[petsc-users] petsc without MPI
Povolotskyi, Mykhailo
mpovolot at purdue.edu
Tue Nov 19 13:51:42 CST 2019
On 11/19/2019 2:47 PM, Balay, Satish wrote:
> On Tue, 19 Nov 2019, Povolotskyi, Mykhailo via petsc-users wrote:
>> Hello,
>> I'm trying to build PETSC without MPI.
>> Even if I specify --with_mpi=0, the configuration script still activates
>> MPI.
>> I attach the configure.log.
>> What am I doing wrong?
> The option is --with-mpi=0
> Satish
>> Thank you,
>> Michael.
Dear Satish,
I actually used a correct one --with-mpi=0 (you can see the attached
configuration log output, the e-mail had a mistake), but it did not work.
Michael.
