[petsc-users] petsc without MPI
Smith, Barry F. bsmith at mcs.anl.gov
Tue Nov 26 00:27:45 CST 2019
  I agree this is confusing. https://gitlab.com/petsc/petsc/merge_requests/2331 the flag PETSC_HAVE_MPI will no longer be set when MPI is not used (only MPIUNI is used).
   Barry
  The code API still has MPI* in it with MPI but they are stubs that just handle the sequential code and do not require an installation of MPI.
> On Nov 19, 2019, at 2:07 PM, Povolotskyi, Mykhailo via petsc-users <petsc-users at mcs.anl.gov> wrote:
> I see.
> Actually, my goal is to compile petsc without real MPI to use it with libmesh.
> You are saying that PETSC_HAVE_MPI is not a sign that Petsc is built with MPI. It means you have MPIUNI which is a serial code, but has an interface of MPI.
> Correct?
> On 11/19/2019 3:00 PM, Matthew Knepley wrote:
>> On Tue, Nov 19, 2019 at 2:58 PM Povolotskyi, Mykhailo <mpovolot at purdue.edu> wrote:
>> Let me explain the problem.
>> This log file has
>> #ifndef PETSC_HAVE_MPI
>> #define PETSC_HAVE_MPI 1
>> #endif
>> while I need to have PETSC without MPI.
>> If you do not provide MPI, we provide MPIUNI. Do you see it linking to an MPI implementation, or using mpi.h?
>>     Matt
>> On 11/19/2019 2:55 PM, Matthew Knepley wrote:
>>> The log you sent has configure completely successfully. Please retry and send the log for a failed run.
>>>   Thanks,
>>>      Matt
>>> On Tue, Nov 19, 2019 at 2:53 PM Povolotskyi, Mykhailo via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> Why it did not work then?
>>> On 11/19/2019 2:51 PM, Balay, Satish wrote:
>>> > And I see from configure.log - you are using the correct option.
>>> > Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-scalar-type=real --with-x=0 --with-hdf5=0 --with-single-library=1 --with-shared-libraries=0 --with-log=0 --with-mpi=0 --with-clanguage=C++ --with-cxx-dialect=C++11 --CXXFLAGS="-fopenmp -fPIC" --CFLAGS="-fopenmp -fPIC" --with-fortran=0 --FFLAGS="-fopenmp -fPIC" --with-64-bit-indices=0 --with-debugging=0 --with-cc=gcc --with-fc=gfortran --with-cxx=g++ COPTFLAGS= CXXOPTFLAGS= FOPTFLAGS= --download-metis=0 --download-superlu_dist=0 --download-parmetis=0 --with-valgrind-dir=/apps/brown/valgrind/3.13.0_gcc-4.8.5 --download-mumps=1 --with-mumps-serial=1 --with-fortran-kernels=0 --with-blaslapack-lib="-Wl,-rpath,/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64  -L/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core " --with-blacs-lib=/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so --with-blacs-include=/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/include --with-scalapack=0
>>> > And configure completed successfully. What issue are you encountering? Why do you think its activating MPI?
>>> > Satish
>>> > On Tue, 19 Nov 2019, Balay, Satish via petsc-users wrote:
>>> >> On Tue, 19 Nov 2019, Povolotskyi, Mykhailo via petsc-users wrote:
>>> >>> Hello,
>>> >>> I'm trying to build PETSC without MPI.
>>> >>> Even if I specify --with_mpi=0, the configuration script still activates
>>> >>> MPI.
>>> >>> I attach the configure.log.
>>> >>> What am I doing wrong?
>>> >> The option is --with-mpi=0
>>> >> Satish
>>> >>> Thank you,
>>> >>> Michael.
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>> -- Norbert Wiener
