[petsc-users] solve problem with pastix
    Matthew Knepley
    knepley at gmail.com
    Tue Nov  5 15:49:52 CST 2019
On Tue, Nov 5, 2019 at 4:11 PM hg via petsc-users <petsc-users at mcs.anl.gov>
wrote:
> Hello
> I got crashed when using Pastix as solver for KSP. The error message looks
> like:
> NUMBER of BUBBLE 1
> COEFMAX 1735566 CPFTMAX 0 BPFTMAX 0 NBFTMAX 0 ARFTMAX 0
> ** End of Partition & Distribution phase **
>    Time to analyze                              0.225 s
>    Number of nonzeros in factorized matrix      708784076
>    Fill-in                                      12.2337
>    Number of operations (LU)                    2.80185e+12
>    Prediction Time to factorize (AMD 6180  MKL) 394 s
> 0 : SolverMatrix size (without coefficients)    32.4 MB
> 0 : Number of nonzeros (local block structure)  365309391
>  Numerical Factorization (LU) :
> 0 : Internal CSC size                           1.08 GB
>    Time to fill internal csc                    6.66 s
>    --- Sopalin : Allocation de la structure globale ---
>    --- Fin Sopalin Init                             ---
>    --- Initialisation des tableaux globaux          ---
> sched_setaffinity: Invalid argument
> [node083:165071] *** Process received signal ***
> [node083:165071] Signal: Aborted (6)
> [node083:165071] Signal code:  (-6)
> [node083:165071] [ 0] /lib64/libpthread.so.0(+0xf680)[0x2b8081845680]
> [node083:165071] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b8082191207]
> [node083:165071] [ 2] /lib64/libc.so.6(abort+0x148)[0x2b80821928f8]
> [node083:165071] [ 3]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_comm+0x0)[0x2b80a4124c9d]
> [node083:165071] [ 4] Launching 1 threads (1 commputation, 0
> communication, 0 out-of-core)
>    --- Sopalin : Local structure allocation         ---
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_sopalin_init_smp+0x29b)[0x2b80a40c39d2]
> [node083:165071] [ 5]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_smp+0x68)[0x2b80a40cf4c2]
> [node083:165071] [ 6]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(sopalin_launch_thread+0x4ba)[0x2b80a4124a31]
> [node083:165071] [ 7]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_ge_sopalin_thread+0x94)[0x2b80a40d6170]
> [node083:165071] [ 8]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(D_pastix_task_sopalin+0x5ad)[0x2b80a40b09a2]
> [node083:165071] [ 9]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(d_pastix+0xa8a)[0x2b80a40b2325]
> [node083:165071] [10]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0x63927b)[0x2b80a35bf27b]
> [node083:165071] [11]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(MatLUFactorNumeric+0x19a)[0x2b80a32c7552]
> [node083:165071] [12]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(+0xa46c09)[0x2b80a39ccc09]
> [node083:165071] [13]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(PCSetUp+0x311)[0x2b80a3a8f1a9]
> [node083:165071] [14]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSetUp+0xbf7)[0x2b80a3b46e81]
> [node083:165071] [15]
> /sdhome/bui/opt/petsc-3.11.0_ompi-3.0.0/lib/libpetsc.so.3.11(KSPSolve+0x210)[0x2b80a3b4746e]
> Does anyone have an idea what is the problem and how to fix it? The PETSc
> parameters I used are as below:
It looks like PasTix is having trouble setting the thread affinity:
so it may be your build of PasTix.
     Matt
> -pc_type lu
> -pc_factor_mat_solver_package pastix
> -mat_pastix_verbose 2
> -mat_pastix_threadnbr 1
> Giang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191105/cccc92ef/attachment.html>
