[petsc-users] Configuration process of Petsc hanging
Balay, Satish balay at mcs.anl.gov
Fri May 31 13:35:15 CDT 2019
PETSc configure is attempting to run some MPI binaries - and that is hanging with this MPI.
You can retry with the options:
 --batch=1 --known-64-bit-blas-indices=0 -known-mpi-shared-libraries=0
[and follow instructions provided by configure]
Satish
On Fri, 31 May 2019, Ma, Xiao via petsc-users wrote:
> Hi ,
> I am trying to install Pylith which is a earthquake simulator using Petsc library, I am building it in PSC bridge cluster, during the steps of building Petsc, the configuration hanging at
> TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:247)
> I am not sure if this has to with the configuration setup of the mpi version I am using.
> Any help would be deeply appreciated.
> I am attaching the configure options here:
> Saving to: ‘petsc-pylith-2.2.1.tgz’
> 100%[===========================================================>] 10,415,016  37.3MB/s   in 0.3s
> 2019-05-31 14:03:13 (37.3 MB/s) - ‘petsc-pylith-2.2.1.tgz’ saved [10415016/10415016]
> FINISHED --2019-05-31 14:03:13--
> Total wall clock time: 1.1s
> Downloaded: 1 files, 9.9M in 0.3s (37.3 MB/s)
> /usr/bin/tar -zxf petsc-pylith-2.2.1.tgz
> cd petsc-pylith && \
>         ./configure --prefix=/home/xm12345/pylith \
>                 --with-c2html=0 --with-x=0 \
>                 --with-clanguage=C \
>                 --with-mpicompilers=1 \
>                 --with-shared-libraries=1 --with-64-bit-points=1 --with-large-file-io=1 \
>                 --download-chaco=1 --download-ml=1 --download-f2cblaslapack=1 --with-hdf5=1    --with                     -debugging=0  --with-fc=0 CPPFLAGS="-I/home/xm12345/pylith/include -I/home/xm12345/pylith/include " L                     DFLAGS="-L/home/xm12345/pylith/lib -L/home/xm12345/pylith/lib64 -L/home/xm12345/pylith/lib -L/home/xm                     12345/pylith/lib64 " CFLAGS="-g -O2" CXXFLAGS="-g -O2 -DMPICH_IGNORE_CXX_SEEK" FCFLAGS="" \
>                 PETSC_DIR=/home/xm12345/build/pylith/petsc-pylith PETSC_ARCH=arch-pylith && \
>         make -f gmakefile -j2 PETSC_DIR=/home/xm12345/build/pylith/petsc-pylith PETSC_ARCH=arch-pylit                     h && \
>         make PETSC_DIR=/home/xm12345/build/pylith/petsc-pylith install && \
>         make PETSC_DIR=/home/xm12345/build/pylith/petsc-pylith test && \
>         touch ../installed_petsc
>              Configuring PETSc to compile on your system
> ===============================================================================                                                 ***** WARNING: MAKEFLAGS (set to w) found in environment variables - ignoring                                              use ./configure MAKEFLAGS=$MAKEFLAGS if you really want to use that value ******                                   ===============================================================================                                           ===============================================================================                                                           WARNING! Compiling PETSc with no debugging, this should        only be done for timing and production runs. All development should                                                       be done when configured using --with-debugging=1                                                    ===============================================================================                                           TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:247)
