[petsc-users] Floating point exception
baikadi pranay pranayreddy865 at gmail.com
Sat Nov 30 15:18:12 CST 2019
Hello PETSc users,
I am currently trying to build a 1-D Schrodinger solver. I have built my
hamiltonian matrix (of size 121 x 121) and i'm trying to find the
eigenvalues. I have the following lines of code for the solver:
*call EPSCreate(PETSC_COMM_WORLD,eps,ierr)*
*call EPSSetOperators(eps,ham,S,ierr)call
EPSSetProblemType(eps,EPS_GHEP,ierr)*
*call EPSSetFromOptions(eps,ierr)call
EPSSetDimensions(eps,10,PETSC_DEFAULT_INTEGER,PETSC_DEFAULT_INTEGER,ierr)call
EPSSolve(eps,ierr)call EPSDestroy(eps,ierr)*
At the EPSSolve line, i get the following error:
*[0]PETSC ERROR: --------------------- Error Message
--------------------------------------------------------------[0]PETSC
ERROR: Floating point exception[0]PETSC ERROR: Vec entry at local location
0 is not-a-number or infinite at end of function: Parameter number
3[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
<http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
shooting.[0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019*
I am using the options *-st_pc_factor_shift_type NONZERO
-st_pc_factor_shift_amount 1*     ( else I end up getting the "zero pivot
in LU factorization" error ).
I outputted my matrix to matlab and confirmed that the null space is empty
and the matrix is not singular. I am not sure why I'm getting this error.
Could you provide me a hint as to how to solve this problem.
Sincerely,
Pranay.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191130/0333a083/attachment.html>
