[petsc-users] Memory optimization
Mon Nov 25 11:48:52 CST 2019
On Mon, Nov 25, 2019 at 11:45 AM Perceval Desforges <
perceval.desforges at polytechnique.edu> wrote:
> I am basically trying to solve a finite element problem, which is why in
> 3D I have 7 non-zero diagonals that are quite farm apart from one another.
> In 2D I only have 5 non-zero diagonals that are less far apart. So is it
> normal that the set up time is around 400 times greater in the 3D case? Is
> there nothing to be done?
> No. It is almost certain that preallocation is screwed up. There is no way
it can take 400x longer for a few nonzeros.
In order to debug, please send the output of -log_view and indicate where
the time is taken for assembly. You can usually
track down bad preallocation using -info.
     Matt
> I will try setting up only one partition.
> Thanks,
> Perceval,
> Probably it is not a preallocation issue, as it shows "total number of
> mallocs used during MatSetValues calls =0".
> Adding new diagonals may increase fill-in a lot, if the new diagonals are
> displaced with respect to the other ones.
> The partitions option is intended for running several nodes. If you are
> using just one node probably it is better to set one partition only.
> Jose
> El 25 nov 2019, a las 18:25, Matthew Knepley <knepley at gmail.com> escribió:
> On Mon, Nov 25, 2019 at 11:20 AM Perceval Desforges <
> Hi,
> So I'm loading two matrices from files, both 1000000 by 10000000. I ran
> the program with -mat_view::ascii_info and I got:
> Mat Object: 1 MPI processes
>   type: seqaij
>   rows=1000000, cols=1000000
>   total: nonzeros=7000000, allocated nonzeros=7000000
>   total number of mallocs used during MatSetValues calls =0
>     not using I-node routines
> 20 times, and then
>   type: seqaij
>   total: nonzeros=1000000, allocated nonzeros=1000000
> 20 times as well, and then
>   type: seqaij
> 20 times as well before crashing.
> I realized it might be because I am setting up 20 krylov schur partitions
> which may be too much. I tried running the code again with only 2
> partitions and now the code runs but I have speed issues.
> I have one version of the code where my first matrix has 5 non-zero
> diagonals (so 5000000 non-zero entries), and the set up time is quite fast
> (8 seconds)  and solving is also quite fast. The second version is the same
> but I have two extra non-zero diagonals (7000000 non-zero entries)  and the
> set up time is a lot slower (2900 seconds ~ 50 minutes) and solving is also
> a lot slower. Is it normal that adding two extra diagonals increases solve
> and set up time so much?
> I can't see the rest of your code, but I am guessing your preallocation
> statement has "5", so it does no mallocs when you create
> your first matrix, but mallocs for every row when you create your second
> matrix. When you load them from disk, we do all the
> preallocation correctly.
>   Thanks,
>     Matt
> Thanks again,
> Best regards,
> Perceval,
> Then I guess it is the factorization that is failing. How many nonzero
> entries do you have? Run with
> -mat_view ::ascii_info
> Jose
> El 22 nov 2019, a las 19:56, Perceval Desforges <
> perceval.desforges at polytechnique.edu> escribió:
> Hi,
> Thanks for your answer. I tried looking at the inertias before solving,
> but the problem is that the program crashes when I call EPSSetUp with this
> error:
> slurmstepd: error: Step 2140.0 exceeded virtual memory limit (313526508 >
> 107317760), being killed
> I get this error even when there are no eigenvalues in the interval.
> I've started using BVMAT instead of BVVECS by the way.
> Thanks,
> Perceval,
> Don't use -mat_mumps_icntl_14 to reduce the memory used by MUMPS.
> Most likely the problem is that the interval you gave is too large and
> contains too many eigenvalues (SLEPc needs to allocate at least one vector
> per each eigenvalue). You can count the eigenvalues in the interval with
> the inertias, which are available at EPSSetUp (no need to call EPSSolve).
> See this example:
> http://slepc.upv.es/documentation/current/src/eps/examples/tutorials/ex25.c.html
> You can comment out the call to EPSSolve() and run with the option
> -show_inertias
> For example, the output
>    Shift 0.1  Inertia 3
>    Shift 0.35  Inertia 11
> means that the interval [0.1,0.35] contains 8 eigenvalues (=11-3).
> By the way, I would suggest using BVMAT instead of BVVECS (the latter is
> slower).
> Jose
> El 21 nov 2019, a las 18:13, Perceval Desforges via petsc-users <
> petsc-users at mcs.anl.gov> escribió:
> Hello all,
> I am trying to obtain all the eigenvalues in a certain interval for a
> fairly large matrix (1000000 * 1000000). I therefore use the spectrum
> slicing method detailed in section 3.4.5 of the manual. The calculations
> are run on a processor with 20 cores and 96 Go of RAM.
> The options I use are :
> -bv_type vecs  -eps_krylovschur_detect_zeros 1 -mat_mumps_icntl_13 1
> -mat_mumps_icntl_24 1 -mat_mumps_cntl_3 1e-12
> However the program quickly crashes with this error:
> slurmstepd: error: Step 2115.0 exceeded virtual memory limit (312121084 >
> I've tried reducing the amount of memory used by slepc with the
> -mat_mumps_icntl_14 option by setting it at -70 for example but then I get
> this error:
> [1]PETSC ERROR: Error in external library
> [1]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
> INFOG(1)=-9, INFO(2)=82733614
> which is an error due to setting the mumps icntl option so low from what
> I've gathered.
> Is there any other way I can reduce memory usage?
> Thanks,
> Regards,
> Perceval,
> P.S. I sent the same email a few minutes ago but I think I made a mistake
> in the address, I'm sorry if I've sent it twice.
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191125/ba5dea9c/attachment.html>
