[petsc-users] solve problem with pastix
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Nov 5 21:36:59 CST 2019
Google finds this https://gforge.inria.fr/forum/forum.php?thread_id=32824&forum_id=599&group_id=186
> On Nov 5, 2019, at 7:01 PM, Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov> wrote:
> I have no idea. That is a good question for the PasTix list.
> Thanks,
> Matt
> On Tue, Nov 5, 2019 at 5:32 PM hg <hgbk2008 at gmail.com> wrote:
> Should thread affinity be invoked? I set -mat_pastix_threadnbr 1 and also OMP_NUM_THREADS to 1
> Giang
> On Tue, Nov 5, 2019 at 10:50 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Nov 5, 2019 at 4:11 PM hg via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello
> I got crashed when using Pastix as solver for KSP. The error message looks like:
> NUMBER of BUBBLE 1
> COEFMAX 1735566 CPFTMAX 0 BPFTMAX 0 NBFTMAX 0 ARFTMAX 0
> ** End of Partition & Distribution phase **
> Time to analyze 0.225 s
> Number of nonzeros in factorized matrix 708784076
> Fill-in 12.2337
> Number of operations (LU) 2.80185e+12
> Prediction Time to factorize (AMD 6180 MKL) 394 s
> 0 : SolverMatrix size (without coefficients) 32.4 MB
> 0 : Number of nonzeros (local block structure) 365309391
> Numerical Factorization (LU) :
> 0 : Internal CSC size 1.08 GB
> Time to fill internal csc 6.66 s
> --- Sopalin : Allocation de la structure globale ---
> --- Fin Sopalin Init ---
> --- Initialisation des tableaux globaux ---
> sched_setaffinity: Invalid argument
> [node083:165071] *** Process received signal ***
> [node083:165071] Signal: Aborted (6)
> [node083:165071] Signal code: (-6)
> [node083:165071] [ 0] /lib64/libpthread.so.0(+0xf680)[0x2b8081845680]
> [node083:165071] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b8082191207]
> [node083:165071] [ 2] /lib64/libc.so.6(abort+0x148)[0x2b80821928f8]
> [node083:165071] [ 3] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_comm+0x0)[0x2b80a4124c9d]
> [node083:165071] [ 4] Launching 1 threads (1 commputation, 0 communication, 0 out-of-core)
> --- Sopalin : Local structure allocation ---
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_sopalin_init_smp+0x29b)[0x2b80a40c39d2]
> [node083:165071] [ 5] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_smp+0x68)[0x2b80a40cf4c2]
> [node083:165071] [ 6] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_thread+0x4ba)[0x2b80a4124a31]
> [node083:165071] [ 7] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_thread+0x94)[0x2b80a40d6170]
> [node083:165071] [ 8] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_pastix_task_sopalin+0x5ad)[0x2b80a40b09a2]
> [node083:165071] [ 9] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(d_pastix+0xa8a)[0x2b80a40b2325]
> [node083:165071] [10] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0x63927b)[0x2b80a35bf27b]
> [node083:165071] [11] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(MatLUFactorNumeric+0x19a)[0x2b80a32c7552]
> [node083:165071] [12] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0xa46c09)[0x2b80a39ccc09]
> [node083:165071] [13] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(PCSetUp+0x311)[0x2b80a3a8f1a9]
> [node083:165071] [14] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSetUp+0xbf7)[0x2b80a3b46e81]
> [node083:165071] [15] /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSolve+0x210)[0x2b80a3b4746e]
> Does anyone have an idea what is the problem and how to fix it? The PETSc parameters I used are as below:
> It looks like PasTix is having trouble setting the thread affinity:
> so it may be your build of PasTix.
> Thanks,
> Matt
> -pc_type lu
> -pc_factor_mat_solver_package pastix
> -mat_pastix_verbose 2
> Giang
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
