[petsc-users] Memory optimization
Perceval Desforges
perceval.desforges at polytechnique.edu
Thu Nov 21 11:13:52 CST 2019
Hello all,
I am trying to obtain all the eigenvalues in a certain interval for a
fairly large matrix (1000000 * 1000000). I therefore use the spectrum
slicing method detailed in section 3.4.5 of the manual. The calculations
are run on a processor with 20 cores and 96 Go of RAM.
The options I use are :
-bv_type vecs -eps_krylovschur_detect_zeros 1 -mat_mumps_icntl_13 1
-mat_mumps_icntl_24 1 -mat_mumps_cntl_3 1e-12
However the program quickly crashes with this error:
slurmstepd: error: Step 2115.0 exceeded virtual memory limit (312121084
> 107317760), being killed
I've tried reducing the amount of memory used by slepc with the
-mat_mumps_icntl_14 option by setting it at -70 for example but then I
get this error:
[1]PETSC ERROR: Error in external library
[1]PETSC ERROR: Error reported by MUMPS in numerical factorization
phase: INFOG(1)=-9, INFO(2)=82733614
which is an error due to setting the mumps icntl option so low from what
I've gathered.
Is there any other way I can reduce memory usage?
Perceval,
P.S. I sent the same email a few minutes ago but I think I made a
mistake in the address, I'm sorry if I've sent it twice.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191121/620db702/attachment.html>
