[petsc-users] Memory growth issue
Smith, Barry F. bsmith at mcs.anl.gov
Thu May 30 10:16:45 CDT 2019
  Great observation Lawrence. https://www.slideshare.net/jsquyres/friends-dont-let-friends-leak-mpirequests
  You can add the following option to --download-mpich
--download-mpich-configure-arguments="--enable-error-messages=all --enable-g"
  then MPICH will report all MPI resources that have not been freed during the run. This helps catching missing waits, etc. We have a nightly test that utilizes this for the PETSc libraries.
   Barry
> On May 30, 2019, at 6:48 AM, Lawrence Mitchell <wence at gmx.li> wrote:
> Hi Sanjay,
>> On 30 May 2019, at 08:58, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> The problem seems to persist but with a different signature.  Graphs attached as before.
>> Totals with MPICH (NB: single run)
>> For the CG/Jacobi          data_exchange_total = 41,385,984; kspsolve_total = 38,289,408
>> For the GMRES/BJACOBI      data_exchange_total = 41,324,544; kspsolve_total = 41,324,544
>> Just reading the MPI docs I am wondering if I need some sort of MPI_Wait/MPI_Waitall before my MPI_Barrier in the data exchange routine?
>> I would have thought that with the blocking receives and the MPI_Barrier that everything will have fully completed and cleaned up before
>> all processes exited the routine, but perhaps I am wrong on that.
> Skimming the fortran code you sent you do:
> for i in ...:
>   call MPI_Isend(..., req, ierr)
> for i in ...:
>   call MPI_Recv(..., ierr)
> But you never call MPI_Wait on the request you got back from the Isend. So the MPI library will never free the data structures it created.
> The usual pattern for these non-blocking communications is to allocate an array for the requests of length nsend+nrecv and then do:
> for i in nsend:
>   call MPI_Isend(..., req[i], ierr)
> for j in nrecv:
>   call MPI_Irecv(..., req[nsend+j], ierr)
> call MPI_Waitall(req, ..., ierr)
> I note also there's no need for the Barrier at the end of the routine, this kind of communication does neighbourwise synchronisation, no need to add (unnecessary) global synchronisation too.
> As an aside, is there a reason you don't use PETSc's VecScatter to manage this global to local exchange?
> Cheers,
> Lawrence
