[petsc-users] Domain decomposition using DMPLEX
Danyang Su
danyang.su at gmail.com
Tue Nov 26 11:42:34 CST 2019
On 2019-11-25 7:54 p.m., Matthew Knepley wrote:
> On Mon, Nov 25, 2019 at 6:25 PM Swarnava Ghosh <swarnava89 at gmail.com
> <mailto:swarnava89 at gmail.com>> wrote:
> Dear PETSc users and developers,
> I am working with dmplex to distribute a 3D unstructured mesh made
> of tetrahedrons in a cuboidal domain. I had a few queries:
> 1) Is there any way of ensuring load balancing based on the number
> of vertices per MPI process.
> You can now call DMPlexRebalanceSharedPoints() to try and get better
> balance of vertices.
Hi Matt,
I just want to follow up if this new function can help to solve the
"Strange Partition in PETSc 3.11" problem I mentioned before. Would you
please let me know when shall I call this function? Right before
DMPlexDistribute?
call DMPlexCreateFromCellList
call DMPlexGetPartitioner
call PetscPartitionerSetFromOptions
call DMPlexDistribute
Danyang
> 2) As the global domain is cuboidal, is the resulting domain
> decomposition also cuboidal on every MPI process? If not, is there
> a way to ensure this? For example in DMDA, the default domain
> decomposition for a cuboidal domain is cuboidal.
> It sounds like you do not want something that is actually
> unstructured. Rather, it seems like you want to
> take a DMDA type thing and split it into tets. You can get a cuboidal
> decomposition of a hex mesh easily.
> Call DMPlexCreateBoxMesh() with one cell for every process,
> distribute, and then uniformly refine. This
> will not quite work for tets since the mesh partitioner will tend to
> violate that constraint. You could:
> a) Prescribe the distribution yourself using the Shell partitioner type
> or
> b) Write a refiner that turns hexes into tets
> We already have a refiner that turns tets into hexes, but we never
> wrote the other direction because it was not clear
> that it was useful.
> Thanks,
> Matt
> Sincerely,
> SG
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191126/b235e917/attachment-0001.html>
