[petsc-users] Memory growth issue
Stefano Zampini stefano.zampini at gmail.com
Fri May 31 14:02:27 CDT 2019
> On May 31, 2019, at 9:50 PM, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Matt,
>   Here is the process as it currently stands:
> 1) I have a PETSc Vec (sol), which come from a KSPSolve
> 2) Each processor grabs its section of sol via VecGetOwnershipRange and VecGetArrayReadF90
> and inserts parts of its section of sol in a local array (locarr) using a complex but easily computable mapping.
> 3) The routine you are looking at then exchanges various parts of the locarr between the processors.
You need a VecScatter object https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreate.html#VecScatterCreate <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreate.html#VecScatterCreate>
> 4) Each processor then does computations using its updated locarr.
> Typing it out this way, I guess the answer to your question is "yes."  I have a global Vec and I want its values
> sent in a complex but computable way to local vectors on each process.
> -sanjay
> On 5/31/19 3:37 AM, Matthew Knepley wrote:
>> On Thu, May 30, 2019 at 11:55 PM Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> Hi Juanchao,
>> Thanks for the hints below, they will take some time to absorb as the vectors that are being  moved around
>> are actually partly petsc vectors and partly local process vectors.
>> Is this code just doing a global-to-local map? Meaning, does it just map all the local unknowns to some global
>> unknown on some process? We have an even simpler interface for that, where we make the VecScatter
>> automatically,
>>   https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html#ISLocalToGlobalMappingCreate <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html#ISLocalToGlobalMappingCreate>
>> Then you can use it with Vecs, Mats, etc.
>>   Thanks,
>>      Matt
>> Attached is the modified routine that now works (on leaking memory) with openmpi.
>> -sanjay
>> On 5/30/19 8:41 PM, Zhang, Junchao wrote:
>>> Hi, Sanjay,
>>>   Could you send your modified data exchange code (psetb.F) with MPI_Waitall? See other inlined comments below. Thanks.
>>> On Thu, May 30, 2019 at 1:49 PM Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>> Lawrence,
>>> Thanks for taking a look!  This is what I had been wondering about -- my
>>> knowledge of MPI is pretty minimal and
>>> this origins of the routine were from a programmer we hired a decade+
>>> back from NERSC.  I'll have to look into
>>> VecScatter.  It will be great to dispense with our roll-your-own
>>> routines (we even have our own reduceALL scattered around the code).
>>> Petsc VecScatter has a very simple interface and you definitely should go with.  With VecScatter, you can think in familiar vectors and indices instead of the low level MPI_Send/Recv. Besides that, PETSc has optimized VecScatter so that communication is efficient.
>>> Interestingly, the MPI_WaitALL has solved the problem when using OpenMPI
>>> but it still persists with MPICH.  Graphs attached.
>>> I'm going to run with openmpi for now (but I guess I really still need
>>> to figure out what is wrong with MPICH and WaitALL;
>>> I'll try Barry's suggestion of
>>> --download-mpich-configure-arguments="--enable-error-messages=all
>>> --enable-g" later today and report back).
>>> Regarding MPI_Barrier, it was put in due a problem that some processes
>>> were finishing up sending and receiving and exiting the subroutine
>>> before the receiving processes had completed (which resulted in data
>>> loss as the buffers are freed after the call to the routine).
>>> MPI_Barrier was the solution proposed
>>> to us.  I don't think I can dispense with it, but will think about some
>>> more.
>>> After MPI_Send(), or after MPI_Isend(..,req) and MPI_Wait(req), you can safely free the send buffer without worry that the receive has not                       completed. MPI guarantees the receiver can get the data, for example, through internal buffering.
>>> I'm not so sure about using MPI_IRecv as it will require a bit of
>>> rewriting since right now I process the received
>>> data sequentially after each blocking MPI_Recv -- clearly slower but
>>> easier to code.
>>> Thanks again for the help.
>>> -sanjay
>>> On 5/30/19 4:48 AM, Lawrence Mitchell wrote:
>>> > Hi Sanjay,
>>> >> On 30 May 2019, at 08:58, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>> >> The problem seems to persist but with a different signature.  Graphs attached as before.
>>> >> Totals with MPICH (NB: single run)
>>> >> For the CG/Jacobi          data_exchange_total = 41,385,984; kspsolve_total = 38,289,408
>>> >> For the GMRES/BJACOBI      data_exchange_total = 41,324,544; kspsolve_total = 41,324,544
>>> >> Just reading the MPI docs I am wondering if I need some sort of MPI_Wait/MPI_Waitall before my MPI_Barrier in the data exchange routine?
>>> >> I would have thought that with the blocking receives and the MPI_Barrier that everything will have fully completed and cleaned up before
>>> >> all processes exited the routine, but perhaps I am wrong on that.
>>> > Skimming the fortran code you sent you do:
>>> > for i in ...:
>>> >     call MPI_Isend(..., req, ierr)
>>> > for i in ...:
>>> >     call MPI_Recv(..., ierr)
>>> > But you never call MPI_Wait on the request you got back from the Isend. So the MPI library will never free the data structures it created.
>>> > The usual pattern for these non-blocking communications is to allocate an array for the requests of length nsend+nrecv and then do:
>>> > for i in nsend:
>>> >     call MPI_Isend(..., req[i], ierr)
>>> > for j in nrecv:
>>> >     call MPI_Irecv(..., req[nsend+j], ierr)
>>> > call MPI_Waitall(req, ..., ierr)
>>> > I note also there's no need for the Barrier at the end of the routine, this kind of communication does neighbourwise synchronisation, no need to add (unnecessary) global synchronisation too.
>>> > As an aside, is there a reason you don't use PETSc's VecScatter to manage this global to local exchange?
>>> > Cheers,
>>> > Lawrence
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190531/918ca56f/attachment.html>
