[petsc-users] DMPlex memory problem in scaling test
Danyang Su
danyang.su at gmail.com
Wed Oct 9 16:08:54 CDT 2019
Dear All,
I have a question regarding the maximum memory usage for the scaling
test. My code is written in Fortran with support for both structured
grid (DM) and unstructured grid (DMPlex). It looks like memory
consumption is much larger when DMPlex is used and finally causew
out_of_memory problem.
Below are some test using both structured grid and unstructured grid.
The memory consumption by the code is estimated based on all allocated
arrays and PETSc memory consumption is estimated based on
PetscMemoryGetMaximumUsage.
I just wonder why the PETSc memory consumption does not decrease when
number of processors increases. For structured grid (scenario 7-9), the
memory consumption decreases as number of processors increases. However,
for unstructured grid case (scenario 14-16), the memory for PETSc part
remains unchanged. When I run a larger case, the code crashes because
memory is ran out. The same case works on another cluster with 480GB
memory per node. Does this make sense?
scenario no. points cell type DMPLex nprocs no. nodes mem per node
GB solver Rank 0 memory MB Rank 0 petsc memory MB Runtime (sec)
1 2121 rectangle no 40 1 200 GMRES,Hypre preconditioner 0.21 41.6
2 8241 rectangle no 40 1 200 GMRES,Hypre preconditioner 0.59
51.84
3 32481 rectangle no 40 1 200 GMRES,Hypre preconditioner 1.95
59.1
4 128961 rectangle no 40 1 200 GMRES,Hypre preconditioner 7.05
89.71
5 513921 rectangle no 40 1 200 GMRES,Hypre preconditioner 26.76
110.58
6 2051841 rectangle no 40 1 200 GMRES,Hypre preconditioner
104.21 232.05
*7* *8199681* *rectangle* *no* *40* *1* *200* *GMRES,Hypre
preconditioner* *411.26* *703.27* *140.29*
*8* *8199681* *rectangle* *no* *80* *2* *200* *GMRES,Hypre
preconditioner* *206.6* *387.25* *62.04*
*9* *8199681* *rectangle* *no* *160* *4* *200* *GMRES,Hypre
preconditioner* *104.28* *245.3* *32.76*
10 2121 triangle yes 40 1 200 GMRES,Hypre preconditioner 0.49
61.78
11 15090 triangle yes 40 1 200 GMRES,Hypre preconditioner 2.32
96.61
12 59847 triangle yes 40 1 200 GMRES,Hypre preconditioner 8.28
176.14
13 238568 triangle yes 40 1 200 GMRES,Hypre preconditioner 31.89
573.73
*14* *953433* *triangle* *yes* *40* *1* *200* *GMRES,Hypre
preconditioner* *119.23* *2102.54* *44.11*
*15* *953433* *triangle* *yes* *80* *2* *200* *GMRES,Hypre
preconditioner* *72.99* *2123.8* *24.36*
*16* *953433* *triangle* *yes* *160* *4* *200* *GMRES,Hypre
preconditioner* *48.65* *2076.25* *14.87*
17 55770 prism yes 40 1 200 GMRES,Hypre preconditioner 18.46
219.39
18 749814 prism yes 40 1 200 GMRES,Hypre preconditioner 149.86
2412.39
19 7000050 prism yes 40 to 640 1 to 16 200 GMRES,Hypre
preconditioner
out_of_memory
*20* *7000050* *prism* *yes* *64* *2* *480* *GMRES,Hypre
preconditioner* *890.92* *17214.41*
The error information of scenario 19 is shown below:
kernel messages produced during job executions:
[Oct 9 10:41] mpiexec.hydra invoked oom-killer: gfp_mask=0x200da,
order=0, oom_score_adj=0
[ +0.010274] mpiexec.hydra cpuset=/ mems_allowed=0-1
[ +0.006680] CPU: 2 PID: 144904 Comm: mpiexec.hydra Tainted:
G OE ------------ 3.10.0-862.14.4.el7.x86_64 #1
[ +0.013365] Hardware name: Lenovo ThinkSystem SD530
-[7X21CTO1WW]-/-[7X21CTO1WW]-, BIOS -[TEE124N-1.40]- 06/12/2018
[ +0.012866] Call Trace:
[ +0.003945] [<ffffffffb3313754>] dump_stack+0x19/0x1b
[ +0.006995] [<ffffffffb330e91f>] dump_header+0x90/0x229
[ +0.007121] [<ffffffffb2cfa982>] ? ktime_get_ts64+0x52/0xf0
[ +0.007451] [<ffffffffb2d5141f>] ? delayacct_end+0x8f/0xb0
[ +0.007393] [<ffffffffb2d9ac94>] oom_kill_process+0x254/0x3d0
[ +0.007592] [<ffffffffb2d9a73d>] ? oom_unkillable_task+0xcd/0x120
[ +0.007978] [<ffffffffb2d9a7e6>] ? find_lock_task_mm+0x56/0xc0
[ +0.007729] [<ffffffffb2d9b4d6>] *out_of_memory+0x4b6/0x4f0*
[ +0.007358] [<ffffffffb330f423>] __alloc_pages_slowpath+0x5d6/0x724
[ +0.008190] [<ffffffffb2da18b5>] __alloc_pages_nodemask+0x405/0x420
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191009/c7f628ad/attachment.html>
