[petsc-users] petsc-users Digest, Vol 131, Issue 49
baikadi pranay
pranayreddy865 at gmail.com
Sat Nov 30 19:28:05 CST 2019
Hello all,
I was able to figure out why i was getting a floating point error. Although
i knew that petsc uses 0-based indexing for fortran, i forgot to modify my
code accordingly. So it was accessing elements of the array which are
essentially zero.
Thank you for your time.
Pranay.
On Sat, Nov 30, 2019 at 2:57 PM <petsc-users-request at mcs.anl.gov> wrote:
> Send petsc-users mailing list submissions to
> petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
> 1. Re: Outputting matrix for viewing in matlab (baikadi pranay)
> 2. Floating point exception (baikadi pranay)
> 3. Re: Floating point exception (Matthew Knepley)
> 4. Re: Floating point exception (baikadi pranay)
> Message: 1
> Date: Sat, 30 Nov 2019 13:30:51 -0700
> From: baikadi pranay <pranayreddy865 at gmail.com>
> To: "Smith, Barry F." <bsmith at mcs.anl.gov>
> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Outputting matrix for viewing in matlab
> Message-ID:
> <CA+zFCTkqxYmE_BGOU92dSAVZ=bPL9W1CkjmCw9=
> sVZYoM7+4hA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Thank you all for the suggestions. I have it working now.
> Regards,
> Pranay.
> On Fri, Nov 29, 2019 at 10:39 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > On Nov 28, 2019, at 7:07 PM, baikadi pranay <pranayreddy865 at gmail.com>
> > wrote:
> > > Hello PETSc users,
> > > I have a sparse matrix built and I want to output the matrix for
> viewing
> > in matlab. However i'm having difficulty outputting the matrix. I am
> > writing my program in Fortran90 and I've included the following lines to
> > output the matrix.
> > > call
> > PetscViewerBinaryOpen(PETSC_COMM_SELF,'matrix',FILE_MODE_WRITE,view,ierr)
> > Normally on would use to save the matrix and then use the scripts
> > Patrick mentioned to read the matrix into Matlab or Python.
> > call MatView(matrix, view,ierr)
> > call PetscViewerDestroy(view,ierr)
> > > call PetscViewerBinaryGetDescriptor(view,fd,ierr)
> > > call PetscBinaryWrite(fd,ham,1,PETSC_SCALAR,PETSC_FALSE,ierr)
> > > These lines do create a matrix but matlab says its not a binary file.
> > Could you please provide me some inputs on where I'm going wrong and how
> to
> > proceed with this problem. I can provide any further information that you
> > might need to help me solve this problem.
> > > Thank you.
> > > Sincerely,
> > > Pranay.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191130/94be3de8/attachment-0001.html
> Message: 2
> Date: Sat, 30 Nov 2019 14:18:12 -0700
> To: petsc-users at mcs.anl.gov
> Subject: [petsc-users] Floating point exception
> Message-ID:
> CA+zFCTkX2Nf-dHnWdxKZtqtLzn2deRRstJbk_dHn9hKxCe6ZsA at mail.gmail.com>
> Hello PETSc users,
> I am currently trying to build a 1-D Schrodinger solver. I have built my
> hamiltonian matrix (of size 121 x 121) and i'm trying to find the
> eigenvalues. I have the following lines of code for the solver:
> *call EPSCreate(PETSC_COMM_WORLD,eps,ierr)*
> *call EPSSetOperators(eps,ham,S,ierr)call
> EPSSetProblemType(eps,EPS_GHEP,ierr)*
> *call EPSSetFromOptions(eps,ierr)call
> EPSSetDimensions(eps,10,PETSC_DEFAULT_INTEGER,PETSC_DEFAULT_INTEGER,ierr)call
> EPSSolve(eps,ierr)call EPSDestroy(eps,ierr)*
> At the EPSSolve line, i get the following error:
> *[0]PETSC ERROR: --------------------- Error Message
> --------------------------------------------------------------[0]PETSC
> ERROR: Floating point exception[0]PETSC ERROR: Vec entry at local location
> 0 is not-a-number or infinite at end of function: Parameter number
> 3[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> shooting.[0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019*
> I am using the options *-st_pc_factor_shift_type NONZERO
> -st_pc_factor_shift_amount 1* ( else I end up getting the "zero pivot
> in LU factorization" error ).
> I outputted my matrix to matlab and confirmed that the null space is empty
> and the matrix is not singular. I am not sure why I'm getting this error.
> Could you provide me a hint as to how to solve this problem.
> Sincerely,
> Pranay.
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191130/0333a083/attachment-0001.html
> Message: 3
> Date: Sat, 30 Nov 2019 15:45:55 -0600
> From: Matthew Knepley <knepley at gmail.com>
> To: baikadi pranay <pranayreddy865 at gmail.com>
> Cc: PETSc <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Floating point exception
> Message-ID:
> <CAMYG4GkU9hQGk+bOKm81xab8UbNsGp5OvV3fTF=
> t7uTi3eDeZA at mail.gmail.com>
> On Sat, Nov 30, 2019 at 3:19 PM baikadi pranay <pranayreddy865 at gmail.com>
> wrote:
> > Hello PETSc users,
> location
> You need to show the entire stack trace that is output here.
> Thanks,
> Matt
> empty
> > Sincerely,
> > Pranay.
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191130/d57a4cd7/attachment-0001.html
> Message: 4
> Date: Sat, 30 Nov 2019 14:56:15 -0700
> To: Matthew Knepley <knepley at gmail.com>
> Message-ID:
> CA+zFCTk4fLaGf8WXdKiuLHtj6H8S7wJWHYtiE+yJfFayqBC4uw at mail.gmail.com>
> Hello,
> The entire output is the following:
> [0]PETSC ERROR: Floating point exception
> [0]PETSC ERROR: Vec entry at local location 0 is not-a-number or infinite
> at end of function: Parameter number 3
> for
> trouble shooting.
> [0]PETSC ERROR: ./a.out on a linux-gnu-c-debug named
> agave1.agave.rc.asu.edu
> by pbaikadi Sat Nov 30 14:54:31 2019
> [0]PETSC ERROR: Configure options
> [0]PETSC ERROR: #1 VecValidValues() line 28 in
> /packages/7x/petsc/3.11.1/petsc-3.11.1/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: #2 PCApply() line 464 in
> /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #3 KSP_PCApply() line 281 in
> /packages/7x/petsc/3.11.1/petsc-3.11.1/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #4 KSPSolve_PREONLY() line 22 in
> /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/impls/preonly/preonly.c
> [0]PETSC ERROR: #5 KSPSolve() line 782 in
> /packages/7x/petsc/3.11.1/petsc-3.11.1/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #6 STMatSolve() line 193 in
> /packages/7x/slepc/3.11.1/slepc-3.11.1/src/sys/classes/st/interface/stsles.c
> [0]PETSC ERROR: #7 STApply_Shift() line 25 in
> /packages/7x/slepc/3.11.1/slepc-3.11.1/src/sys/classes/st/impls/shift/shift.c
> [0]PETSC ERROR: #8 STApply() line 57 in
> /packages/7x/slepc/3.11.1/slepc-3.11.1/src/sys/classes/st/interface/stsolve.c
> [0]PETSC ERROR: #9 EPSGetStartVector() line 797 in
> /packages/7x/slepc/3.11.1/slepc-3.11.1/src/eps/interface/epssolve.c
> [0]PETSC ERROR: #10 EPSSolve_KrylovSchur_Symm() line 32 in
> /packages/7x/slepc/3.11.1/slepc-3.11.1/src/eps/impls/krylov/krylovschur/ks-symm.c
> [0]PETSC ERROR: #11 EPSSolve() line 149 in
> Regards,
> Pranay.
> On Sat, Nov 30, 2019 at 2:46 PM Matthew Knepley <knepley at gmail.com> wrote:
> > wrote:
> >> Hello PETSc users,
> location
> > Thanks,
> > Matt
> >> pivot in LU factorization" error ).
> >> empty and the matrix is not singular. I am not sure why I'm getting this
> >> error. Could you provide me a hint as to how to solve this problem.
> >> Sincerely,
> >> Pranay.
> their
> > experiments lead.
> > -- Norbert Wiener
> > <http://www.cse.buffalo.edu/~knepley/>
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191130/d2498b43/attachment.html
> Subject: Digest Footer
> End of petsc-users Digest, Vol 131, Issue 49
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191130/83aabdab/attachment.html>
