[petsc-users] doubts on VecScatterCreate
Emmanuel Ayala juaneah at gmail.com
Sun Nov 3 23:49:38 CST 2019
*I mean, the portion for A look like messy distribution, as if scatter was
done wrong*
El dom., 3 de nov. de 2019 a la(s) 23:41, Emmanuel Ayala (juaneah at gmail.com)
escribió:
> Hi everyone, thanks in advance.
> I have three parallel vectors: A, B and C. A and B have different sizes,
> and C must be contain these two vectors (MatLab notation C=[A;B]). I need
> to do some operations on C then put back the proper portion of C on A and
> B, then I do some computations on A and B y put again on C, and the loop
> repeats.
> For these propose I use Scatters:
> C is created as a parallel vector with size of (sizeA + sizeB) with
> petsc_decide for parallel layout. The vectors have been distributed on the
> same amount of processes.
> For the specific case with order [A;B]
> VecGetOwnershipRange(A,&start,&end);
> ISCreateStride(MPI_COMM_WORLD,(end-start),start,1,&is_fromA);
> ISCreateStride(MPI_COMM_WORLD,(end-start),start,1,&is_toC1);// this is
> redundant
> VecScatterCreate(A,is_fromA,C,is_toC1,&scatter1);
> VecGetSize(A,&sizeA)
> VecGetOwnershipRange(B,&start,&end);
> ISCreateStride(MPI_COMM_WORLD,(end-start),start,1,&is_fromB);
> ISCreateStride(MPI_COMM_WORLD,(end-start),(start+sizeA),1,&is_toC2);
> //shifts the index location
> VecScatterCreate(B,is_fromB,C,is_toC2,&scatter2);
> Then I can use
> VecScatterBegin(scatter1,A,C,INSERT_VALUES,SCATTER_FORWARD);
> VecScatterEnd(scatter1,A,C,INSERT_VALUES,SCATTER_FORWARD);
> and
> VecScatterBegin(scatter1,C,A,INSERT_VALUES,SCATTER_REVERSE);
> VecScatterEnd(scatter1,C,A,INSERT_VALUES,SCATTER_REVERSE);
> and the same with B.
> I used MPI_COMM SELF and I got the same results.
> *The situation is: My results look good for the portion of B, but no for
> the portion of A, there is something that I'm doing wrong with the
> scattering?*
> Best regards.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191103/3dfd4f18/attachment.html>
