[petsc-users] Memory growth issue
Sanjay Govindjee
s_g at berkeley.edu
Thu May 30 15:31:00 CDT 2019
1) Correct: Placing a WaitAll before the MPI_Barrier solve the problem
in our send-get routine for OPENMPI
2) Correct: The problem persists with KSPSolve
3) Correct: WaitAll did not fix the problem in our send-get nor in
KSPSolve when using MPICH
Also correct. Commenting out the call to KSPSolve results in zero
memory growth on OPENMPI.
On 5/30/19 11:59 AM, Smith, Barry F. wrote:
> Thanks for the update. So the current conclusions are that using the Waitall in your code
> 1) solves the memory issue with OpenMPI in your code
> 2) does not solve the memory issue with PETSc KSPSolve
> 3) MPICH has memory issues both for your code and PETSc KSPSolve (despite) the wait all fix?
> If you literately just comment out the call to KSPSolve() with OpenMPI is there no growth in memory usage?
> Both 2 and 3 are concerning, indicate possible memory leak bugs in MPICH and not freeing all MPI resources in KSPSolve()
> Junchao, can you please investigate 2 and 3 with, for example, a TS example that uses the linear solver (like with -ts_type beuler)? Thanks
> Barry
>> On May 30, 2019, at 1:47 PM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
>> Lawrence,
>> Thanks for taking a look! This is what I had been wondering about -- my knowledge of MPI is pretty minimal and
>> this origins of the routine were from a programmer we hired a decade+ back from NERSC. I'll have to look into
>> VecScatter. It will be great to dispense with our roll-your-own routines (we even have our own reduceALL scattered around the code).
>> Interestingly, the MPI_WaitALL has solved the problem when using OpenMPI but it still persists with MPICH. Graphs attached.
>> I'm going to run with openmpi for now (but I guess I really still need to figure out what is wrong with MPICH and WaitALL;
>> I'll try Barry's suggestion of --download-mpich-configure-arguments="--enable-error-messages=all --enable-g" later today and report back).
>> Regarding MPI_Barrier, it was put in due a problem that some processes were finishing up sending and receiving and exiting the subroutine
>> before the receiving processes had completed (which resulted in data loss as the buffers are freed after the call to the routine). MPI_Barrier was the solution proposed
>> to us. I don't think I can dispense with it, but will think about some more.
>> I'm not so sure about using MPI_IRecv as it will require a bit of rewriting since right now I process the received
>> data sequentially after each blocking MPI_Recv -- clearly slower but easier to code.
>> Thanks again for the help.
>> -sanjay
>> On 5/30/19 4:48 AM, Lawrence Mitchell wrote:
>>> Hi Sanjay,
>>>> On 30 May 2019, at 08:58, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>> The problem seems to persist but with a different signature. Graphs attached as before.
>>>> Totals with MPICH (NB: single run)
>>>> For the CG/Jacobi data_exchange_total = 41,385,984; kspsolve_total = 38,289,408
>>>> For the GMRES/BJACOBI data_exchange_total = 41,324,544; kspsolve_total = 41,324,544
>>>> Just reading the MPI docs I am wondering if I need some sort of MPI_Wait/MPI_Waitall before my MPI_Barrier in the data exchange routine?
>>>> I would have thought that with the blocking receives and the MPI_Barrier that everything will have fully completed and cleaned up before
>>>> all processes exited the routine, but perhaps I am wrong on that.
>>> Skimming the fortran code you sent you do:
>>> for i in ...:
>>> call MPI_Isend(..., req, ierr)
>>> for i in ...:
>>> call MPI_Recv(..., ierr)
>>> But you never call MPI_Wait on the request you got back from the Isend. So the MPI library will never free the data structures it created.
>>> The usual pattern for these non-blocking communications is to allocate an array for the requests of length nsend+nrecv and then do:
>>> for i in nsend:
>>> call MPI_Isend(..., req[i], ierr)
>>> for j in nrecv:
>>> call MPI_Irecv(..., req[nsend+j], ierr)
>>> call MPI_Waitall(req, ..., ierr)
>>> I note also there's no need for the Barrier at the end of the routine, this kind of communication does neighbourwise synchronisation, no need to add (unnecessary) global synchronisation too.
>>> As an aside, is there a reason you don't use PETSc's VecScatter to manage this global to local exchange?
>>> Cheers,
>>> Lawrence
>> <cg_mpichwall.png><cg_wall.png><gmres_mpichwall.png><gmres_wall.png>
