[petsc-users] FormFunction: high Memory requested
Sun Oct 6 19:08:58 CDT 2019
On Sun, Oct 6, 2019 at 3:54 PM Amir via petsc-users <petsc-users at mcs.anl.gov>
wrote:
> How can we save memory  during Jacobin computation? I use DMPlex for my DM
> layout. Is it better to set fill pattern of Jacobin matrix? can I use
> DASetBlockFills()?
I think the discussion is becoming confused. The largest part of memory
comes from LU factorization, not from Jacobian assembly.
     Matt
> Thanks
> Amir
> On Oct 6 2019, at 9:41 pm, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Oct 5, 2019 at 1:12 AM Amir <mhbaghaei at mail.sjtu.edu.cn
> <https://link.getmailspring.com/link/D533A949-3DE7-40D6-8A83-7D4070DBD509@getmailspring.com/0?redirect=mailto%3Amhbaghaei%40mail.sjtu.edu.cn&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
> wrote:
> [image: Sent from Mailspring]
> I tried to run with -pc_none or using other preconditioner than LU. The
> memory pattern remains the same, although the newton could not solve. For a
> Jacobian size of 180K*180K, do you think 5GB memory is much?
> 1.8e5 * 1.8e5 * 8 = 2.6e11 bytes so 5Gb is 2% fill in your matrix, which
> might be completely reasonable.
>    Matt
> Thanks
> Amir
> On Oct 5 2019, at 5:55 am, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Oct 4, 2019 at 4:27 PM Amir via petsc-users <
> <https://link.getmailspring.com/link/6B28CA58-29C6-4D61-A0E9-873FD4DCB12A@getmailspring.com/0?redirect=mailto%3Apetsc-users%40mcs.anl.gov&recipient=a25lcGxleUBnbWFpbC5jb20%3D>>
> wrote:
> Hi
> To test my FormFunction, running the code on a coarse mesh, the memory
> usage is normal. However, when I try to use higher mesh resolution, the
> memory behavior is abnormal. It goes up till the program finished with
> Memory requested message. To better see the memory usage, I run with
> -log_view -malloc_test  -malloc_dump. All of vectors created, were
> destructed. Can you help me through this. Is it really because I use higher
> mesh resolution? Thanks for your time.
> Probably yes. The memory for LU goes up superlinearly and can be quite
> large.
>   Thanks,
>      Matt
> Amir
> [0]PETSC ERROR: Memory requested 8589934260
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.1, unknown
> [0]PETSC ERROR: ./main on a mpich-gcc-dbg named amir by amir Sat Oct  5
> 04:06:01 2019
> [0]PETSC ERROR: Configure options --download-mpich --download-fblaslapack
> --with-shared-libraries=1 --with-blaslapack-dir=/usr --with-x-dir=/
> --download-mumps --download-superlu_dist --download-hypre --download-ml
> --download-hdf5 --download-cmake --download-scalapack -download-parmetis
> -download-metis --with-mpich=1 --with-fortran-kernels=generic
> --with-debugging=0
> [0]PETSC ERROR: #1 PetscFreeSpaceGet() line 11 in
> /home/amir/petsc/src/mat/utils/freespace.c
> [0]PETSC ERROR: #2 PetscTrMallocDefault() line 183 in
> /home/amir/petsc/src/sys/memory/mtr.c
> [0]PETSC ERROR: #3 PetscMallocA() line 390 in
> /home/amir/petsc/src/sys/memory/mal.c
> [0]PETSC ERROR: #4 PetscFreeSpaceGet() line 11 in
> [0]PETSC ERROR: #5 MatLUFactorSymbolic_SeqAIJ() line 349 in
> /home/amir/petsc/src/mat/impls/aij/seq/aijfact.c
> [0]PETSC ERROR: #6 MatLUFactorSymbolic() line 2975 in
> /home/amir/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #7 PCSetUp_LU() line 95 in
> /home/amir/petsc/src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: #8 PCSetUp() line 923 in
> /home/amir/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #9 KSPSetUp() line 381 in
> /home/amir/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #10 KSPSolve() line 612 in
> [0]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 224 in
> /home/amir/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #12 SNESSolve() line 4312 in
> /home/amir/petsc/src/snes/interface/snes.c
> [ 0]48 bytes PetscFreeSpaceGet() line 10 in
> [ 0]1356241520 bytes PetscFreeSpaceGet() line 11 in
> [ 0]2227520 bytes MatLUFactorSymbolic_SeqAIJ() line 308 in
> [ 0]23216 bytes PetscBTCreate() line 75 in
> /home/amir/petsc/include/petscbt.h
> [ 0]742512 bytes MatLUFactorSymbolic_SeqAIJ() line 306 in
> [ 0]742512 bytes MatLUFactorSymbolic_SeqAIJ() line 301 in
> [ 0]742512 bytes MatLUFactorSymbolic_SeqAIJ() line 300 in
> [ 0]16 bytes PetscLayoutSetUp() line 141 in
> /home/amir/petsc/src/vec/is/utils/pmap.c
> [ 0]16 bytes PetscStrallocpy() line 189 in
> /home/amir/petsc/src/sys/utils/str.c
> [ 0]32 bytes PetscStrallocpy() line 189 in
> [ 0]32 bytes PetscFunctionListAdd_Private() line 213 in
> /home/amir/petsc/src/sys/dll/reg.c
> [ 0]16 bytes ISCreate_General() line 740 in
> /home/amir/petsc/src/vec/is/is/impls/general/general.c
> [ 0]48 bytes PetscLayoutCreate() line 48 in
> [ 0]784 bytes ISCreate() line 39 in
> /home/amir/petsc/src/vec/is/is/interface/isreg.c
> [ 0]742512 bytes ISInvertPermutation_General() line 205 in
> experiments lead.
> -- Norbert Wiener
> <https://link.getmailspring.com/link/6B28CA58-29C6-4D61-A0E9-873FD4DCB12A@getmailspring.com/1?redirect=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&recipient=a25lcGxleUBnbWFpbC5jb20%3D>
> experiments lead.
> -- Norbert Wiener
> <https://link.getmailspring.com/link/D533A949-3DE7-40D6-8A83-7D4070DBD509@getmailspring.com/1?redirect=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191006/369b0c1e/attachment-0001.html>
