[petsc-users] DMPlexCreateFromDAG for P2 elements
Stefano Zampini
stefano.zampini at gmail.com
Tue Oct 8 14:18:51 CDT 2019
DMPlex abstracts the mesh topology. PetscSection defines the dofs associated to the mesh entities.
Why do you need P2 elements? For the discrete solution or because you have a high order mesh?
If it is only for the solution, you should create a linear mesh (cell-vertex only), interpolate the mesh, and then use
PetscFECreateDefault (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/FE/PetscFECreateDefault.htm <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/FE/PetscFECreateDefault.htm>)
DMAddField (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMAddField.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMAddField.html>)
DMCreateDS (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateDS.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateDS.html>)
Instead, if you have a high-order mesh, you should create a linear mesh, and then manipulate yourself the PetscSection defining the local coordinates.
However, I’m not sure how complete is the support for high-order meshes when it comes to compute FEM residuals and assemble Jacobians
> On Oct 8, 2019, at 9:54 PM, Asitav Mishra via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi,
> Does Petsc support DMPlexCreateFromDAG for 2nd order (P2) elements, or any orders higher than one (P1) for that matter? I know it is possible to create DMPlex mesh from GMSH files with P2 elements, but not sure how the 'cone/support' structures are built. One approach is to ignore the higher order nodes in an element to create the 'cones', but is there a way to preserve the P2 element information in the 'cones'?
> For example: how would the depth=1 cone structure look like for a mesh with two P2 triangles sharing a face?
> 2
> 6 | 8
> 0 0 5 1 3
> 4 | 7
> 1
> Higher order nodes: [4, 5, 6, 7, 8]. Can we construct cones with cells-to-nodes (depth = 1)?:
> numPoints = [9, 2]; // 9 nodes instead of just 4?
> coneSizes = [6, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0];
> cones = [0, 1, 2, 4, 5, 6, 2, 1, 3, 5, 7, 8];
> etc.
> Any help would be greatly appreciated.
> Thanks,
> Asitav
> Asitav Mishra, PhD
> Research Engineer II, NIA
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191008/3b246bc8/attachment.html>
