve u,v,w being corrected by the density field
What I have implemented so far:
   1. Advance TS1 to solve for T
   2. Advance TS2 to solve for S
   3. Solve rho and calculate correction
   4. Advance TS3 to solve for u,v,w
Or, altenatively:
   1. Advance TS to solve for T,S,u,v,w at the same time.
   2. Solve rho and calculate correction
Both implementation are lacking the feedback from the T,S <-> rho <->
Velocities interaction, and is creating problems when using a bigger DT.
All the systems from the first numeration are different algorithms, and
each TS in the 2nd numeration generate a different RHS.
What Jed is suggesting is to create an overarching routine that does all
that is the first list under one single step?
On Wed, Oct 9, 2019 at 3:24 PM Jed Brown <jed at jedbrown.org> wrote:
> Manuel Valera via petsc-users <petsc-users at mcs.anl.gov> writes:
> > Hello,
> > I have a set of equations which are co-dependent when integrating in
> time,
> > this means the velocities u,v,w need a component from the Temperature and
> > Salinity integration at the same intermediate step. Same for Temperature
> > and Salinity, which need the current velocities (at the intermediate time
> > stages) to be computed accurately.
> There's nothing special about having different fields.  Just evaluate
> the RHS function of the coupled system.  There are examples (e.g.,
> ts/examples/tutorials/ex9.c) of doing this for systems like shallow
> water (momentum coupled with thickness).
> > My question is, how to feed the information of the updated temperature
> > inside the velocity, and vice-versa? this would be equivalent, I think,
> to
> > obtaining the intermediate stages of the time integration so they can be
> > the input for the next intermediate stage.
> > Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191009/ca4c0399/attachment.html>
