[petsc-users] Memory growth issue
Zhang, Junchao jczhang at mcs.anl.gov
Fri May 31 16:17:34 CDT 2019
On Fri, May 31, 2019 at 3:48 PM Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Thanks Stefano.
Reading the manual pages a bit more carefully,
I think I can see what I should be doing.  Which should be roughly to
1. Set up target Seq vectors on PETSC_COMM_SELF
2. Use ISCreateGeneral to create ISs for the target Vecs  and the source Vec which will be MPI on PETSC_COMM_WORLD.
3. Create the scatter context with VecScatterCreate
4. Call VecScatterBegin/End on each process (instead of using my prior routine).
Lingering questions:
a. Is there any performance advantage/disadvantage to creating a single parallel target Vec instead
of multiple target Seq Vecs (in terms of the scatter operation)?
No performance difference. But pay attention, if you use seq vec, the indices in IS are locally numbered; if you use MPI vec, the indices are globally numbered.
b. The data that ends up in the target on each processor needs to be in an application
array.  Is there a clever way to 'move' the data from the scatter target to the array (short
of just running a loop over it and copying)?
See VecGetArray, VecGetArrayRead etc, which pull the data out of Vecs without memory copying.
 -sanjay
On 5/31/19 12:02 PM, Stefano Zampini wrote:
On May 31, 2019, at 9:50 PM, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Matt,
  Here is the process as it currently stands:
1) I have a PETSc Vec (sol), which come from a KSPSolve
2) Each processor grabs its section of sol via VecGetOwnershipRange and VecGetArrayReadF90
and inserts parts of its section of sol in a local array (locarr) using a complex but easily computable mapping.
3) The routine you are looking at then exchanges various parts of the locarr between the processors.
You need a VecScatter object https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreate.html#VecScatterCreate
4) Each processor then does computations using its updated locarr.
Typing it out this way, I guess the answer to your question is "yes."  I have a global Vec and I want its values
sent in a complex but computable way to local vectors on each process.
-sanjay
On 5/31/19 3:37 AM, Matthew Knepley wrote:
On Thu, May 30, 2019 at 11:55 PM Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi Juanchao,
Thanks for the hints below, they will take some time to absorb as the vectors that are being  moved around
are actually partly petsc vectors and partly local process vectors.
Is this code just doing a global-to-local map? Meaning, does it just map all the local unknowns to some global
unknown on some process? We have an even simpler interface for that, where we make the VecScatter
automatically,
  https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html#ISLocalToGlobalMappingCreate
Then you can use it with Vecs, Mats, etc.
     Matt
Attached is the modified routine that now works (on leaking memory) with openmpi.
-sanjay
On 5/30/19 8:41 PM, Zhang, Junchao wrote:
Hi, Sanjay,
  Could you send your modified data exchange code (psetb.F) with MPI_Waitall? See other inlined comments below. Thanks.
On Thu, May 30, 2019 at 1:49 PM Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Lawrence,
Thanks for taking a look!  This is what I had been wondering about -- my
knowledge of MPI is pretty minimal and
this origins of the routine were from a programmer we hired a decade+
back from NERSC.  I'll have to look into
VecScatter.  It will be great to dispense with our roll-your-own
routines (we even have our own reduceALL scattered around the code).
Petsc VecScatter has a very simple interface and you definitely should go with.  With VecScatter, you can think in familiar vectors and indices instead of the low level MPI_Send/Recv. Besides that, PETSc has optimized VecScatter so that communication is efficient.
Interestingly, the MPI_WaitALL has solved the problem when using OpenMPI
but it still persists with MPICH.  Graphs attached.
I'm going to run with openmpi for now (but I guess I really still need
to figure out what is wrong with MPICH and WaitALL;
I'll try Barry's suggestion of
--download-mpich-configure-arguments="--enable-error-messages=all
--enable-g" later today and report back).
Regarding MPI_Barrier, it was put in due a problem that some processes
were finishing up sending and receiving and exiting the subroutine
before the receiving processes had completed (which resulted in data
loss as the buffers are freed after the call to the routine).
MPI_Barrier was the solution proposed
to us.  I don't think I can dispense with it, but will think about some
more.
After MPI_Send(), or after MPI_Isend(..,req) and MPI_Wait(req), you can safely free the send buffer without worry that the receive has not completed. MPI guarantees the receiver can get the data, for example, through internal buffering.
I'm not so sure about using MPI_IRecv as it will require a bit of
rewriting since right now I process the received
data sequentially after each blocking MPI_Recv -- clearly slower but
easier to code.
Thanks again for the help.
-sanjay
On 5/30/19 4:48 AM, Lawrence Mitchell wrote:
> Hi Sanjay,
>> On 30 May 2019, at 08:58, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
>> The problem seems to persist but with a different signature.  Graphs attached as before.
>> Totals with MPICH (NB: single run)
>> For the CG/Jacobi          data_exchange_total = 41,385,984; kspsolve_total = 38,289,408
>> For the GMRES/BJACOBI      data_exchange_total = 41,324,544; kspsolve_total = 41,324,544
>> Just reading the MPI docs I am wondering if I need some sort of MPI_Wait/MPI_Waitall before my MPI_Barrier in the data exchange routine?
>> I would have thought that with the blocking receives and the MPI_Barrier that everything will have fully completed and cleaned up before
>> all processes exited the routine, but perhaps I am wrong on that.
> Skimming the fortran code you sent you do:
> for i in ...:
>     call MPI_Isend(..., req, ierr)
> for i in ...:
>     call MPI_Recv(..., ierr)
> But you never call MPI_Wait on the request you got back from the Isend. So the MPI library will never free the data structures it created.
> The usual pattern for these non-blocking communications is to allocate an array for the requests of length nsend+nrecv and then do:
> for i in nsend:
>     call MPI_Isend(..., req[i], ierr)
> for j in nrecv:
>     call MPI_Irecv(..., req[nsend+j], ierr)
> call MPI_Waitall(req, ..., ierr)
> I note also there's no need for the Barrier at the end of the routine, this kind of communication does neighbourwise synchronisation, no need to add (unnecessary) global synchronisation too.
> As an aside, is there a reason you don't use PETSc's VecScatter to manage this global to local exchange?
> Cheers,
> Lawrence
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190531/345ca6b7/attachment.html>
