[petsc-users] Select a preconditioner for SLEPc eigenvalue solver Jacobi-Davidson
Fande Kong
fdkong.jd at gmail.com
Tue Nov 5 11:55:50 CST 2019
OK, I figured it out!
I need to add the code :
ierr = EPSGetST(eps,&st);CHKERRQ(ierr);
ierr = STPrecondSetMatForPC(st,B);CHKERRQ(ierr);
after ierr = EPSSetFromOptions(eps);CHKERRQ(ierr);
It might be a good idea to document this if we intend to do so.
Fande,
On Tue, Nov 5, 2019 at 10:33 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> JD sets STPRECOND at EPSSetUp(), if it was not set before. So I guess you
> need to add -st_type precond on the command line, so that it is set at
> EPSSetFromOptions().
> Jose
> > El 5 nov 2019, a las 18:13, Fande Kong <fdkong.jd at gmail.com> escribió:
> > How about I want to determine the ST type on runtime?
> > mpirun -n 1 ./ex3 -eps_type jd -st_ksp_type gmres -st_pc_type none
> -eps_view -eps_target 0 -eps_monitor -st_ksp_monitor
> > ST is indeed STPrecond, but the passed preconditioning matrix is still
> ignored.
> > EPS Object: 1 MPI processes
> > type: jd
> > search subspace is orthogonalized
> > block size=1
> > type of the initial subspace: non-Krylov
> > size of the subspace after restarting: 6
> > number of vectors after restarting from the previous iteration: 1
> > threshold for changing the target in the correction equation (fix):
> 0.01
> > problem type: symmetric eigenvalue problem
> > selected portion of the spectrum: closest to target: 0. (in magnitude)
> > number of eigenvalues (nev): 1
> > number of column vectors (ncv): 17
> > maximum dimension of projected problem (mpd): 17
> > maximum number of iterations: 1700
> > tolerance: 1e-08
> > convergence test: relative to the eigenvalue
> > BV Object: 1 MPI processes
> > type: svec
> > 17 columns of global length 100
> > vector orthogonalization method: classical Gram-Schmidt
> > orthogonalization refinement: if needed (eta: 0.7071)
> > block orthogonalization method: GS
> > doing matmult as a single matrix-matrix product
> > DS Object: 1 MPI processes
> > type: hep
> > solving the problem with: Implicit QR method (_steqr)
> > ST Object: 1 MPI processes
> > type: precond
> > shift: 0.
> > number of matrices: 1
> > KSP Object: (st_) 1 MPI processes
> > type: gmres
> > restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> > happy breakdown tolerance 1e-30
> > maximum iterations=90, initial guess is zero
> > tolerances: relative=0.0001, absolute=1e-50, divergence=10000.
> > left preconditioning
> > using PRECONDITIONED norm type for convergence test
> > PC Object: (st_) 1 MPI processes
> > type: none
> > linear system matrix = precond matrix:
> > Mat Object: 1 MPI processes
> > type: shell
> > rows=100, cols=100
> > Solution method: jd
> > Preconding matrix should be a SeqAIJ not shell.
> > Fande,
> > On Tue, Nov 5, 2019 at 9:07 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > Currently, the function that passes the preconditioner matrix is
> specific of STPRECOND, so you have to add
> > ierr = STSetType(st,STPRECOND);CHKERRQ(ierr);
> > before
> > otherwise this latter call is ignored.
> > We may be changing a little bit the way in which ST is initialized, and
> maybe we modify this as well. It is not decided yet.
> > Jose
> > > El 5 nov 2019, a las 0:28, Fande Kong <fdkong.jd at gmail.com> escribió:
> > > Thanks Jose,
> > > I think I understand now. Another question: what is the right way to
> setup a linear preconditioning matrix for the inner linear solver of JD?
> > > I was trying to do something like this:
> > > Create eigensolver context
> > > ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRQ(ierr);
> > > Set operators. In this case, it is a standard eigenvalue problem
> > > ierr = EPSSetOperators(eps,A,NULL);CHKERRQ(ierr);
> > > ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRQ(ierr);
> > > Set solver parameters at runtime
> > > Solve the eigensystem
> > > ierr = EPSSolve(eps);CHKERRQ(ierr);
> > > But did not work. A complete example is attached. I could try to dig
> into the code, but you may already know the answer.
> > > On Wed, Oct 23, 2019 at 3:58 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > Yes, it is confusing. Here is the explanation: when you use a target,
> the preconditioner is built from matrix A-sigma*B. By default, instead of
> TARGET_MAGNITUDE we set LARGEST_MAGNITUDE, and in Jacobi-Davidson we treat
> this case by setting sigma=PETSC_MAX_REAL. In this case, the preconditioner
> is built from matrix B. The thing is that in a standard eigenproblem we
> have B=I, and hence there is no point in using a preconditioner, that is
> why we set PCNONE.
> > > Jose
> > > > El 22 oct 2019, a las 19:57, Fande Kong via petsc-users <
> petsc-users at mcs.anl.gov> escribió:
> > > > Hi All,
> > > > It looks like the preconditioner is hard-coded in the
> Jacobi-Davidson solver. I could not select a preconditioner rather than the
> default setting.
> > > > For example, I was trying to select LU, but PC NONE was still used.
> I ran standard example 2 in slepc/src/eps/examples/tutorials, and had the
> following results.
> > > > Thanks,
> > > > Fande
> > > > ./ex2 -eps_type jd -st_ksp_type gmres -st_pc_type lu -eps_view
> > > > 2-D Laplacian Eigenproblem, N=100 (10x10 grid)
> > > > type: jd
> > > > block size=1
> (fix): 0.01
> > > > selected portion of the spectrum: largest eigenvalues in magnitude
> > > > tolerance: 1e-08
> > > > type: svec
> > > > type: hep
> > > > type: precond
> > > > shift: 1.79769e+308
> > > > type: gmres
> > > > type: none
> > > > type: shell
> > > > rows=100, cols=100
> > > > Solution method: jd
> > > > Number of requested eigenvalues: 1
> > > > Linear eigensolve converged (1 eigenpair) due to CONVERGED_TOL;
> iterations 20
> > > > k ||Ax-kx||/||kx||
> > > > 7.837972 7.71944e-10
> > > <ex3.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191105/84dd2f2a/attachment-0001.html>
