[petsc-users] Memory growth issue
Sanjay Govindjee
s_g at berkeley.edu
Thu May 30 02:01:18 CDT 2019
I put in calls to PetscMemoryGetCurrentUsage( ) around KSPSolve and my
data exchange routine. The problem is clearly mostly in my data
exchange routine.
Attached are graphs of the change in memory for each call. Lots of
calls have zero change, but on a periodic regular basis the memory goes
up from the data exchange; much less
so with the KSPSolve calls (and then mostly on the first calls).
For the CG/Jacobi data_exchange_total = 21,311,488;
kspsolve_total = 2,625,536
For the GMRES/BJACOBI data_exchange_total = 6,619,136; kspsolve_total =
54,403,072 (dominated by initial calls)
I will try to switch up my MPI to see if anything changes; right now my
configure is with --download-openmpi.
I've also attached the data exchange routine in case there is something
obviously wrong.
NB: Graphs/Data are from just one run each.
-sanjay
On 5/29/19 10:17 PM, Smith, Barry F. wrote:
> This is indeed worrisome.
> Would it be possible to put PetscMemoryGetCurrentUsage() around each call to KSPSolve() and each call to your data exchange? See if at each step they increase?
> One thing to be aware of with "max resident set size" is that it measures the number of pages that have been set up. Not the amount of memory allocated. So, if, for example, you allocate a very large array but don't actually read or write the memory in that array until later in the code it won't appear in the "resident set size" until you read or write the memory (because Unix doesn't set up pages until it needs to).
> You should also try another MPI. Both OpenMPI and MPICH can be installed with brew or you can use --download-mpich or --download-openmp to see if the MPI implementation is making a difference.
> For now I would focus on the PETSc only solvers to eliminate one variable from the equation; once that is understood you can go back to the question of the memory management of the other solvers
> Barry
>> On May 29, 2019, at 11:51 PM, Sanjay Govindjee via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> I am trying to track down a memory issue with my code; apologies in advance for the longish message.
>> I am solving a FEA problem with a number of load steps involving about 3000
>> right hand side and tangent assemblies and solves. The program is mainly Fortran, with a C memory allocator.
>> When I run my code in strictly serial mode (no Petsc or MPI routines) the memory stays constant over the whole run.
>> When I run it in parallel mode with petsc solvers with num_processes=1, the memory (max resident set size) also stays constant:
>> PetscMalloc = 28,976, ProgramNativeMalloc = constant, Resident Size = 24,854,528 (constant) [CG/JACOBI]
>> [PetscMalloc and Resident Size as reported by PetscMallocGetCurrentUsage and PetscMemoryGetCurrentUsage (and summed across processes as needed);
>> ProgramNativeMalloc reported by program memory allocator.]
>> When I run it in parallel mode with petsc solvers but num_processes=2, the resident memory grows steadily during the run:
>> PetscMalloc = 3,039,072 (constant), ProgramNativeMalloc = constant, Resident Size = (finish) 31,313,920 (start) 24,698,880 [CG/JACOBI]
>> When I run it in parallel mode with petsc solvers but num_processes=4, the resident memory grows steadily during the run:
>> PetscMalloc = 3,307,888 (constant), ProgramNativeMalloc = 1,427,584 (constant), Resident Size = (finish) 70,787,072 (start) 45,801,472 [CG/JACOBI]
>> PetscMalloc = 5,903,808 (constant), ProgramNativeMalloc = 1,427,584 (constant), Resident Size = (finish) 112,410,624 (start) 52,076,544 [GMRES/BJACOBI]
>> PetscMalloc = 3,188,944 (constant), ProgramNativeMalloc = 1,427,584 (constant), Resident Size = (finish) 712,798,208 (start) 381,480,960 [SUPERLU]
>> PetscMalloc = 6,539,408 (constant), ProgramNativeMalloc = 1,427,584 (constant), Resident Size = (finish) 591,048,704 (start) 278,671,360 [MUMPS]
>> The memory growth feels alarming but maybe I do not understand the values in ru_maxrss from getrusage().
>> My box (MacBook Pro) has a broken Valgrind so I need to get to a system with a functional one; notwithstanding, the code has always been Valgrind clean.
>> There are no Fortran Pointers or Fortran Allocatable arrays in the part of the code being used. The program's C memory allocator keeps track of
>> itself so I do not see that the problem is there. The Petsc malloc is also steady.
>> Other random hints:
>> 1) If I comment out the call to KSPSolve and to my MPI data-exchange routine (for passing solution values between processes after each solve,
>> use MPI_Isend, MPI_Recv, MPI_BARRIER) the memory growth essentially goes away.
>> 2) If I comment out the call to my MPI data-exchange routine but leave the call to KSPSolve the problem remains but is substantially reduced
>> for CG/JACOBI, and is marginally reduced for the GMRES/BJACOBI, SUPERLU, and MUMPS runs.
>> 3) If I comment out the call to KSPSolve but leave the call to my MPI data-exchange routine the problem remains.
>> Any suggestions/hints of where to look will be great.
>> -sanjay
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190530/a320faa1/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190530/a320faa1/attachment-0003.png>
!$Id:$
subroutine psetb(b,getp,getv,senp,senv,eq, ndf, rdatabuf,sdatabuf)
! * * F E A P * * A Finite Element Analysis Program
!.... Copyright (c) 1984-2017: Regents of the University of California
! All rights reserved
! Modification log Date (dd/mm/year)
! Original version 01/11/2006
! 1. Revise send/receive data add barrier 24/11/2006
! 2. Correct send/receive and add error messages 16/03/2007
! 3. Change 'include/finclude' to 'finclude' 23/01/2009
! 4. Remove common 'pfeapa' (values in 'setups') 05/02/2009
! 5. finclude -> petsc/finclude 12/05/2016
! 6. Update for PETSc 3.8.3 28/02/2018
! 7. Change 'id' to 'eq' 23/05/2019
! Purpose: Transfer PETSC vector to local arrays including ghost
! node data via MPI messaging
! Inputs:
! getp(ntasks) - Pointer array for getting ghost data
! getv(sum(getp)) - Local node numbers for getting ghost data
! senp(ntasks) - Pointer array for sending ghost data
! senv(sum(senp)) - Local node numbers to send out as ghost data
! eq(ndf,numnp) - Local equation numbers
! ndf - dofs per node
! rdatabuf(*) - receive communication array
! sdatabuf(*) - send communication array
! Outputs:
! b(neq) - Local solution vector
# include <petsc/finclude/petscsys.h>
use petscsys
implicit none
# include "cdata.h"
# include "iofile.h"
# include "pfeapb.h"
# include "setups.h"
integer ndf
integer i, j, k, lnodei, eqi, soff, rbuf,sbuf,tbuf, idesp
integer getp(*),getv(*),senp(*),senv(*)
integer eq(ndf,*)
real*8 b(*), rdatabuf(*), sdatabuf(*)
integer usolve_msg, req
parameter (usolve_msg=10)
! Petsc values
PetscErrorCode ierr
integer msg_stat(MPI_STATUS_SIZE)
! Sending Data Asynchronously
soff = 0
idesp = 0
do i = 1, ntasks
if (senp(i) .gt. 0) then
sbuf = soff
do j = 1, senp(i)
lnodei = senv(j + idesp)
do k = 1, ndf
eqi = eq(k,lnodei)
if (eqi .gt. 0) then
sbuf = sbuf + 1
sdatabuf(sbuf) = b(eqi)
endif
end do ! k
end do ! j
idesp = idesp + senp(i)
sbuf = sbuf - soff
call MPI_Isend( sdatabuf(soff+1), sbuf, MPI_DOUBLE_PRECISION,
& i-1, usolve_msg, MPI_COMM_WORLD, req, ierr )
! Report send error
if(ierr.ne.0) then
write(iow,*) ' -->> Send Error[',rank+1,'->',i,']',ierr
write( *,*) ' -->> Send Error[',rank+1,'->',i,']',ierr
endif
soff = soff + sbuf
endif
end do ! i
! Receiving Data in blocking mode
idesp = 0
do i = 1, ntasks
if (getp(i) .gt. 0) then
! Determine receive length
tbuf = getp(i)*ndf
call MPI_Recv( rdatabuf, tbuf, MPI_DOUBLE_PRECISION, i-1,
& usolve_msg, MPI_COMM_WORLD,msg_stat, ierr)
if(ierr.ne.0) then
write(iow,*) 'Recv Error[',i,'->',rank+1,']',ierr
write( *,*) 'Recv Error[',i,'->',rank+1,']',ierr
endif
rbuf = 0
do j = 1, getp(i)
lnodei = getv(j + idesp)
do k = 1, ndf
eqi = eq(k,lnodei)
if (eqi .gt. 0 ) then
rbuf = rbuf + 1
b( eqi ) = rdatabuf( rbuf )
endif
end do ! k
end do ! j
idesp = idesp + getp(i)
endif
end do ! i
call MPI_BARRIER(MPI_COMM_WORLD, ierr)
end
